NO MORE STOCK JATO
NO MORE STOCK JATO
first off this is converted to a on road car now,(thats why i put it in the on road section)NO STOCK PARTS ARE LEFT AT ALL, ALL CHANGED TO UPGRADED ONES, THERE IS NO OTHER JATO WITH THIS MUCH, I CHECKED EBAY, GRAIGS LIST AND ALL THE FORUMS GALLERYS, NO ONE HAS THIS MANY PARTS OR CUSTOM MADE PARTS AS I DO!! YOU ARE LOOKING AT ONE OF ONE MADE JATO! THE MODS ARE AS LISTED HERE:
-FULLY ported and polished 3.3 engine sleeve and carb.(now a 5.0)
-polished and balanced crank and push rod
-o.s. head
-K AND N AIR FILTER
-custom made cnc titanium machined tranny gears(all the internal gears)
-nitruos oxide system with a custom S8 reed( to let more nos in the motor)(rb innovations only makes up to a S5 reed)
-5 piece carbon fiber kit
-custom cnc machined top brace plate
-custom cnc machined bottom chassis
-custom made cnc machined crankcase cover
-aluminum shocks
-alum. shock tower
-alum. bulk head
-alum. bumper brace and bumper
-alum.a-arms(front and rear,shaved down for less wieght)
-alum. wheel hubs and carriers - also shaved down
-titanium custom made front and rear tie rods
-titanium steering rods
-titanium cvds (rear axles)
-steel braided fuel lines
-grafite brake pads (look of carbon fiber)
-high heat cross drilled and slotted alum. brake rotor
-alum. brake arms
-roll cage
- and alot more that i can not think of. IF THEY DID NOT MAKE A MODIFIED PART FOR THIS THAN I EITHER MADE IT MYSELF OR I WENT OUT AND HAD ONE MADE! NO MATTER WHAT THE COST!!
-o.s. head
-K AND N AIR FILTER
-aluminum shocks
-alum. shock tower
-alum. bulk head
-alum. brake arms
-roll cage
Looks like you have alot of work and $$$ into it. Looks good brother, can you keep the wheels from spinning with that NOS package?
differante strokes
did you every hear the old saying "differante strokes for differante folks? it is not for racing or for show it is for what is called "my OWN injoyment.
You should also try getting it on reader's rides in the rc car magazines.
