Old 08-31-2009, 09:26 AM   #1
Default glow plug promblems
Hey
i got a nitro 4 tec with a 3.3 engine and i keep fouling or burning my glow plugs after 1 use for about like 10-15 mins, if anyone noes how to slove this plzz reply. i am using 30% sport blue thunder nitro and i am using the super duty traxxas glow plug 3232x and i use ez start to start up the engine.
imran is offline   Reply With Quote
Old 08-31-2009, 09:43 AM   #2
trickd122's Avatar
Originally Posted by imran View Post
Hey
What percentage Nitro are you using, Plug and head clearance?
Too close an head clearance will foul and burn the plugs?
Are your needles very sensitive?
More info
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 08-31-2009, 10:12 AM   #3
hey i am new to this and i dont noe what you mean by head clerance and also how can you change that
Old 08-31-2009, 10:13 AM   #4
lil-bump's Avatar
Trader Rating: 83 (100%+)
Hey
I would run 20% nitro if you do know your true head clearance. Also you may want to fattten up your highend needle
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-31-2009, 11:11 AM   #5
nazwenhome's Avatar
Trader Rating: 33 (97%+)
if its burning(dull grey filament) then it means u have less fuel for burning.
but mostly its the head shim clearance that caused this sort of problem.
unscrew your heat sink and button head from the sleeve. add 1 or 2 more 0.1mm head shims between the sleeve and button head. still in doubt, just richen your high speed needle it should be ok if its not too hot.
just my 2 cents
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
OS CV-R Promblems AssocRacer Nitro Off-Road 12 11-08-2007 09:13 AM
