Old 08-19-2009, 03:09 PM   #1
Default Nitro Acclerates by Itself
Hey guys, I have a Nitro RS4 3. I got it about 4 years ago, but stopped playing it until about a week ago. The reason i stopped was because the clutch was broken, but i went and replaced that. Anyways, i've played about a lil over 10 tanks and its been running like new until recently. It started yesterday, and basically the car would accelerate at full throttle by itself. I thought maybe the low and high end needle were out of tune so i read up on it and tried to tune it myself. That didnt solve the problem. I made sure to get it back to the specs it were before i touched it because im far from good at this hobby yet. Anyways, i was wondering if anyone had any idea how to solve this problem because i want to get back to playing again! lol. Thanks in advance.
silentxnight is offline   Reply With Quote
Old 08-19-2009, 05:15 PM   #2
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Hey
Make shore your clutch shoes havent come apart,also check your idle ,your radio settings too.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 08-19-2009, 10:38 PM   #3
Thanks for replying, i checked the idle and its not that. i can turn it all the way in and itll still accelerate on its own. I dont think its the radio settings either. My first thought was that the batteries for the receivers were dead, but i changed them out and still the same. I guess its the clutch. How would i go about checking it? is it hard to do? i havent touched this thing in well over 4 years...im afraid i dont remember how to fix it. Could anyone give me a quick step by step in trying to get to the clutch. Thanks.
Old 08-19-2009, 10:48 PM   #4
nevermind. i think you are right about the clutch shoes. I searched up some videos on youtube and it looks fairly simple. Will try to fix it tomorrow. Thanks.
Old 08-20-2009, 12:39 AM   #5
you can maybe check the throttle servo and see if it is still good?!
LAM3SAUCE is offline   Reply With Quote
Old 08-20-2009, 11:47 AM   #6
lethalsassonic's Avatar
If your engine is racing and not idling then u are too lean. But u said u checked the needles, so maybe there's an airleak, there's too much air in the chamber and that's making it too lean, the engine sounds like it's all or nothing. I had the same problem with an OS motor, and I gave up and just bought a new one. Listen if it's not a simple airleak, replacing engine parts can be half the price of a new engine, or the same price as buying a used one that is in good condition. So consider getting another motor if repairs and adjustments aren't working.
Cars: Tamiya TRF 417x, HPI Ken Block WR8, EREVO Brushless
Heli's: Blade 300x, Blade 130x, Blade mcpx BL
lethalsassonic is offline   Reply With Quote
Old 08-21-2009, 04:20 AM   #7
nazwenhome's Avatar
Trader Rating: 33 (97%+)
here is some of my thoughts,
if the clutch came loose? during idle, yr kit will move but just enough or slowly pick up speed on the ground.
if its a leak? im sure its a nasty hole that caused this. of course, lotsa fuel dripping out.
if its the throttle servo, u can see carburetor opening initially if its too big or the servo just like to be at open throttle position or low battery.
if as soon as u start your engine,it launch off full speed, on the ground then u better check with local hobby shop for careful inspection.
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
