Old 08-16-2009, 02:46 PM   #1
Default Road Rails
Anyone have any input on these? we are thinking of getting them and want to know if anyone has used them? Good bad or ugly!
reddishdsb is offline   Reply With Quote
Old 08-16-2009, 02:54 PM   #2
wingracer's Avatar
Trader Rating: 24 (100%+)
If they are the ones I'm thinking off, I don't like them. It's easy for a car to just run right over them and have a head on crash with another car.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-16-2009, 05:18 PM   #3
Grenade10's Avatar
Trader Rating: 37 (100%+)
Yes light weight, easy to run over and land in the wrong lane and total 2 cars .... sometimes more.
We use them for some exhibitions, just for the weight and ease of set up, but not for racing!!!
For racing if you can afford, CDC Click Track, or make your own out of 3" white plastic down spouts. Not the ribbed one, smooth square. See a Do-it Best Store.
Darkside, Sweep, BSR, Fantom, IGT Hobbies and IGT8
Byrons Fuel, ProtoForm Bodies & Futaba Radio Gear by Choice
Founding Member of CORRC .... 5280raceway
www.darksidems.com www.igthobbies.com www.IGT8.com
Grenade10 is offline   Reply With Quote
Old 08-16-2009, 06:28 PM   #4
Danny-b23's Avatar
+1.
Seen a car get about 15ft of air and hit an outer barrier. Took out a shock tower, bent bulkheads, bent turnbuckles...
Over all, they turn cars into missiles.
RC America|XRAY|ORCA|Motiv|EA Motorsports
Danny Buck
WCICS Rep - Round 1, Saskatoon, SK
Danny-b23 is offline   Reply With Quote
Old 08-17-2009, 04:18 PM   #5
tomkelley's Avatar
Yeah Its easy for cars to get launched over them, but its usually due to the placement of them on the track. Also one thing you can do is double stack them back to back to create a barriers where needed. Plus if you design layouts properly then you could reduce these problems. Try to avoid placing rails perpendicular to the racing line. For instance a gradual sweeper or carousel on or off the strait is a good example. Most driver's will not jump over this type of section because they are not driving directly towards the barriers at perpendicular angles. I also used other elements such as a heavy floor mat at apexes to discourage corner cutting to close to the rails. Hope this helps.
There's also a lot of other track materials you could use such as old fire hose (contact your local fire dept, they give them away alot). Also I heard of CRC's click system, might be another option.
Detroit Radio Control Car Club
www.drccc.org
tomkelley is offline   Reply With Quote
QCRCCC OFF-ROAD RACING emer Manila Racers 16543 04-08-2016 01:31 AM
Aarcmcc Rules TrustMe Australian Racing 43 10-10-2005 02:15 AM
road rails, love em or hate em?? thedoc329 Electric On-Road 84 11-01-2004 09:38 PM
Hobby shop tracks; Whats wrong with this picture? imjonah Electric On-Road 61 10-21-2004 03:55 PM
Road Dome Track System (Has your club used this?) LabRacer Electric On-Road 15 04-16-2004 11:06 PM
