Old 08-13-2009, 12:29 PM   #1
SERPENT7twenty's Avatar
Trader Rating: 20 (100%+)
Questions?? PISTON Question
So I successfully changed out my Rod last night. The top of my Piston was black. Go some of it off with a rag ... is this due to the motor being too Rich or too Lean? Low end or High end?
Motor has been running strong for the last and first gallon. Just switched up to Maxys 30%
Picco Red Dot Evo3 w/Picco 2651 pipe and header
Running PowerMaster 30% fuel
Thanks!
TEAM KAMIKAZE - SERPENT 966 - NOVAROSSI - HUDY - KO PROPO - XCEED
Kamikaze Development Driver - R&D = Rebuild & Destroy
www.Kamikazetoysandhobbies.com
SERPENT7twenty is offline   Reply With Quote
Old 08-13-2009, 12:34 PM   #2
Send a message via Yahoo to motojon
Thanks!
Leave it there J you want that on the piston
My Gpa(RIP)
motojon is offline   Reply With Quote
Old 08-13-2009, 12:43 PM   #3
nitrodude's Avatar
Thanks!
The black stuff is just carbon build up, it means the motor is running good. Dont remove it from O.D. of the piston, it actually helps compression. Im sure Sam told you already, but Ill tell you anyways, run one tank at idle with the new rod before you hammer it, and if I were you I would richen the needles when switching fuel, you WILL have to retune it.
Steven Muller
AKA El Pibe RUFAST? HAHA!!!
Ronin Speed Parts
nitrodude is offline   Reply With Quote
Old 08-13-2009, 12:51 PM   #4
OOOOO ok .. I will leave it .. I only took off a small small amount since it was caked on there soo bad.
1 tank idle .. NOTED! Dooooon't really wanna mess with the tuning since its been runnung so good so I'll just go back to the PowerMaster LOL
Thanks fella's ..
Steve Jon .. any of you guys comin out?
Old 08-13-2009, 12:52 PM   #5
JRGTR's Avatar
Send a message via MSN to JRGTR
Carbon is your friend!!!
MTX5/Novarossi engines!
Byron's Racing Fuels/Airtronics
Matrix tires
www.pitlanehobby.com
JRGTR is offline   Reply With Quote
Old 08-13-2009, 12:56 PM   #6
Big Jeff BBQ's Avatar
I just changed a rod in the same motor at the GLC and after the rod change i could not control the temp started to get to hot which was worse than befor the change.
I think for the price of the motor and the rod i will just run it until it BLOWS!
I still have the motor it is a Murnan Modified Red Dot if any body is interested i will sell it for $100 with both rods it only been ran at 2-Big races.
The motor is very clean and has had after run oil in it after every day of running.
later
Jeff
Blowin' Smoke BBQ
Special Thanks To:
Steve Pitts
Kevin Hutchinson
Big Jeff BBQ is offline   Reply With Quote
Old 08-13-2009, 12:57 PM   #7
asw7576's Avatar
I thought ( excessive ) carbon build up on top of piston head can cause early detonation problems ie. higher engine temp, and scracth the cylinder liner.
Old 08-13-2009, 01:08 PM   #8
Send a message via Yahoo to sheeley
Im no expert in anything but I notice the dark color build up in my engines and I dont think it can be wiped off with a rag. I also noticed the black gunky stuff in a engine that hasnt been run out of fuel and then oiled at the end of the day. Maybe its just fuel difference.
sheeley is offline   Reply With Quote
Old 08-13-2009, 01:30 PM   #9
I googled carbon build up and I guess that black gunk is carbon. I saw some rc pictures that I cant believe such thick build up could be good.
Old 08-13-2009, 01:33 PM   #10
I do know that I run the fuel out of my engines and run oil threw them while still warm and after 4 gallons the top of my piston is pretty black color with nothing to whipe off
Old 08-13-2009, 01:54 PM   #11
Ok so I ran the first tank idle...towards the end before it ran out of gas it did the normal rev up and die...I tried to re start the motor but its frozen up.
I grabbed the flywheel with some needle nose .. wont budge... tried other various things and the motor wont turn over to at all...
Did I break something?
Old 08-13-2009, 01:55 PM   #12
trickd122's Avatar
Default carbon build up
While carbon buildup is not a desirable look it actually helps the compression of your engine. I am not an "Expert", However from experience too lack can also mean that your running too lean. Occassionally I would clean the top of the piston only this IMO keeps the engine running efficiently.
my 2 cents
TEAM MAGIC "making my competition disappear"
trickd122 is offline   Reply With Quote
Old 08-13-2009, 02:09 PM   #13
Roelof's Avatar
Send a message via ICQ to Roelof
A recent topic:
http://www.rctech.net/forum/nitro-ro...une-color.html
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-13-2009, 07:10 PM   #14
lil-bump's Avatar
Trader Rating: 83 (100%+)
I've never seen my piston black but they are all a nice brown tan color. I run Byrons pro-driver 16%, The only time I've seen sludge (Unburnt castor) is when I ran Odonnels
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 08-13-2009, 07:26 PM   #15
keavze's Avatar
stuck at TDC? better remove engine and check again...
at least openup the backplate and have a look.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
SAVAGE - SS, .25, .21 Official Thread! Horatio Monster Trucks 11167 05-15-2017 09:40 PM
Palmaris engine thread EdwardN Onroad Nitro Engine Zone 2533 08-12-2013 11:48 AM
Losi xxx-4 Chrissy C Electric Off-Road 2902 05-26-2011 10:10 AM
RB Concept C6 BBT7 for sale & L2G magnesium head separately jaylude22 R/C Items: For Sale/Trade 11 03-25-2008 04:22 PM
modified engines Quietroit Onroad Nitro Engine Zone 35 10-03-2005 11:43 AM
