Old 08-11-2009, 09:32 AM   #1
PrimeAKF11's Avatar
Default If piston gets stuck at TDC, is it a sign that it's not broken in?
I have a question. I've been breaking in my new Picco .12 motor and put about 8 tanks through it. Thing is, when it's cold, it still sometimes gets stuck at TDC when I'm trying to start it. Not always, but sometimes. If I heat it up even a little bit it never gets stuck. It could be my weak starter box (Old duratrax with 12v gel cell powering it), but still.
Is this a sign that it's not broken in yet? I was planning on putting two more tanks through it (10 tanks total) and then tune it for a race this weekend, but I've also heard something like I need to put at least half a gallon through it before tuning it for a race. What do you guys think?
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 08-11-2009, 09:35 AM   #2
Gonzo RR's Avatar
Picco motors are known for this! I have a Picco .21 with over a gal. thru it and it will still get stuck at the top. I recomend warming up the engine first it will make it easier to start and your starter box will thank you for it!!! run it a bit on the rich side
Xray NT1 '08 /'09 EC LRP12R / Serpent 720 '08 RB Concept V12, R3 RB mods, V12 Rody, Matrix RW / Serpent 733, 733TE RB T9 / EA RC8T OS .21 Vspec speed tuned / Kyosho Inferno GT, GT2 / EA SC10 / Serpent Cobra GT coming soon!
Gonzo RR is offline   Reply With Quote
Old 08-11-2009, 09:37 AM   #3
PrimeAKF11's Avatar
Yessir, I do plan on bringing a hair dryer with me for the race . But do you think I can give it a (rich) race tune after 10 tanks?
Old 08-11-2009, 09:41 AM   #4
Gonzo RR's Avatar
Originally Posted by PrimeAKF11 View Post
Yessir, I do plan on bringing a hair dryer with me for the race . But do you think I give it a race tune after 10 tanks?
I would run it a bid rich for practice and qualifiers and one hour leaner on the HSN for the main.
It is important to keep the engine runing rich while you are braking it in. The excess oil and lubricants take the stress from moving parts. After half a gal thru it you should be able to tell how the engine comes to life.
Old 08-11-2009, 10:12 AM   #5
Roelof's Avatar
Send a message via ICQ to Roelof
Most engines have in a cold conditon a tighter fit of the piston. When it get stuck sometimes when starting it only says there is still a tight fit of the piston but it could be race ready, you only do need to take time to warm up the engine.
8 tanks is not much and it can take a while to get the right fit, when that moment is there the engine will be running at its best.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 08-12-2009, 06:55 AM   #6
nazwenhome's Avatar
Trader Rating: 33 (97%+)
that is normal for any newly broken in engines. im in the middle of breaking in my picco engine too. almost 2 liters went in and its still tight.
from what i can gather around, picco evo series engines, half gallon is what normally pro racers would say, and they do make a difference in its life time behavior. get it just about 90-100 degree Celsius constant run in on a starter box for another liter or so.
hope this helps
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
Old 08-12-2009, 09:11 AM   #7
clmbia45's Avatar
The other thing you can do is loosen the glow plug 1/8 of a turn for start, and tighten it after motor starts.
clmbia45 is offline   Reply With Quote
Old 08-12-2009, 10:35 AM   #8
nazwenhome's Avatar
tried that tips before, it'll just spray some nitro out on a slightly high idle. heat the motor up and start. can't go wrong with that
Old 08-18-2009, 08:57 PM   #9
Default im new to rc, and i dont know if my motor is damaged
i recently bought an hpi rs4 evo. and i ran 6 tanks. after i took it out for a spin and tried to reach second gear then suddenly the car died. i tried to start it up again but the roto thing wont spin, i checked the pistons and inside was small bits of metal. the pistons would hardly move. what would be wrong with my motor?
disbedakoogui is offline   Reply With Quote
Old 08-18-2009, 09:03 PM   #10
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Im guessing a broken conrod or broken bearing. 6 tanks is way too little for an engine to break-in.
That is unless you bought it used, in that case you shouldve looked at the conrod for any play.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
Old 08-18-2009, 09:19 PM   #11
SERPENT7twenty's Avatar
Trader Rating: 20 (100%+)
I have a Picco .12 Evo3 Red Dot in my car and it is on its 2nd gallon of gas and 2nd rod and it STILL locks up EVERYTIME.
I have heard and seen that the hair dryer trick works perfect.
TEAM KAMIKAZE - SERPENT 966 - NOVAROSSI - HUDY - KO PROPO - XCEED
Kamikaze Development Driver - R&D = Rebuild & Destroy
www.Kamikazetoysandhobbies.com
SERPENT7twenty is offline   Reply With Quote
Old 08-18-2009, 09:54 PM   #12
My IDM evo3 is well into 3 gallons and still gets stuck and I have to pry it off of center, and I have a 3cell lipo powering one of the JLR mini starter box motors......
and that is even on a nice hot 100 degree texas day.. it usually won't get stuck again after the first time.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 08-18-2009, 10:00 PM   #13
Yea mine gets stuck pretty often. I usually just take a Hex wrench and turn over the flywheel through the clutchbell bolt.
My guys have told me its normal ... another guy I race with always has problems .. he even burned out one of his starter box motors trying to start hte bastard LOL
But once she is fired up shes ready to rock and roll .. love that motor!
Old 08-18-2009, 10:30 PM   #14
GHETTOTEACHER's Avatar
I have a Novarossi that has over a gallon and a half. It still gets stuck during a cold start. Another antidote is a LIPO bump box!! I have the Ofna pink box with the big motor. I use a 3800/ 20C/ 14.4, four cell lipo and that thing cranks the tightest motor with ease!! It has so much power that it might snap a con rod, but I have not had a tight start issue since I installed that battery!!
Herolin <---Traded my Airtronics for an Ipad and Laptop...
Soon to be GHETTOPRINCIPAL..
GHETTOTEACHER is offline   Reply With Quote
