Old 01-22-2004, 10:30 AM   #1
Default HPI RS4 3 SS questions
I finally got my car rippin'. But this leads me to my next couple of questions.
1. My idle seems to high......what is the best way to adj. this? It seems that when i adj. the idle....the engine is hard to start, or will die.
2. The underside of the car has 5 scews that hold the motor/motor mount in place. These screws are rounded, not flush. I notice that they are starting to wear down do to the parking lot bashing i do...are there other screws that I can use that would be flush with the chassis?
Thank you
UNITED_RC is offline   Reply With Quote
Old 01-22-2004, 10:59 PM   #2
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
as long as your car doesn't move when idleing it isn't idleing high I know it sounds like it but leave it if it starts and doesn't move.
as for the screws, I had the same problem, all I know is that they wear and need to be replaced I don't know of any flush screws
Smoke21 is offline   Reply With Quote
Old 01-23-2004, 07:31 AM   #3
smoke,
Thank you for the reply....but sometimes it does idle to high, and causes the car to roll slightly.
Regarding the engine mount srews, that is poor design. There needs to be some flush mount srews.
Old 01-23-2004, 06:28 PM   #4
adjust your idle screw. Close the carb little bit. OR double check your servo trim. my NTC3 is FAST. I gotta get body...
tjrcs is offline   Reply With Quote
hyper7 shock questions and other questions buds302 Nitro Off-Road 1 06-11-2008 12:03 AM
B4: Kit vs RTR, Questions. BelialX13 Rookie Zone 15 02-14-2008 04:57 PM
kanai diff questions and other questions famous182 Electric Off-Road 2 02-25-2006 02:19 PM
TNX QUESTIONS chrometwanks Monster Trucks 2 02-03-2006 06:02 PM
TB questions nekmiyevo2 Electric On-Road 7 08-11-2005 09:37 AM
