Old 01-20-2004, 05:50 PM   #1
Ducati-Rider's Avatar
Default NTC3 Pull Start on an AE starter box ~ Will it work?
Been running electric and finally got the nitro bug. Found a pull start (PS) NTC3 and need to know if the AE starter box works on a PS engine. I got the starter box with my second NPS NTC3 and it works fine with the NPS, but seems to bog or drag on the PS stock engine. Are the flywheels different sizes that interfere with the starter box drive wheel?
Gotta tell ya, ain't been the same since I pulled the trigger on a nitro
Ducati-Rider is offline   Reply With Quote
Old 01-20-2004, 06:26 PM   #2
thefuzzclub's Avatar
you have to change the engine mount and flywheel. to use the starter box, the flywheel must be bigger and the engine mounts must sit lower. check the part numbers in the ae manual.
thefuzzclub is offline   Reply With Quote
Old 01-20-2004, 06:32 PM   #3
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
you dont have to change it i didn't change mine the non p/s fly wheel is lighter but how cares about weight untill a roar race. i forgot just change the backer plate on it and throw the p/s away good luck with it
20 SMOKE is offline   Reply With Quote
Old 01-20-2004, 11:17 PM   #4
Default Thqnks
I thought there was some kinda spacing difference. as the non pull starts fits great and spins right up.
bill
Old 01-21-2004, 02:41 AM   #5
The Sleeper's Avatar
There shouldn't be much of a spacing difference.
The reason the engine mounts are taller for PS engines is to make clearance for the pull start itself. The flywheels for pull start engines are generally bigger. This allows you to still use a starter box. You may want to check to see you have a pull start flywheel. Compare it to the one on your other car. You should see a difference in diameter.
Do you have problems starting your PS engine even by pulling the rope? If so, the one-way bearing may be bad.
The Sleeper is offline   Reply With Quote
Old 01-25-2004, 02:06 AM   #6
Im2lazy's Avatar
Default Re: Thqnks
bill
The pull-start flywheel is specifically larger than the non-pull flywheel so that even when using pull-start mounts and a pull-start flywheel, you would be able to use a starter box. All cars with flywheel access through the bottom of the chassis are like this. That is why there is a larger (pull-start) flywheel for pull-start engine mounts and a smaller (non-pull) flywheel for lower non-pull motor mounts. The reason for the smaller flywheel and lower motor mounts is simply performance. The reason for the larger flywheel and higher motor mounts are obviously for clearance.
So long as you don't see any black rubber from the starter wheel on the chassis, there should be any clearance issues.
Agreed.
Im2lazy is offline   Reply With Quote
pull start doesnt work with glow plug in atebit Rookie Zone 8 08-27-2007 08:03 PM
How do starter boxes work? Do they work with Shaft Start engines? Ofna_Driver_777 Electric Off-Road 7 02-25-2007 07:51 PM
Pull Start? Roto Start? or Starter Box? jamiekulhanek Electric Off-Road 3 09-09-2004 01:50 AM
NTC3 pull start to non-pull question SeventyGTX Nitro On-Road 4 02-16-2004 08:05 PM
how do I convert pull start NTC3 to non? jbui Nitro On-Road 5 06-11-2002 09:59 PM
