Old 01-19-2004, 11:13 PM   #1
lachlan90's Avatar
Default removing tire from rim
does anybody know how to get the tire of the rim. what is the easiest way???
thanks
lachlan90 is offline   Reply With Quote
Old 01-19-2004, 11:29 PM   #2
modellor's Avatar
Rubber - soak in acetone
Foam - Soak in gasoline
modellor is offline   Reply With Quote
Old 01-19-2004, 11:29 PM   #3
sup
sup's Avatar
acetone. but the tires will melt. and if the rims are plastic, it will melt too. i think nylon rims wont melt when acetone is applied. proline sells a chemical to remove ca too. some place the wheels in boiling water, have not tried this yet though..
sup is offline   Reply With Quote
Old 01-19-2004, 11:38 PM   #4
Randy Caster's Avatar
Trader Rating: 46 (100%+)
You only need to post once, people will answer.
Old 01-19-2004, 11:54 PM   #5
veecee's Avatar
Trader Rating: 34 (100%+)
boiling rubber tyres/rims will break up the superglue and allow you to reuse the rim. provided the rim is half decent in quality and doesn't go soft when boiled.
veecee is offline   Reply With Quote
Old 01-20-2004, 02:30 AM   #6
The Sleeper's Avatar
If you boil your tires, do so for at least a half hour.
The Sleeper is offline   Reply With Quote
Old 01-20-2004, 11:27 PM   #7
Ducati-Rider's Avatar
Default Boiled tires
Guys - I just boiled a set of LOSI xxx-4 rears and the process crystalized the glue and the tires peeled right off. Just cook them for a while and flip them like doughnuts.......clean peel and saved the wheels!
Ducati-Rider is offline   Reply With Quote
Old 01-21-2004, 01:15 AM   #8
rod_b's Avatar
Send a message via AIM to rod_b
I don't know if it's the same for the smaller tires as it is for the 1/8 scale buggy tires but I bake mine at 350 degrees for about 15 mins. The heat will crystalize the CA and the tires will peel right off. The heat should not warp the rims or damage the foam or even the tire...well that's how it is for 1/8 buggy tires anyway.
rod_b is offline   Reply With Quote
Old 01-21-2004, 08:27 PM   #9
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
Just buy some glue disolve Golberg makes some
Smoke21 is offline   Reply With Quote
Old 02-08-2004, 02:48 AM   #10
Send a message via ICQ to Cartman
rubber tyres will NOT melt in acetone but certain wheels will!
Dremel UK - Schumacher Racing - Vapextech UK - MBModels UK - MRT
Cartman is offline   Reply With Quote
Old 02-08-2004, 03:28 PM   #11
Smoke21's Avatar
check it this is what you need
removing 1/18 shocks rcjustforfun Rookie Zone 3 05-16-2007 11:36 PM
removing tire from rim lachlan90 Electric On-Road 8 01-20-2004 02:27 AM
Removing CA Calvin Ng Electric On-Road 1 08-03-2003 11:54 PM
removing CA from tire Calvin Ng Electric On-Road 6 05-04-2003 01:45 PM
removing CA from tire Calvin Ng Electric On-Road 1 05-04-2003 12:47 PM
