PICCO EVO3 IDM
PICCO EVO3 IDM
would anyone know the factory needle settings for this motor? thanks
Start with the Top needle Flush with the housing and then you can start with the low speed needle maybe around 1/2 turn in from flush on the slide adapter. This will be rich but running. May need to rich or lean the bottom end more. But will start you off.
perfect, worked out nicely, thanks for the info
No problem glad to help.
