Old 07-31-2009, 10:16 AM   #1
didrace's Avatar
Default Serpent 720 with v-one rear end..
It seems that i can not get this car to work ..
is there any chance i can change the rear end to the kyosho car?
Thanks!!
didrace is offline   Reply With Quote
Old 07-31-2009, 10:36 AM   #2
impalabob64's Avatar
Send a message via AIM to impalabob64
Thanks!!
What is your setup ,what tire shore are you running, are you running a solid axle or front diff,what diff fluid are you running in the rear.Post you setup im pretty sure you will get help.Post your setup an explain what the car is doing.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 07-31-2009, 12:46 PM   #3
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Thanks!!
Yes you can. all you need are small shims to shim the hinge pins where the arms run. You can run everything of the 720 except the lower arms and the rest of the assembly of the uprights.
eBay user id: riketsukirai
Riketsu is offline   Reply With Quote
