Old 07-23-2009, 02:29 PM   #1
Default Expanding the fuel tank
Hi Guys,
Thought i would ask the question on here as i have been told they used to do this alot.
My questions is how do you blow out your tank to get more volume.
I was told years ago how to do it but i wasnt sure.
Does anyone know how this can be done, as my tank is under volume like to get that bit extra out of it
carlin is offline   Reply With Quote
Old 07-23-2009, 02:40 PM   #2
AutieBender's Avatar
If you did heat it up and expand it the wouldnt that hurt the seams on the fuel tank? Maybe more fuel line would be a better solution
Team Losi/Novarossi/Losi Tires/Nitrotane/JR propo/Upgrade Graphics
Quicks R/C Hobby Shop
Surprise, Arizona
AutieBender is offline   Reply With Quote
Old 07-23-2009, 02:59 PM   #3
Trader Rating: 18 (100%+)
Default expanding fuel tank
Originally Posted by carlin View Post
Hi Guys,
What kind of chassis are you talking about. If you heat the seam, it will most likely leak, just as the other post says.
Many tanks are interchangeable with other manufacturers.
I have changed tanks in my on-road cars with ohter makes for longer run times. Just be sure if you race the car, you do not exceed the max. volume allowed
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 07-23-2009, 03:13 PM   #4
Roelof's Avatar
Send a message via ICQ to Roelof
Just heat up the tank with a paint removal gun and blow on the tank or use some tools to bend it outwards from the inside.
Just find the spots where you have some room to shape the tank more outwards.
The quality of an answer comes with the quality of the question.
Roelof is online now   Reply With Quote
Old 07-23-2009, 04:24 PM   #5
Trader Rating: 28 (100%+)
Send a message via AIM to Scott Fisher
What he said, or as also suggested, you can add fuel line and/or an external filter.
| Capricorn | Ybslow | Proline-Protoform | Johnny Bravo Racing | Desoto Racing | Murnan Modified | Matrix Tires | Powermaster Fuel |
Scott Fisher is offline   Reply With Quote
Old 07-23-2009, 04:40 PM   #6
RayJ's Avatar
If you have an air compressor with a fine point nozzle this method works pretty well. Block the fuel outlet with a small piece of fuel tubing. I generally use a 3mm screw screwed into the fuel tubing and then put over output fitting. I then attach a longer length of fuel tubing to the pressure intake fitting of the tank. I turn on the air compressor to about 10 to 15 lbs of air pressure. NO MORE than this. You will see the tank expand slightly. With a heat gun I very gradually heat the area I want to expand. You will see the area soften. Allow to cool..... and your done.
RayJ is offline   Reply With Quote
Old 07-23-2009, 05:23 PM   #7
wingracer's Avatar
Trader Rating: 24 (100%+)
This is exactly how I have done it before but you have to be very careful with the heat. It's very easy to blow a hole in the tank if you get a spot too hot.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 07-23-2009, 11:52 PM   #8
asw7576's Avatar
What is your car, carlin ?
Boil the tank in boiled water and you blow some pressure through a long silicone tube with your mouth. Use zip ties to lock the nipple and silicone tubes. Keep the lid opener on top, above water. Becareful when doing this acrobats.... ---> hot water and your skins.
Old 07-24-2009, 07:00 AM   #9
nazwenhome's Avatar
Trader Rating: 33 (97%+)
go for extra fuel tube. just wind excess tubing properly with a tube clip. maybe 3/4ft length would do.
seen my cousin doing this experiment with his mtx4 tank and boiling water long time ago. seems ok at the begining, expended tank 80cc which is reasonable. turns out, he made it fragile maybe somewhat brittle. all it need is just a stupid flip and it cracks open.
Serpent S411 TE : ready to race
Tamiya TA05 VDF : sleeping mode
Align 450 sports v2 : tick-tock in progress
nazwenhome is offline   Reply With Quote
Old 07-24-2009, 08:40 AM   #10
Hi Guys,
Thanks for the reply, thats the method using boiling water.
It's for 1/8th rallycross not onroad.
It's for Kyosho MP9 fuel tank.
Just i know loads of onroad guys do this not many ppl in rallycross do.
Try putting alot of fuel tubing just gets messy & i like having tidy car though.
Also it has plenty of fuel tubing already.
Thanks for the replies though guys.
Old 07-24-2009, 03:12 PM   #11
rcfoolz's Avatar
Trader Rating: 22 (100%+)
Send a message via Yahoo to rcfoolz
I can say that with the extra fuel tubing, when I've tried it, the engine does not perform the same. Blowing the tank out is the better way to go...JUST TAKE YOUR TIME!
Am I going back racing?...Hmmm.. Not anytime soon... But soon enough.
rcfoolz is offline   Reply With Quote
Nitro Engine Break In d4_racer Australian Racing 50 02-22-2011 03:42 PM
Head Clearance 54 Onroad Nitro Engine Zone 13 03-24-2010 03:02 PM
High Performance Nitro MassiveMods Australian Racing 1318 03-12-2009 04:52 PM
Yay Dvx400Rider Nitro Off-Road 7 02-27-2009 09:25 PM
RC News in Sarawak jfc_tech Malaysian R/C Racers 678 12-08-2008 09:26 AM
How To Break In ?????? MaTt 93 Nitro Off-Road 11 10-09-2007 02:44 PM
