Old 01-15-2004, 04:19 AM   #1
bleach1's Avatar
Default What to do with servo wires?>
I have built a serpent 705 and the car doesnt use a radio box so i have all these long servo wires i have cable tied around the steering servo. How has everyone else taken car of their servo wires? Is it safe to cut and shorten them?
bleach1 is offline   Reply With Quote
Old 01-15-2004, 05:21 AM   #2
of course you can cut them, just make sure you don't make any faults (red on yellow or something like that)
-Nitrohead- is offline   Reply With Quote
Old 01-15-2004, 05:29 AM   #3
mop_iko's Avatar
Location: JOHOR BAHRU, MALAYSIA but now working in SHANGHAI
Default Re: What to do with servo wires?>
You can cut them short, but i think no need for you to cut it, just fold it and tie it with a zip tie. bundle them together and 'store' them under your radio tray between your tank and the battery pack. make sure the wires are not 'grinded' by the front diff or blocking the servo saver movement.
this is one issue / problem serpent need to consider when they design a new car after 710... coz in 710 also they havent solve this problem yet. plus the location for on/off switch...
mop
mop_iko is offline   Reply With Quote
Old 01-15-2004, 05:55 AM   #4
KMac's Avatar
The best thing to do is unscrew the bottom cover of the servo, de-solder the leads, cut them to length and re-solder them back in place. No mess, no fuss.
KMac is offline   Reply With Quote
Old 01-15-2004, 08:24 AM   #5
Turbo9000's Avatar
For me this is the hardest part of installing the electronics. I swap my electronics alot so I dont want to cut my wires shorter. I usually bundle up the wire with zip ties somewhere out of the way on the car. It gets pretty hard when you run a failsafe and all that good stuff. Just make sure you keep the wires away from servo arms and motor mounts...I had a battery short out because the hot chassis melted the wires.
Turbo9000 is offline   Reply With Quote
Old 01-15-2004, 10:01 AM   #6
Providing they do not damage the board or link solder joints in the process.
Personally I do shorten my pigtails to keep wiring neat and clean, but if you are not an accomplished solderer with adequate equipemnt, you run the risk of ruining the servo by messing up the board or pigtail.
NitroJohnnyD is offline   Reply With Quote
Old 01-15-2004, 10:12 AM   #7
Send a message via AIM to Profoxcg
so there is no place to put an on/off switch? -- what am I going to do ?!
Profoxcg is offline   Reply With Quote
Old 01-15-2004, 03:00 PM   #8
Trader Rating: 2 (75%+)
You can zip-tie, superglue, shoe-goo or shrinkwrap the on/off switch to the throttle servo.
PUNISHER is offline   Reply With Quote
Old 01-15-2004, 08:14 PM   #9
tIANcI's Avatar
Do not cut or re-solder the wires ... you may be asking for trouble unless you have a TRS (throttle return spring). Just bundle it up neatly and cable tie it but remember to also secure the bundle so that it does not drop near the chassis or below it!
tIANcI is offline   Reply With Quote
Old 01-16-2004, 08:14 AM   #10
VenomWorldOrder's Avatar
Default Re: Re: What to do with servo wires?>
www.servocity.com
sells the bits to shorten the wires without soldering. i sent a email to ppurchase these items but their service for OS customers isn't that good! i sent around 4 emails stating a order reminding etc and still haven't recieved any products even after they seemed to confirm it.
VenomWorldOrder is offline   Reply With Quote
Old 01-16-2004, 09:04 AM   #11
Manticore's Avatar
R/C Tech Charter Subscriber
Default Re: Re: Re: What to do with servo wires?>
Originally posted by VenomWorldOrder
www.servocity.com
this?
Manticore is offline   Reply With Quote
Old 01-24-2004, 02:34 AM   #12
bleach1's Avatar
Ok here was my eventual solution to my servo wire problem with the 705. I tried to tie everything down with zip ties. I could only fit my relativly large hitec reciever in a position where it sticks out a fair bit. Any advice on how to protect it?
Old 01-24-2004, 02:55 AM   #13
Thumbs down
http://members.optusnet.com.au/bleach1/705wires.jpg
this link works....
UOOHH! UGLY! a mate i race with told me today that dick smiths in australia sells the servo plug ends (the metal components in the pic that manticore posted) so you can then cut the wire and sorten it from the plastic connector peice.
Old 01-26-2004, 06:04 AM   #14
Talking cool, thanks for the info
I was able to get the connector replacements at my local store, but it was not as cheap as in the website. I am going to try to get all that sort out tonight. =) I want to start the break in of my engine this week so its ready for some saturday practice.
Old 01-27-2004, 03:40 AM   #15
this link works....
i've purchased the parts i talk about above at dick smiths. they are pcb matrix sockets. they fit......kind of. there is a certain section that is different (the part on the metal connector that is exposed on the plastic cover that sits infront of the plastic flap) this peice is longer than standard. it fits but not too well.
verdict. try it. it will work but won't fit perfect. if anyone in australia can get servocity to answer your emails AND SEND YOU THE PROIDUCTS EMAIL OR PM ME.
Anybody ever solder new wires on there servo? sm1nts2escape Radio and Electronics 1 09-09-2008 05:32 PM
changing servo wires bigbutstupid Radio and Electronics 1 05-11-2008 05:13 AM
Shortening servo wires TL_XXX-S_racer Electric On-Road 6 01-13-2008 11:18 AM
servo wires? spiderman-49 Rookie Zone 5 11-01-2006 04:21 PM
Shortening servo wires Accord Electric On-Road 12 12-01-2003 01:31 AM
