Old 07-21-2009, 09:41 PM   #16
Speedypeterb's Avatar
Trader Rating: 16 (100%+)
Send a message via AIM to Speedypeterb
there is one thing no one mention is that the one way bearing can go bad or not oiled properly
Speedypeterb is offline   Reply With Quote
Old 07-22-2009, 10:12 AM   #17
Loveless's Avatar
Originally Posted by VA_Racer View Post
OK the only reason there should be any gear striped is because either gear mesh, or clutch bell bearing are bad or thrust bearing bad, engine moved ie gear mesh. People complain about this problem and most of the time say its the car, but most of the time its user error. I don't strip gears unless I miss the mesh. I know people that have never striped a gear.
Try cutting 2 strips of paper just enough to fit between the pinions and the gears and set it that way.
VA_Racer, i was going to ask how to mesh correctly, so i guess i remove the 2nd gear, and mesh the 1st gear first, i was using mugen parts bag plastic package doubled to do this but i was doing both at the same time, so i'll give the doubled paper a shot, thanks for all you guys help.
AIRTRONICS/KEVLAR R.D./MUGEN FUEL/PARMA, CENTRAL BODIES/MUGEN SEIKI/PICCO ENGINES/JP ENGINES/ BELTRANS WHEELS AND HOBBIES, KAMIKAZI RACING.
"Free your mind, and your ass will follow"...
Loveless is offline   Reply With Quote
Old 07-22-2009, 10:22 AM   #18
lil-bump's Avatar
Trader Rating: 83 (100%+)
I would also check your thrust bearing. The only other time I stripped 1st is my tires where too low and in a turn the chassis rolled enough for the 1st gear to touch the ground.
Pass you soon...
Elliott Hart
Serpent America
Desoto Racing Team
Chicky fan club member #9
One Eighth Racers of Toledo
lil-bump is offline   Reply With Quote
Old 07-22-2009, 11:04 AM   #19
Trader Rating: 18 (100%+)
Default MTX4
I have had my spur gears in for well over a year now, and they are just starting to show signs of wear.
When I ran my MTX3, I changed over to the .08 gears, and stripped them every time I ran the car. I went back to the stock gars for the MTX3, and never had another problem.
There really are quite a few areas that will cause the spur gears to strip, but if you are at your wits end, try changing the spur gears and pinion gears to the MTX3 stock gears. You will not have has many tuning options, but it may do the trick so where you will not strip the gears out.
Areas where I would check out first
gear mesh.
rear layshaft<[possibly bent>
clutch bell and or clutch bell bearings
chassis tweaked
engine moving under stress
chassis to brace
bearings in the spur gears
just a few items I would check first
[COLOR="Red"][FONT="Comic Sans MS"][/FONT][/COLOR]BRC358http://www.kamikazercracing.com
nearest barstool
brc358 is offline   Reply With Quote
Old 11-09-2009, 11:05 AM   #20
Team Ewing's Avatar
Default Gear Failure
Hi,
Hopefully you've found the cure to your gear stripping. Certainly a lot of great info here. If NO other cure has helped, change your rear bulk heads. I have a very high mileage MTX4 and early this season I got around to changing my rear bulk heads and found the bearing hole on that side elongated. It cured my mesh problems...... it's a long shot, but it can happen. Good racing to ya.
Losi 22 Xceleron Tekin Pro 13.5
Team Ewing is offline   Reply With Quote
Old 11-09-2009, 11:40 AM   #21
asw7576's Avatar
Then maybe I'm the only person in this forum with the least complaint of 1st gear stripping problem ... (just kiddin.... maybe I got lucky all this time )
... I get 1st or 2nd gear stripping problem only 3 times since 2004, the year I started nitro racing :
1 time : mtx3 ...... engine block shifting after impact.
1 time : mrx4r ..... engine block shifting after impact.
1 time : G4S ....... wrong size / wrong application 1st and 2nd spur gear vs 1st and 2nd pinion gear.
Old 11-09-2009, 02:04 PM   #22
freestyles's Avatar
Trader Rating: 14 (100%+)
I don't have a mugen but the same principle aplies. I get the foil out of a ciggarette packet and double it over. I then take my first gear spur off and adjust my mesh with the the second gear. Put the paper between the spur and pinion and squeeze them together really tight then swing off the motor mount srews and you should be right to go. Just double check it all once everything is installed again that your first gear meshed ok. There is a fine line between a perfect gear mesh and mesh that's to tight/loose.
Hope this was what you were after
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Mugen MTX-4R Bing Nitro On-Road 3921 04-14-2014 07:11 AM
Mugen MTX-4 Grasshopperr Nitro On-Road 9087 08-30-2011 07:15 PM
MTX4 talks MAVICXXX Malaysian R/C Racers 4528 05-27-2010 04:17 AM
Keep stripping second gear (MTX4) BIGTACO Nitro On-Road 33 11-17-2006 05:12 PM
