Old 07-14-2009, 06:49 PM   #1
Monteman's Avatar
Trader Rating: 16 (100%+)
Default NTC3+ Motor
Just normal driving last night all of a sudden the car stops and i can hear it over revving and not going anywhere, walk all the way across the parking lot (of course ) and notice that the spurs aren't moving together, i shut the car off and haul it back to my pit box aka my trunk and notice that the motor had shifted over causing the 1st gear spur to disengage from the clutch bell. Is this at all normal? Will locktite hold up to the presumed heat in the motor mounts?
Cameron - Edmonton Canada
** Every time see someone use their first post to necro-bump a 4 year old thread all I can think is "at least they used the search function" **
Monteman is offline   Reply With Quote
Old 07-14-2009, 07:12 PM   #2
xlamontx's Avatar
Trader Rating: 15 (100%+)
This is the first time I ever heard of this happening, but I'm also not surprised if the motor mount screws were installed w/o thread lock.
A little dab of blue (removable) thread lock should keep the screws tight while operating your car.
"Have Car ~ Will Travel"
XLX Racing (Est. 1995)
TRACK MASTERS R/C ~ TEAM DRIVER
MSRA-Racing.com
xlamontx is offline   Reply With Quote
Old 07-14-2009, 08:19 PM   #3
Monteman's Avatar
theres threadlock on them so im not sure what cause it, i want to take a look at hte clutch and spurs to make sure theres no damage, the motor is already out so the clutch bell is a piece of cake but i dont want to rip half the car apart to get at the spurs if i only have to pull a bit, what do i need to do to get at/change the spur gears on the ntc3+ ?
Old 07-14-2009, 09:23 PM   #4
kidsid99's Avatar
Trader Rating: 53 (100%+)
The fastest way is to take the rear shock tower loose from the diff case (3 screws). Then take the 6 screws that hold the diff case together, then take the 2 screws out that go in front of the two speed, (there is a piece that goes across the out drive piece there that has just 2 screws- u shaped) then just lift the diff case apart, you might not even have to take the rear of it all the way up just the front to get the small gear out of the diff case that is attached to the two speed. It is real simple. You can do it in about if not less than 5 minutes.
Make sure that you oil the bearings in the clutch bell before you put them back in and make sure there is no grit between the motor mounts and the chassis. That motor should have never moved if it was tight, unless there was some grit that gave way to make it loose. I will try and find the car break down and put a link up here for you. Also the big spur gear is on a oneway bearing and it needs to be oiled fairly often also, depending on how much you run and how hard.
Hope this helps, if not you can keep posting and we will continue to try and help.
XRAY, RC America, Boca Bearings,
www.msra-racing.com
kidsid99 is offline   Reply With Quote
Old 07-14-2009, 09:34 PM   #5
kidsid99's Avatar
Here you go:
http://aedownloads.com/downloads/man...c3_manuala.pdf
Check out pages 7 & 8. They show most of what I was talking about. Even if it shows it during building you don't have to take it that far down. As a matter of fact you can get the two speed out without removing the motor.
www.msra-racing.com
Old 07-14-2009, 10:00 PM   #6
Monteman's Avatar
Sweet thanks dude, for whatever reason i didnt get that book with my car. More reason to believe my NIB ntc3+ was not NIB. Manual missing and fuel lines all chopped up.
Old 07-15-2009, 12:03 AM   #7
kidsid99's Avatar
You are more than welcome. Glad I could help. I don't know about you but I download manuals for all the cars I get in case something happens, it also lets you get in there for the factory guys setups and option parts.
www.msra-racing.com
race ready RC10GT FS FT nitro_freak1 R/C Items: For Sale/Trade 21 02-25-2006 09:52 PM
NTC3 Team Car with OS .12 TR SeattleRCer R/C Items: For Sale/Trade 23 11-14-2005 11:03 PM
Hobbytown OP Racing RETURNS! Core Creations Kansas/Missouri Racing 2804 04-25-2005 09:37 AM
Warpspeed Demon and Demon 2 futureal Electric On-Road 2557 03-08-2005 03:41 PM
sts rs12 modified turbo .12 asd Nitro On-Road 238 03-26-2003 11:14 PM
