Old 01-11-2004, 05:52 PM   #1
Regional Moderator
racer rich's Avatar
Steering Servo Problem?
Hello. I have a question regarding my steering servo.
Whenever I turn the wheel to the right, it and let go, it centers back and the wheels are straight. Whenever I turn the wheels to the left, and let go, it also centers back-----but not the the same position as when I did this when I turned the wheels right and let go. It centers a little more to the left. The wheels are centering differently when I turn different directions. This is the case when I turn from lock to lock, and a little. It is a KO PROPO 2144 metal gear digital servo. I checked the first "plastic gear" and it does not seem stripped. Is this normal, or a servo malfunction? I know its not the car because it did the same thing in another car of mine.
Thanks in advance!
racer rich is offline   Reply With Quote
Old 01-12-2004, 05:28 PM   #2
Regional Moderator
racer rich's Avatar
anyone?
Old 01-12-2004, 05:35 PM   #3
chachi's Avatar
i have an analogue servo that does the same thing. it is an airtronics 94357.
i am also curious if this normal, or is i should be sending it in for repairs......
chachi is offline   Reply With Quote
Old 01-12-2004, 10:36 PM   #4
Regional Moderator
racer rich's Avatar
I have been racing on and off for the past 6 years and from what I can remember this is not normal. I am really perplexed since I opened up the servo and saw no damage to the gears (servo is literally brand new). Does anyone know what this can be? I use a Futaba 3PK radio, if that makes any difference.
Also, is the Airtronics servo spline the same size as a KO Propo servo spline?
Thanks in advance.
Old 01-13-2004, 07:56 PM   #5
I have a month old steering servo and i've noticed the same issue. What is the problem and is there a solution??
snor565 is offline   Reply With Quote
steering servo problem Bdegan Electric Off-Road 2 04-07-2007 08:29 AM
18 steering servo problem. c_wehrer707 Micro and Mini Scales 9 03-06-2007 12:28 PM
steering servo problem..Hellfire Hellfire1 Monster Trucks 1 02-04-2006 08:56 AM
Ok, put in new servo, now another problem with steering. klonoa Nitro On-Road 2 05-30-2004 08:37 PM
