Old 07-11-2009, 01:45 AM   #1
Pro10noob's Avatar
Default Kyosho part VZ-08B
Who has a picture of the above part from Kysosho??
It is from a Kyosho V-ONE RR and i think it is the ring that holds the belt pulley or is it the complete pulley set to use on part number VZ-08???
Any info is more then welcome
Pref with picture
cheers Roy
l===/o\===l
[_]-###-[_] V-link proto type Pro10,JKMR P235-SE Pro10
P235-VL Pro10 comming soon
Sponsered by me,myself and i :)
Pro10noob is offline   Reply With Quote
Old 07-12-2009, 08:52 PM   #2
I think this is what you are looking for. Its a whole set.
VZ008B - Pulley set
http://www.shopkyosho.com/product/pa...r=VZ008B/410.0
Kyo83 is offline   Reply With Quote
Old 07-13-2009, 01:49 AM   #3
Pro10noob's Avatar
As in a pulley and the part that holds it in it's place???
I know it is for the VZ-08 and that is a spool for the RR.
If any one got a pic of the item i would be very happy.
regards Roy
l===/o\===l
Old 07-13-2009, 11:49 AM   #4
Ed Anderson's Avatar
Trader Rating: 26 (100%+)
Arrow
VZ-08B is a pulley set the "B" is probably just an update. Don't think it has anything to do with a spool.
Contains parts
22,23,24,196,197 X1
21 X2
26 X3
21 = pulley... rear jack shaft
22 = pulley... front jack shaft to diff
23 = brake adapter
24 = spacer
26 = plate
196 = pulley... front jack shaft to rear jack shaft
197 = plate
Ed Anderson is offline   Reply With Quote
Old 07-13-2009, 01:51 PM   #5
If you want the spool, it is VZW220
there is a picture on this link
http://www.rc-mushroom.com/product_i...ducts_id=13844
VZ008 is here, and B is usually an update of a part. I don't know the exact differences but probably tooth numbers or material.
Support those that support us
https://ActivRC.com http://TeamPowersUSA.net https://www.1upracing.com/ http://TeamAssociated.com
Brian Bosley is offline   Reply With Quote
Old 07-13-2009, 02:37 PM   #6
Pro10noob's Avatar
That is the spool for a triple r and i have the spool for a double r and need the pulley to fit on it so i can use the bloody thing.
The spool for the rr is part VZW-08 and i need the pulley that go's on that sucker.
cheers Roy
l===/o\===l
Old 07-13-2009, 03:16 PM   #7
cheers Roy
according to the manual, the rr came with a one-way (vz078) and a diff. the oneway is not a spool but bolts up similarly. it uses part # 29 and 30 for the pulley which is available in bag VZ009 which is these parts
Old 07-13-2009, 03:31 PM   #8
Pro10noob's Avatar
The front pulley is there on the pic(bottum right) but i also need something to hold it on the spool for the rr.
The spool for the RR is part number VZW-08
http://www.kyosho.de/?page=shop%2Fpr...search=VZW-08#
You need a ring to hold the pulley on the spool.
I don't know if that ring is the same as the one you use on the plastic spool of the S-III parts number VZ-048??
If so then i would be very happy
Look at the pic's.
On the right there is the spool for the RR and i hope that the part in the left pic(bottum right is the one i need.
regards Roy
Kyosho part VZ-08B-b3e635831a8e2f33e134579943fa43fe.jpg   Kyosho part VZ-08B-cc093f8772e3ebcba86a1e93b7847800.jpg
l===/o\===l
Old 07-13-2009, 08:55 PM   #9
Honestly? buy the ybslow aluminum spool and be done with it since it uses current gear sets.
I really had no clue kyosho ever made the spool you showed above, that is quite unique. I don't know why they didn't stick with that since they later went back to it with the one I posted above.
MRCCR Club (Lilydale Victoria) Thread OZDC Australian Racing 1341 06-18-2017 01:38 AM
Hong Nor / Jammin Products And RC Fans Thread plazma Malaysian R/C Racers 1717 04-02-2013 02:07 AM
Kyosho VoneR Thread neons Nitro On-Road 12206 06-29-2012 04:19 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Kyosho V-One RR Evo or FW-05R? AtomiK Nitro On-Road 12 06-02-2004 04:02 AM
Brand new Kyosho V-one-RR Evolution parts mikecatts Nitro On-Road 9 06-01-2004 01:39 PM
