Old 01-10-2004, 05:13 PM   #1
Smoke21's Avatar
Location: Pacifica, California OR Clearlake Oaks, California
Send a message via AIM to Smoke21
Default OK I am getting really frustrated with this steering issue.
OK my Nitro RS4 3 Type SS will drive one way or the other at low speed then turn back the other way at high speed. I tried fixing the toe even with each other still the same issue. What should I do?
Smoke21 is offline   Reply With Quote
Old 01-10-2004, 09:22 PM   #2
Motorman's Avatar
Sounds like the steering linkage is sloppy in some way, or your servo could be going bad and not centering properly
Just here to give the world grief.
Motorman is offline   Reply With Quote
Old 01-10-2004, 09:41 PM   #3
BG
BG's Avatar
Your problem sounds very confusing as you describe it. It can be a number of things.
First of all what radio are you using? There are features in the more advanced radios that allow for a Dual Rate Exponential for the stearing. You can adjust the speed of the servo from centre to full travel and then back to centre. Check this if its a JR.
You servo saver might have a problem, check that.
Also check what motorman has suggested
Cheers Bill
BG is offline   Reply With Quote
Old 01-10-2004, 11:30 PM   #4
Smoke21's Avatar
Not the steering linkage... It was replaced yesterday I have an airtronics MX-3 with 2 94102 servos that are only 5 months old plus I replaced it with a faster JR Z270 Servo still didn't help, I thought it might be toe but still didn't help after re-straighting the toe turnbuckles it was worse (though I think it might be the fact that I had to change it to FWD to start the car will my drill(damn pullstart!) also I don't know if I have one (i never bought one, i donno if my kit has one) I noticed on thing about the front diff when I steered the wrong way and I was stuck in dirt spinning the wheels one spun longer than the other, could that be the problem?
Old 01-11-2004, 09:44 AM   #5
Motorman's Avatar
The car will never go straight with the front end doing all the work. that is your problem. Why were you in dirt with an onroad car anyway?
Old 01-11-2004, 08:45 PM   #6
Smoke21's Avatar
I was in the dirt because I steered the wrong way and had 0 traction and yes I will make it 4WD again but the front diff is old and worn needs to be replaced. Two things were wrong the front diff and tweak. I put it on RWD and it got better, then I took it back home and took a look at the rear camber(I saw it from behind when I was driving and noticed the left had more camber one way than the right wheel) and the camber link ball screw was in a different hole on the left wheel than the right wheel, I will see if it is better tomarrow.
OS 21 trouble (frustrated) Storm59 Nitro Off-Road 18 07-12-2008 07:46 PM
Frustrated jakethedriver Electric On-Road 45 03-08-2007 03:44 PM
Frustrated with my first nitro, help! bcmorrison Rookie Zone 6 02-21-2005 11:49 PM
very frustrated. PLEASE HELP prelude19 Electric On-Road 9 10-05-2001 11:07 PM
