Old 11-20-2009, 02:43 PM   #76
Hey there,
in the 900010 Set are included:
All new pulleys with a newly designed profile and optimized for the belts.
4 adapters for the new pulleys
and also some small parts for the assembly.
If you want to "update" your current V8 you also need to order the new, longer front belt, 606117.
We changed the design and also the the shape of the pulleys.
Addiotionally we changed the size of the pulley on the front oneway and the connected one.
We had 16Z to 24Z in the front, and with the new pulleys we have 18Z to 27Z for smoother rotation.
Hope i could help
Alex
coupe is offline   Reply With Quote
Old 11-20-2009, 03:39 PM   #77
scoobie1's Avatar
Thanks coupe, that info helps tremendously!
I live with fear every day...sometimes she lets me race!!!
scoobie1 is offline   Reply With Quote
Old 11-21-2009, 11:23 AM   #78
Default pulley question and velox 2010
Originally Posted by coupe View Post
Hey there,
Hope i could help
Alex
Alex: first, thanks for all the information. About the pulleys, what is diference that the drivers feels between 900010 Set and the shepherd metallic pulleys? is only the weight?
Finally will be velox V8 2010? the kit will have some optional 2009 parts?
thanks for your time
Gabriel
veloxargentina is offline   Reply With Quote
Old 11-22-2009, 01:50 AM   #79
Hey there,
if we can we like to help you, so we do !!
Point 1
The new pulleys are a little bit different in the tooth profile, so the drivetrain is running very smooth.
Point 2
Compared to the aluminium pulleys the new pulleys are super light, so ther is a extra in acceleration.
And with 2 in oppositely positioned grub screws in the adapter you can also minimize vibrations with the second grub screw !!
You can also use the new extra superleight weight pulley adapters, i will check the number on monday, and i also saw that we dont have pictures of them in the shop !!! I will prepare on monday.
Point 3
The plastic is a little bit more belt friendly
So thats it for the moment, now it is time for breakfast !!!
Alex
Old 11-22-2009, 06:15 AM   #80
Velox V8 2010
For the future kit we do not like to change to much as we want to stay with the kit like it is. There is no reason for us to change something essential.
The only "update" we will have are the new pulley and the new adapters.
They will be supplied with the kit 2010 wich will be available in the spring.
Also we will maybe have a change with the middle belt. As you maybe realized the middle belt is about 1 tooth too long with the new pulleys. So we are testing some belts in the moment, and i am pretty sure that we will have a shorter belt for the new pulleys.
So thats ist again
Alex
Old 11-22-2009, 10:53 AM   #81
speedracer1bp's Avatar
Default New Pulleys
So, with the new pulleys, the 18Z and the 27Z. Would you still use a 7mm tire split?
Also, it this for mechanical advantage??
speedracer1bp is offline   Reply With Quote
Old 11-22-2009, 10:57 AM   #82
hello,
all is the same like before, you can use the same tire split as the gear ratio is still the same, only the diameter of the two front pulleys are grown up and helps the smoothness of the drivetrain.
me
Old 11-22-2009, 11:03 AM   #83
wingracer's Avatar
Trader Rating: 24 (100%+)
Like coupe said, the ratio is exactly the same. Bigger pulleys means more teeth are in contact with the belt, distributing the load over a larger area. Should reduce the chances of a belt stripping.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 11-22-2009, 06:05 PM   #84
That sounds good. However I must say. The Shepherd is by far the easiest 1/8 scale car on belts I have ever run. This is icing on the cake!
Old 11-26-2009, 09:55 PM   #85
FF25510's Avatar
started to build, any tips
FF25510 is offline   Reply With Quote
Old 11-27-2009, 03:44 AM   #86
Just enjoy !!!
Alex
Old 11-27-2009, 05:45 AM   #87
RC MARKET's Avatar
brushless form hk
RC MARKET is offline   Reply With Quote
Old 11-29-2009, 09:39 AM   #88
Default loose middle belt
Hi all,
I have just purchased the josh cyrul conversion from teamc (excellant service and prices) but noticed the middle belt is loose, I did buy 17015 (belt tensioner) but wondered what you use as a mount for this,can anybody help?
thanks,
lee
leenus is offline   Reply With Quote
Old 11-30-2009, 12:19 AM   #89
Send a message via MSN to PMSorber
Originally Posted by leenus View Post
Hi all,
thanks,
lee
Lee,
We have mounted the tensioner on it original place, no problems with the belt.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 12-11-2009, 06:04 PM   #90
FF25510's Avatar
finished , may test next week
Shepherd V8 '09-ssl10330.jpg   Shepherd V8 '09-ssl10336.jpg   Shepherd V8 '09-ssl10335.jpg   Shepherd V8 '09-ssl10334.jpg   Shepherd V8 '09-ssl10337.jpg
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
TWC 1/10 & 1/8 ON ROAD OPEN FUN RACE IN MIRI Steven @ Yap Malaysian R/C Racers 73 07-03-2009 04:28 AM
Tags
shepher max 21
