Old 05-06-2011, 10:41 AM   #391
IgorR's Avatar
Originally Posted by shambmk View Post
Hi guys,is there any changes for the pulley set year 2009 and year 2010 kit?
The front pulley of the 2010 are 27 - 18 teeth instead of 24 - 16 on the 09 or older car version.
Because of this change the front belt is different. I think longer.
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 05-06-2011, 10:42 AM   #392
IgorR's Avatar
Originally Posted by IgorR View Post
Hello,
Could you tell me what is the difference between the original Velox 09 chassis (ref: 903101) and the Hard version (ref: 903111)?
Is the hard chassis for high grip track only?
Does anyone run LiFe RX battery in the car? Does it fit?
Thanks,
Nobody?
Yokomo YR-X12
Shepherd Velox EC
Old 05-06-2011, 11:36 AM   #393
kmh
Nobody?
Try posting the question on the "spyshot '11" thread. I have the Protek LiFe rx batt and would like to know if it fits also.
kmh is offline   Reply With Quote
Old 05-06-2011, 11:45 AM   #394
ND
Hello,
Thanks,
Hi
The hard chassis is similar to the original Velox chassis, the 09 version with Velox milled into it is quite a bit softer. I personnally prefer the feel of the car with the hard chassis, the car feels more consistant and with better rear end traction. In the UK we generally use the hard chassis in high and low grip conditions.
ND is offline   Reply With Quote
Old 05-28-2011, 09:57 AM   #395
avs
avs's Avatar
Hello,
Thanks,
i tried the protek life battery. the length and width are no problem, but i had to shim the tank supports up 2mm to provide any gap between the battery and tank.
on the 3rd charge (after only 2 days use) the battery puffed up so badly the tank was locked.
the idea of a LiFe battery sounds great, and the 2mm on the tank is not that bad. maybe i just got unlucky.
Tony Shimko
avs is offline   Reply With Quote
Old 05-31-2011, 04:50 AM   #396
ugglasdav's Avatar
anyone ever have problems with the carb hitting the tank at full throtle?
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 05-31-2011, 07:33 AM   #397
avs
avs's Avatar
if you can get full throttle without contacting the tank, then just adjust the servo travel.
otherwise, you can loosen the carb (pinch screw below the idle screw) and rotate it so the slide will extend to the side of the tank. look at the pics at post 21 of this thread, and you can get the idea, just a little rotation will be enough.
be certain to not let the carb slide out. before the loosen the carb get a visual picture of how close the carb and crankcase are.
Tony Shimko
Old 10-06-2011, 08:23 PM   #398
hello to the team new v8 2010 owner and only shepherd in jamaica
andredemessa is offline   Reply With Quote
Old 10-06-2011, 08:38 PM   #399
have a question if anyone can help, while i am driving and come off a left corner and squeeze the gas the car seem to load up and then shut off, could this be clutch set up or engine tuning
Old 10-12-2011, 05:39 PM   #400
5crossyourlip's Avatar
Trader Rating: 28 (97%+)
engine tuning....rich it up a 1/8 to a 1/4 of a turn on the low end
shepherd velox V8 with max power TQ xL9... is there anything better
Shepherd velox V8 eleven with murnan M21....there's still isn't anything better
ebay feedback: 108+/0-
rcuniverse feedback: 46+/0-
rctech feedback: 21+/0-
5crossyourlip is offline   Reply With Quote
Old 10-13-2011, 07:09 AM   #401
YBSLOW's Avatar
Nobody?
I am running a LIFE battery with my 11, same battery tray as 09.
YBSLOW Racing
RC Target - Capricorn
HOTRACE Tyres, Tru Source, Fantom
POWER MASTER Fuel, 2mm Designs
Protoform Bodies, Avid Bearings, AMR Engines
YBSLOW is offline   Reply With Quote
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
TWC 1/10 & 1/8 ON ROAD OPEN FUN RACE IN MIRI Steven @ Yap Malaysian R/C Racers 73 07-03-2009 04:28 AM
Tags
shepher max 21
