Old 01-05-2011, 01:28 PM   #376
wingracer's Avatar
Trader Rating: 24 (100%+)
Depends completely on the track.
For me, low bite means less caster, spacers behind the arm. As grip comes up, I need more caster, move spacers in front of the arm.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 01-05-2011, 02:06 PM   #377
Chickentrader's Avatar
Originally Posted by ugglasdav View Post
thx guys, and what about the amount of spacers u use for the caster at the fromt, stock it says to put 2 big ones towards the back and 1 small and 2 big towards the front but there is some movement in the front suspension arms
Just use smaller clips and find the right caster clips to get rid of any slop, you should still be able to achieve the same caster angle. There will always be situations where there could be a bit of slop in some places due to wear or small inaccuracies in manufacturing.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 01-13-2011, 01:28 AM   #378
@ Mark:
If no problems come up, everything should be ready before the worlds.
@Wanaberc:
I don't know the CEFX upgrade, but I think it's different as we need a new radioplate bracket for the new flex system.
Last weekend Daniele Ielasi was testing at the Worlds track in Homestead and he was very satisfied. His best lap was 15,8 sec and in a simulated 10min qualifier he could do 37 laps. So we are really looking forward to the Worlds in April.
Best regards
Patrick
www.team-shepherd.com - www.sonic-engines.com
Trick is offline   Reply With Quote
Old 01-24-2011, 01:59 AM   #379
Default This forum needs livening up!
No posts in 10 days; this forum needs livening up! Bring us some news guys!
To put what I preach into practice here are some: Congratulations to Shepherd drivers Stephen and Peter Jovanovic's 1st and 2nd in the Victorian IC State Tiltles.
Stephen and Peter were previously with Motonica: but my understanding is that both of the brothers are (unfortunately for Shepherd fans, but lucky for Capricorn fans) planning to move to Capricorn in the nearest future.
Kindest regards,
Lars.
Old 04-20-2011, 05:19 AM   #380
ugglasdav's Avatar
does anyone know if you can use the v10 recivier box on the v8. thanks
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 04-20-2011, 08:52 AM   #381
Yes you can but you will need to purchase the thin strip of carbon plate that is used as a filler/adapter to make it fit on the 1/8 car properly. Its a genuine Shepherd part but dont have the part number to hand.
An alternative is to purchase an Xray NT1 /RX8 Reciever box which can be modified to fit thats what I did on mine.
eigthracer is offline   Reply With Quote
Old 04-20-2011, 10:07 AM   #382
The item code is #508401
It comes with two alu collars so the box also fits the Velox V8 2010. Please note that it can't be used at the Velox V8 2011.
Best regards
Patrick
Old 04-23-2011, 01:23 AM   #383
Default Front belt n rear strip
Greetings to all,i just bought a kit velox'09 and recently hear that the front and rear belt strip quite often.So guys,what do i need to do before i start to run my velox'09?
shambmk is offline   Reply With Quote
Old 04-23-2011, 08:11 AM   #384
Pooh2's Avatar
Send a message via MSN to Pooh2
Run them as loose as you can and they will last a long time.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 05-01-2011, 08:56 AM   #385
ugglasdav's Avatar
Default 2 speed shoe
hi guys, i have a small problem with my 2 speed shoe. when i spin my 2nd gear i can feel the shoe rubbing not all the way round just in some places. i have also sanded the 2 speed shoe to make it smooth but it still has not worked. also how far do you screw in the set grub screws. thanks
>>>Sanwa m11x
Old 05-01-2011, 05:10 PM   #386
avs
avs's Avatar
any news on '11 update availability in the us?
Tony Shimko
avs is offline   Reply With Quote
Old 05-01-2011, 07:34 PM   #387
avs
avs's Avatar
i was taught to back the scriews by 1/4 or 1/2 turn from locking the shoe. you don't want it to drag, but minimize the slop.
this won't change the shift point but it can make it smoother.
if you set the (spring preload) screws just at the edge of the shoe, this should be a low shift point, then adjust to suit your track conditions.
Tony Shimko
Old 05-02-2011, 02:34 AM   #388
IgorR's Avatar
Default Velox V8 09 Chassis
Hello,
Could you tell me what is the difference between the original Velox 09 chassis (ref: 903101) and the Hard version (ref: 903111)?
Is the hard chassis for high grip track only?
Does anyone run LiFe RX battery in the car? Does it fit?
Thanks,
Yokomo YR-X12
Shepherd Velox EC
IgorR is offline   Reply With Quote
Old 05-06-2011, 03:30 AM   #389
To all Shepherd drivers!!!
Shepherd Micro Racing is working on some changes for U.S. distribution.
Please give us a week more to announce the final facts.
You can be sure that all Shepherd Products will be available in the next two weeks.
We are sorry for this situation.....
Best Regards
Armin
Shepherd-Micro-Racing
veloxrc is offline   Reply With Quote
Old 05-06-2011, 06:20 AM   #390
Default V8 year 2009 and 2010 pulley set
Hi guys,is there any changes for the pulley set year 2009 and year 2010 kit?
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
TWC 1/10 & 1/8 ON ROAD OPEN FUN RACE IN MIRI Steven @ Yap Malaysian R/C Racers 73 07-03-2009 04:28 AM
Tags
shepher max 21
