Old 11-10-2010, 08:35 AM   #361
Rick Vessell's Avatar
Originally Posted by xevias View Post
Hey Rick-
Rumour has it that a white guy is going to show at the RCX race with a Velox8 in Shanghai at the end of the month. Is that white guy you?
If so, I need a resupply of socks and underwear.
Nope, not me. Things are looking tough for me to go anywhere at the moment but that can always change.
Rick
Rick Vessell is offline   Reply With Quote
Old 11-16-2010, 10:42 AM   #362
R3VoLuTiOn's Avatar
Trader Rating: 27 (100%+)
is there a webpage for setups for these cars?
John Tsang 🏁 VBC Racing 🚗 ORCA RC 🚗 GripworksRC 🚗 MotivRC 🚗 GravityRC 🚗 RC America
http://www.facebook.com/VancouverRRR 🏁 http://www.facebook.com/OvergearedRacing
R3VoLuTiOn is offline   Reply With Quote
Old 11-16-2010, 11:24 AM   #363
Pooh2's Avatar
Send a message via MSN to Pooh2
http://www.team-shepherd.com/en/inde...d=24&Itemid=48 This should get you started. Josh also has some setups for the car. I'll post the link soon.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 11-16-2010, 07:50 PM   #364
Hello,
Let me know the type of track you will be racing on and I will post a setup that I would start with.
Mark Sweeney
MJSGas is offline   Reply With Quote
Old 11-23-2010, 08:22 PM   #365
Default Clutch material?
What's the difference between the black, grey and white clutches? Would you generally use a harder clutch on a track with less traction, a smaller track or both?
crafty63 is offline   Reply With Quote
Old 12-06-2010, 07:06 PM   #366
do you have a good setup for a small tight medium grip track?
the default setup looks funny with 4deg toe out???
fuse01 is offline   Reply With Quote
Old 01-02-2011, 07:53 AM   #367
@crafty:
The grey material is the standard one in the kit. It has a good balance between lifetime and grip. The black one is a little bit harder and has a longer lifetime. The white one is a little bit softer and has a shorter lifetime, but you can adjust the clutch a little bit more aggressive.
@fuse:
+4 toe-out is the total for both sides, so 2 on each side. In our download section you can find a setup of Daniele Ielasi in Leno. The track is medium sized and had medium grip. It's already a little bit old, but still a good setup. I would only add a little bit more camber in the rear.
Best regards
Patrick
www.team-shepherd.com - www.sonic-engines.com
Trick is offline   Reply With Quote
Old 01-02-2011, 08:57 AM   #368
Default 2011 Car
Hello Patrick,
Can you give us a hint on the changes for the 2011 car.
We have seen the rear end and sway bar mounting changes. What other changes can we expect?
Thank you,
Mark Sweeney
Old 01-04-2011, 10:00 AM   #369
Dear Mark,
we plan to introduce the following major changes:
- new single-piece electronic mount with laid-down gas servo
- new flex system for the radioplate; it's not necessary to change the radioplate anymore
- new lower rear anti-rollbar with ball bearings
- new single piece upper wishbone bracket in the rear
Soon we will release some pictures!
Probably a upgrade kit will be available for those who don't want to buy a complete new car.
Best regards
Patrick
Old 01-04-2011, 11:12 AM   #370
Originally Posted by Trick View Post
Dear Mark,
Best regards
Patrick
Patrick,
Thank you for the update. I would assume the parts would be available before the World Championships?
Thank You,
Mark Sweeney
Old 01-04-2011, 08:46 PM   #371
Wanabrc's Avatar
Trader Rating: 70 (100%+)
Dear Mark,
Best regards
Patrick
Is the new flex system similar to the CEFX upgrade?
Wanabrc is offline   Reply With Quote
Old 01-05-2011, 06:14 AM   #372
ugglasdav's Avatar
hey guys, would anyone be able to recommend some extras for this car that you feel are needed. also how many spacers do you guys use for the front caster. Thanks. P.S its the 2010 car
>Shepherd Velox V8/Team associated TC5R
>>IDM 2011/ Speed passion/Much More
>>>Sanwa m11x
ugglasdav is offline   Reply With Quote
Old 01-05-2011, 09:32 AM   #373
Pooh2's Avatar
The eccentrics and extra hinge pins. Other than that the car is ready!!!!!!!
Old 01-05-2011, 10:53 AM   #374
wingracer's Avatar
Trader Rating: 24 (100%+)
What Pooh said. Also the bulkhead brace is nice though it looks like that will be eliminated on the 11 update.
Mainly, just stock up on those hingepins. It's not a design weakness, they are supposed to bend in a crash, allowing you to finish the race.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is online now   Reply With Quote
Old 01-05-2011, 12:25 PM   #375
ugglasdav's Avatar
thx guys, and what about the amount of spacers u use for the caster at the fromt, stock it says to put 2 big ones towards the back and 1 small and 2 big towards the front but there is some movement in the front suspension arms
>>>Sanwa m11x
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
TWC 1/10 & 1/8 ON ROAD OPEN FUN RACE IN MIRI Steven @ Yap Malaysian R/C Racers 73 07-03-2009 04:28 AM
Tags
shepher max 21
