Old 10-14-2010, 08:04 AM   #346
Rick Vessell's Avatar
Originally Posted by Pooh2 View Post
Anyone coming???
I'm hoping to be there also, possibly even driving. Too early to say for sure though.
Rick Vessell is offline   Reply With Quote
Old 10-14-2010, 10:04 AM   #347
dj apolaro's Avatar
Whats up Patrick! Hope all is going well and look forward to seeing you guys again. Tell Alex I said Whats up.....
DJ Apolaro
Capricorn RC, Capricorn Tires, Novarossi World, Spektrum, Horizon Hobby, PROTOform, RCTarget, IGT8.
dj apolaro is offline   Reply With Quote
Old 10-14-2010, 03:04 PM   #348
Hey DJ, everything's fine, hope you are fine too!
Do you come to Argentina to the South America Cup? I will go there, I think it will be an interesting event.
Looking forward to meeting you soon.
www.team-shepherd.com - www.sonic-engines.com
Trick is offline   Reply With Quote
Old 10-14-2010, 03:13 PM   #349
dj apolaro's Avatar
I do not think so. I have no information for that race and I already have a full calendar. Have fun and talk to you later.
Dj
Old 10-15-2010, 01:38 AM   #350
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Originally Posted by Trick View Post
At the momen I plan to attend the pre worlds together with Josh Cyrul to give support to all the Shepherd racers.
Patrick
Will you be attending the worlds along with the other Team Shpherd Drivers?
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 10-15-2010, 10:43 AM   #351
Smile
Winracer: thanks a lot for upload your setup. Itīs work very wel only i have a couple of changes about it.
the track i have a little problem with a new aluminium servo saver because a small crash with another car make the steering bad. How much is have tight the servo saver spring? I tight te spring 1.5mm like say the instruction manual.
thank for all
Gabriel
Originally Posted by wingracer View Post
You asked for it. Here is my TQ set-up from the regional. Bumpy and slick parking lot track. Small in size but pretty quick and flowing.
Car is a standard V8 with no CEFX parts except for the bulkhead brace and front shock tower. Standard plastic, eccentric hubs with the bearings down all the way around.
Front:
Shocks: white springs, stock pistons, Losi 40wt oil, lowest hole on tower.
3 degrees camber to start, adjusted by wear, 1 degree toe out.
long wheelbase.
Flat sway bar.
Upper arm position up, no spacers under the deck.
-1 droop.
Ackerman, bellcrank in the back hole, plate adjusted out (I think, need to look at it again)
Tires, Jaco 32's 66mm
Track width 253mm
Rear:
Shocks: white springs, stock pistons, Losi 42.5 oil, one hole up from bottom on tower.
3 degrees camber to start, adjusted by wear, 3 degrees toe-in.
Optional adjustable bar full soft (blades flat, inner hole on arms)
Lower hinge pin position, full UP (this is the key)
Upper hinge pin position: My TQ run was with it down. Moved it up which settled the car down and made it easier to drive but was slower. Left it up for the main.
2mm spacer between upper arm outer ball and upright.
Droop 10mm
Track width, 261mm I think but need to measure to be sure.
Tires, Jaco 35's 71mm
Body, protoform 909 mounted at 21mm with Shepherd rear post extenders in their highest position. Gurney was pretty high, maybe 10mm.
Ok, it's a bit off the wall but if you want a car with really aggressive steering that still has good forward bite off the corner, give it a shot.
veloxargentina is offline   Reply With Quote
Old 10-15-2010, 10:46 AM   #352
wingracer's Avatar
Trader Rating: 24 (100%+)
thank for all
Gabriel
I don't have the aluminum servo saver yet so I don't really know. I hear you need to run it very tight but have no experience with it. I seem to be one of the few people that has no problems with the stock servo saver.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 10-15-2010, 10:54 AM   #353
Smile
Patrick: is a real pleasure that you come to Argentina, my friend and dealer Eduardo Bustos invite to the event at all shepherd racers. In my case is almost imposible go to race for works problems.
Is possible to know if the Velox V8 will be improvements for the 2011 season?
what will be this improvements?
Thanks for all
Gabriel Funes
Old 10-15-2010, 11:21 AM   #354
Pooh2's Avatar
Send a message via MSN to Pooh2
That will be great if you guys make it the track is really really nice YOU WILL LOVE IT!!!!
Patrick
It an AWESOME TRACK Patrick!!! I look forward to meeting you.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 10-16-2010, 01:47 AM   #355
Team Shepherd will attend the Florida Stade Race for a practice in begin of January with Daniele Ielasi and two more Italian Top-Drivers.
For the Worlds our complete Team, Daniele, Patrick, Oliver, Josh "and more" will fight for the Title.
Hi Rick, hope to see you in April!
Armin
veloxrc is offline   Reply With Quote
Old 10-16-2010, 02:01 AM   #356
Yes, we are working on some changes for the V8.
We are sure to improve the good performance for the V8.
If all working well we plan to test the upgrade in January.
But itīs to early to talk about the details.
If we any news or details we`ll inform you.
You have to be patience..........
Armin
Old 10-18-2010, 08:14 AM   #357
Armin
Hello Armin! I'm working on the Pre-WC or the January test also. Too early to say for sure though.
Rick
Old 10-26-2010, 09:38 PM   #358
2056dennis's Avatar
Trader Rating: 126 (100%+)
Default shepherd v8
hey guys i have a new in the box shepherd v8 for sale it is listed in the for sale area or pm me ( my buddy is going to do something different )
CRC Gen XL / Xray 09 , t2r pro / CW sprint and CW rocket / Kyosho evolva m3 / Tekin rs / Futaba 4pks / Trinity / Dirtburners thanks Bill / 1/8th racers of Toledo / Trex chassi / Summit Race way / Stateline
LAZER SPEEDWAY where all else IS just a parking lot / Hobby Stop West Raceway
2056dennis is offline   Reply With Quote
Old 11-01-2010, 11:32 AM   #359
Default Vegas Paris setup
Hello Everyone
Attached is my setup from the Vegas Paris race.
The car was fast, even on small tires
If you have any questions, please PM me.
Mark Sweeney
Mark Sweeney Vegas Paris 2010.pdf
MJSGas is offline   Reply With Quote
Old 11-10-2010, 04:51 AM   #360
xevias's Avatar
Hey Rick-
Rumour has it that a white guy is going to show at the RCX race with a Velox8 in Shanghai at the end of the month. Is that white guy you?
If so, I need a resupply of socks and underwear.
xevias is offline   Reply With Quote
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
TWC 1/10 & 1/8 ON ROAD OPEN FUN RACE IN MIRI Steven @ Yap Malaysian R/C Racers 73 07-03-2009 04:28 AM
Tags
shepher max 21
