Old 08-06-2010, 12:19 PM   #301
g-wan's Avatar
Send a message via MSN to g-wan Send a message via Yahoo to g-wan
Originally Posted by BigBellyCat View Post
That was me. I'm still tuning up the Velox and finding out a lot more things to improve the durability of the platform i'm using. Sad it was raining coz I really wanted to go up against the 966s, the Kyoshos and fellow Velox racers. Anyway, lets see after Raya we just get together and throw together a fun race.
well you running great as im strugle for my engine setup as my engine got new liner and conrod,but if not raining for sure can enjoy the day,just wait n see if got other nitro race after raya..
km k8 / os speed / savox / blitz / contact tyre
km hk1 evo / os speed / savox / sweep
sworkz evo / spower evo s7 / sweep / savox
xray t3 2012 / tekin rs pro / reedy / savox
km racing / sworkz / xray / savox / sanwa / os speed / sweep / ulti / blitz
g-wan is offline   Reply With Quote
Old 08-07-2010, 09:19 AM   #302
BigBellyCat's Avatar
i've done cleaning out the velox and letting her sit together with the new parts being replaced. I'm currently working on the old school Vector to bring to the track and play around with the old on-road engine that still has good compression. When its raining outside which it still seems to do everyday, i'm working on the 511 and db01. i heard theres a fun race after raya
BigBellyCat is offline   Reply With Quote
Old 08-12-2010, 09:10 PM   #303
there are four 2mm screws holding up the graphite battery tray. two of the screws are stripped and i cant get them out. my LHS doesnt stock these miniature sizes. I got a cutting tool to slot the screw heads but i think i'll damage the battery tray in the process. do i just let it be secured to the chassis permanently or is there a way i can remove these screws?
Old 08-12-2010, 09:12 PM   #304
does the 2009 edition pulley replacements have been replaced with the new material?
After another hour of running the 18t pulley turned to eggs. My friends cant figure out why i'm chewing out the belt pulleys but they have upgraded to the alum pulleys. do mugen pulleys fix the velox v8?
Old 08-12-2010, 09:38 PM   #305
wingracer's Avatar
Trader Rating: 24 (100%+)
Try using a small drill bit to drill into the screws from the top. I will probably grab and spin the screw right out.
Slotting is my proffered method. Yes you will end up cutting into the plate a bit but it will still be perfectly fine if you are careful.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 08-13-2010, 02:17 AM   #306
Send a message via MSN to PMSorber
The Shepherd pulley set 2009 is the one with the square adapters. The pulley material is so tough (Kyosho style) that it never disforms. Alu pulleys will eat belts after some time as the teeth get sharpen in time.
Check on this page if your set is the same:
http://www.team-shepherd.nl/index.ph...1&limitstart=6
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
PMSorber is offline   Reply With Quote
Old 08-15-2010, 03:35 PM   #307
I do not have any of these parts on my car, so maybe thats why i'm suffering from parts entrophy. I will be ordering these upgraded components asap.
Can someone help me with the pinions/pulleys combination? When should we be using the 25T/26T pulley in our setups? I'm using the 16t/21t pinion 49t/46t spur to exploit the best acceleration and top speed, but how do we factor in the front and rear tyre diameters, the pulleys etc into our setup?
What sort of tyre diameter should I be aiming for after the end of a 1hr main using the standard 26T pulley? what happens if I change it to 25T? Is there a chart I can compare this and find the better combination of pinions?
Currently i'm setup for a medium low traction track, but would like some info on how to adjust to other tracks if required.
Old 08-16-2010, 01:14 AM   #308
We never use the 25T, maybe others do. 21T / 46T seems a bit too much, focus more on power / traction than on topspeed. On a realy fast engine try 21 / 47 or 20 / 45. Wheel gap must be around 6,5mm / 7mm.
After a 1hr main? That will depend upon the track, I can tell you that you will need a tyre change
As far as I know there is no chart.
@ConSult Trading
Old 08-18-2010, 07:56 PM   #309
Slo-MTX4's Avatar
Send a message via ICQ to Slo-MTX4
Does anyone know if the Mugen servo saver spring fits the car? I know some guys use the Kyosho one but i cant get a hold of one.
Podified Picco/MRX5/Futaba/Savox
PODIFIED ENGINES/Trackside RC
Slo-MTX4 is offline   Reply With Quote
Old 08-19-2010, 01:49 AM   #310
Maybe a strange question, but why should you do that?
@ConSult Trading
Old 08-19-2010, 07:53 AM   #311
avs
avs's Avatar
one time i blamed the spring for a centering problem, but it turned out to be the adjustable ackerman horn. the ears had bent out a little and it would take a set to the left or right after a hard corner.
some guys added a 2nd screw to pin the connection, and others went to the alloy part from teamc or shepherd.
i used a spare plastic part which has held up so far. maybe the earlier parts' plastic was softer? don't know but its something to check.
Tony Shimko
avs is offline   Reply With Quote
Old 08-19-2010, 05:02 PM   #312
Slo-MTX4's Avatar
Because i believe it is too soft.
Old 08-19-2010, 07:58 PM   #313
That alum servo saver from Team C was one of my first upgrades. Very good at holding center and no breakage. It does stiffen up the spring setting though so i backed off one turn and still get very responsive handling. I wouldnt go on replacing the plastic servo saver coz if it tweaks to the left or the right during a race, i'll be struggling just to get it to run
Old 08-21-2010, 03:53 PM   #314
wingracer's Avatar
I'm the overnight TQ for the first annual Jon Laster Memorial race. Man I love this car. I've never had a 1/8th turn like this on a slick track and still grip off the corner.
Team Shepherd USA
Old 08-31-2010, 08:39 PM   #315
Default GLC setups
Hello
Attached is Josh Cyrul's and my setup from this past weekends GLC race in Toledo Ohio.
Josh was on his way to a victory, but was caught up in a late race shunt.
My car was good in the main, placing third after having learning the personality of my new Sirio engine.
If you have any questions, please feel to ask.
Mark Sweeney
Team Shepherd/CEFX
MJSGas is offline   Reply With Quote
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
TWC 1/10 & 1/8 ON ROAD OPEN FUN RACE IN MIRI Steven @ Yap Malaysian R/C Racers 73 07-03-2009 04:28 AM
Tags
shepher max 21
