Shepherd V8 '09
#286
That's the long belt for the new pulleys. The fronts are bigger, 18/27 instead of 16/24 so you need a longer belt. Also you would want the new short side belt if running the larger front pulleys but neither are available in low friction yet. That's why a lot of people (including me) are running all the new pulleys EXCEPT for the front ones. Just slap an aluminum 16 on it and rock and roll.
#287
#288
It doesn't need to be as tight as the smaller pulleys. That is why you will also want the short side belt.
#289
is the serpent 966 clutch shoe compatible with the velox v8 clutch shoe? can it fit inside the velox clutch?
#290
Suspended
#291
I just would like to let everyone know that after 5 years of being out of the 1/8 scale races, the Velox is a very good welcome to the world of speed. I followed the setup from the advise given here and it was very stable and the speed was very impressive for me. I didnt have to change much parameters and the car handled very well for my taste. The pulleys held up well to the racing and the new pulleys will be my first upgrade.
Qualified in the B-mains and told myself it was a good return after such a long time and with a brand new spanking car.
Sometimes I think i should be tinkering with the car whole day, but the simple and unbreakable design made me focus more on the driving.
Thank you Team Shepherd for all your help in my races. I'm convinced I made the right choice for returning to 1/8 cars
Preparing for the next race...
#292
i think serpent clutches have all been 3pin. the older mugen is a 4pin should drop in. (H0773 is 4pin, H0779 is the newer 3pin) the yellow version is popular.
#293
I've done the run-in of the Velox and after almost 1hr of racing and two hours of running, i'm in the process of cleaning it. I cant help notice that there is a lot of fuel residue and oil at the back of the fuel tank where the snap pin is located. I thought it was the exhaust fumes just building up on the radio deck, but the car comes off soaked with fuel residue until the oil drips off the fuel tank. I thought the fuel tank might be leaking but i pressure tested it and there was no leaks...
I took a look at the cooling head and the glow plug area but these areas are clear of fuel and oil residue. The engine doesnt seem to have any oily leaks. If the engine is still tuned 'rich' shouldnt most of the oil be on the inside of the body and not collect at the back of the fuel tank?
Has BP taken up residence inside my car?
#294
Suspended
#295
can i seal up the fuel nipple with gasket sealer? just to secure the tap and make no more air/fuel leaks. Does this affect engine performance with a leaky fuel nipple? it just makes the car a bit messy only?
#296
Suspended
Succes!
#297
I had 2 tanks fail on that place, one was caused by crashing into a fence, one was factory defects from the first batch this cost me big time.... engine run lean blow plug costed me 2 Nova 359 Tuned!
#298
I'm so peeved. Not only did I have to tighten up the fuel nipple, there was a lot of plastic 'bits and pieces' inside the fuel nipple, so effectively it was clogged up with a lot of junk!!! I dont know how the engine still managed to get its fuel supply and still run well.
I changed the fuel nipple and secured it tight and snug and for extra security layered the edges of the fuel nipple with fuel resistant silicone. Guess I'll have to go run the velox again and see if theres any difference in performance...
#299
#300
That was me. I'm still tuning up the Velox and finding out a lot more things to improve the durability of the platform i'm using. Sad it was raining coz I really wanted to go up against the 966s, the Kyoshos and fellow Velox racers. Anyway, lets see after Raya we just get together and throw together a fun race.
