Shepherd V8 '09
#241
I'm finally done testing the different setups for my Velox in preparation for my country's first 1/8 onroad race in a looong time. I cant compare laptimes to other drivers since i'm alone but its consistently hitting the corners EVERY time. Very smooth and fast. How will it stack up against the Evolva, The mugens and the Serpents?
Wish me luck
As I was looking over the car today, I noticed the rear body posts that were attached to the rear uprights had a lot of 'play'. I know i can take out this play by using thin shims either teflon or steel. I'm wondering what effect does this have on the body and the car's performance?
I read somewhere that if the 1/8 body is too tight fitting around all 4 body posts, any crash or bump will tweak the chassis. Is this true? Does the rear body post have to be 'sloppy' or can I reinforce the front and rear body posts with graphite braces?
By the way, i'm using two types of bodies the Protoform 909 and the LOLA. I'm sticking to the LOLA as its more predictable on the straights. The 909 seems a bit 'wandering'...or maybe its just me?
Wish me luck
#242
I was having a weird problem on the straight early on. The only bump on the whole track was about 2/3rds of the way down the straight. My car always wanted to go left over this bump. It was weird as no one else seemed to be doing this but I was able to drive with it that way. After the first couple qualifiers I added a little more caster as the grip came up just a bit and the problem went away. Straight as an arrow over the bump after that.
#243
hey all, i guess i wasn't paying close enough attention, when i went to install the '09 pulley set, i found the new parts use a square section adapter. so to install the new pulley set i need to:
replace the 3 603501 with 603511 adapters.
but i don't see a '09 version for the rear adapter 603504.
is the single '09 part now used in all 4 places?
#244
oh well, now i have spare plastic parts.
#245
Suspended
I know that they are also sold seperately: 603511 There are even Light Weight versions as option.
#246
Exactly right. I ran the 909 at the Nats (very low grip) and it was fantastic. I used the Shepherd rear extenders all the way up and pretty far forward (I think it is about 20mm) and gave great steering with reasonable stability.
#247
#248
Thanks, I have a set but I think i'l experiment a bit more on the 909 and LOLA. Has anyone seen the posting for the 'loose' rear body supports? Would a 'tightly' setup rear body posts tweak the car chassis in the event of a crash?
How much of a difference do interior 'body stiffeners' do to 1/8 bodies? I can see the benefit on the exhaust side of the body, to help deflect the bashing force if you get T-boned. I'm currently only using aluminum tape and foam body rings to cushion the body. Is that enough?
#249
#250
Whats the general setting for belt tensioners? I set my rear belt to 'loose' and the front belt 'loose' but either belt does not skip. For the middle belt, how tight must i set it? I'm going to use the stock belts for the qualifiers and mains or should i swap out the belts before the mains?
Even if the mains is just 30mins long, will they be able to handle the stress? I checked my belts and pulleys, no visible sign of damage. Are belts supposed to stretch after use? I noticed that when the car was brand new, I was able to roll the chassis with ease along a flat surface. Now with some run time and bout 3hrs of testing, the car rolls along much smoother.
#251
i am finally getting around to installing the CEFX radio plate, but i have airtronics gear. has anybody been able to install an airtronics steering servo?
it seems the output shaft is too far off center of the servo body so that the horn fouls the tank. is there a secret trick that i am just not seeing?
judging from pictures Josh put up last summer, it almost looks like the output shaft is located in the forward position, but that is so far forward the link becomes very short.
thanks for any help with this.
#252
#253
#254
thanks for the offer, are you using the CEFX radio plate? if so, how long is the link you have from the horn to servo-saver?
i assume this setup all fits nicely with a ko servo, using the dimensions for a ko servo. i end up with a 22mm(center to center) long link. does this sound correct?
i am using the original shepherd servo saver and steering servo posts.
#255
Hi Mark,
I will post a pics with a dimension for you tomorrow.
Mark
