Old 02-22-2010, 10:36 AM   #136
wingracer's Avatar
Trader Rating: 24 (100%+)
Tighter tension doesn't equal longer life. I have found the lightest tension that prevents skipping gives the best life. The normal setting seems best.
Sean. Certified speed crazed mowron.
Team Shepherd USA
www.ashfordhobby.com
wingracer is offline   Reply With Quote
Old 02-22-2010, 11:45 AM   #137
wmay11's Avatar
Hey guys, I have Central bodies for my Velox, any good? Does the Euro conversion make a big diff?
RX8 - Savox - Reds Racing - Ko - Contact - Enneti
wmay11 is offline   Reply With Quote
Old 02-22-2010, 12:34 PM   #138
speedracer1bp's Avatar
Default Belt Tensioner
Hey guys, I thought I'd share an idea I came up with. I have started using the new pulleys up front, ie: 18/27 with the longer front belt, instead of the 16/24. When doing this, you'll need to use a shorter Side belt as you have to compensate for the slightly longer front belt.
I use the CEFX parts including the new belt tensioner, but instead of a regular 3mm cap screw, I put another Shepherd belt tensioner bearing assy to take up slack. Works perfect.
Shepherd doesn't have the shorter side belts yet, so this may be a permenant answer. Just thought I'd share!
Shepherd V8 '09-shepherd-tensioner-002.jpg   Shepherd V8 '09-shepherd-tensioner-001.jpg
speedracer1bp is offline   Reply With Quote
Old 02-22-2010, 01:05 PM   #139
Originally Posted by PMSorber View Post
Kronos, we always run the LF belts during competition, normal belts during training. We place the belt tentioner on normal, not on tight. The belt wear depends a lot on the track (dirt and surface). You could also grind the top of a normal belt to extend its life a bit and have an almost similar LF-effect.
Thanks for the help - Pooh2 and wingracer too!
- Kronos.
Kronos is offline   Reply With Quote
Old 02-22-2010, 01:45 PM   #140
Pooh2's Avatar
Send a message via MSN to Pooh2
- Kronos.
You're more than welcome. The Velox is a very very good car and I'm sure racers here in the U.S will see that very soon.
MUGEN MRX5/CONTACT TIRES/DESOTO RACING/TEAM LOGIC
"Since the Bible and the church are obviously mistaken in telling us where we came from, how can we trust them to tell us where we are going"?
Pooh2 is offline   Reply With Quote
Old 02-22-2010, 02:19 PM   #141
Send a message via MSN to PMSorber
Ow? I dont think this is good, sorry. You are creating a lot of drag and vibration by pushing a roller on a wobly (teeth) surface...
Just wait for some day's guy's.
@ConSult Trading
Team Shepherd, PiraniRC, Sonic and Awesomatix BENELUX
www.team-shepherd.nl
PMSorber is offline   Reply With Quote
Old 02-22-2010, 02:27 PM   #142
Wmay11,
Central on a early 2008 version, I dont know... The Euro conversion or even better the 2009 conversion make a big difference! You could also try a Zytec of Collary R10 body.
@ConSult Trading
Old 02-22-2010, 02:29 PM   #143
Default tensioner
I used to do this on my Mugens for several years. not one belt failure...
Old 02-23-2010, 01:02 AM   #144
wmay11's Avatar
Wmay11,
Hi thanks for the reply, and also is the white shoe the one to use? I am going to stick with the stock spring as it seems pretty stiff.
Old 02-23-2010, 01:14 AM   #145
The white shoe is the most agressive one available, combined with the LW fly-weights and the stock spring a verry powerfull combination. Tune your clutch carefully, you will be supprised!
@ConSult Trading
Old 02-23-2010, 07:37 AM   #146
wmay11's Avatar
I take it the LW fly weights are the ones with the centre machined out. I am starting at about 1.4mm on spring and .6 gap, does that sound about right?
Old 02-23-2010, 10:15 AM   #147
Hi Guys,
Well after a bit of a Sabatical form 1/8th , I am going to run A Velox at our 1st National event, It's the original velox hopefully our upgrade bits will arrive,before the event, any hints and tips i need to look out for?
karlfawcett is offline   Reply With Quote
Old 02-23-2010, 12:49 PM   #148
Yup.
About the 1.4mm on spring... I never do that, there is a better way...
Screw in the nut fully and unscrew between the 1,25 to 1,75 turn. Now finetune your clutch and when you have found the sweetspot, screw the nut fully in and count the rotations... Now you always know how to set your clutch.
.6 is ok with a new shoe.
@ConSult Trading
Old 02-23-2010, 12:51 PM   #149
Originally Posted by karlfawcett View Post
Hi Guys,
What do you mean with "original" Velox?
@ConSult Trading
Old 02-25-2010, 07:25 AM   #150
You all call, Shepherd Micro Racing produces:
http://www.team-shepherd.com/en/inde...d=131&Itemid=1
@ConSult Trading
1/8th scale Motonica smac Nitro On-Road 1830 01-16-2012 10:34 PM
R/C Stuff Selling Kenneth Tan Singapore R/C Racers 45728 09-09-2009 08:19 AM
TWC 1/10 & 1/8 ON ROAD OPEN FUN RACE IN MIRI Steven @ Yap Malaysian R/C Racers 73 07-03-2009 04:28 AM
Tags
shepher max 21
