Old 01-07-2004, 10:27 PM   #1
lachlan90's Avatar
Default running temps
Hi everyone
i was just wonderin if any1 noes wat the running temp 4 a os .15 cv ex engine.
thanx in advance
lachlan90 is offline   Reply With Quote
Old 01-08-2004, 09:33 PM   #2
lachlan90's Avatar
Default ANYONE
comon it s a cv-x os engine anyone??????
plz
Old 01-10-2004, 02:33 AM   #3
luketob's Avatar
i never had any experience with that engine, but i used to have .12 TR that runs really good between 240-270. Hope this helps.
luketob is offline   Reply With Quote
Old 01-10-2004, 04:46 AM   #4
MTX-3 Kid's Avatar
I ran a O.S .12 CV-X Hyper all last year, I was racin at night time with the temp at about 110 C
Hope this helps
MTX-3 Kid is offline   Reply With Quote
Old 01-13-2004, 08:50 PM   #5
MugenMTX3Kid's Avatar
Send a message via AIM to MugenMTX3Kid
Some people said to adjust until it is great in performance then check the temperature. So what i am saying is not to worry about the temp?
MugenMTX3Kid is offline   Reply With Quote
Old 01-13-2004, 09:05 PM   #6
lachlan90's Avatar
thanks everyone 4 there help!
Old 01-13-2004, 10:51 PM   #7
fmolzer's Avatar
Each engine has it's own sweetspot for performance/temps and it varies with outside conditions, but in general, if your engine operates in the 190-260 F range, you will be fine. You do not want it to run much cooler than 190 and not much hotter that 260, that said, I have had engines that only came alive if I allowed them to be at 250-280...
Good luck
fmolzer is offline   Reply With Quote
Old 01-13-2004, 11:20 PM   #8
modellor's Avatar
This is true. Each engine has different settings. For this reason I never use a temp gun. I instead listen for the noise of the engine and once I reach the sweet spot I then turn the high end back out 1/8th of a full 360deg turn.
A manufacture could give you a set temp for an engine. You then go and set the engine to run at this temp with a temp gun and the engine goes like crap.
Why?
Simple, the manufacture cant take into account the different scenarios around the world. They could be at sea level with a certain temp and humidity etc and you could be in a different weather environment all together which would require a totally different setting.
Just go with your ears and feel for how sharp the throttle control is and you will not be far wrong. Once you hit that swet spot then back the needle out so the engine isnt squealing constantly for mercy.
modellor is offline   Reply With Quote
Temps; is it really enough??? Tron 101 Radio and Electronics 2 04-15-2008 08:19 PM
Temps kcrunchone Team and Company Discussions 1 11-13-2006 07:41 PM
running too rich or running to lean bumm_off_street Nitro On-Road 7 03-29-2006 08:28 PM
TEMPS??? aus jd 2703 Electric Off-Road 14 08-29-2005 07:15 PM
O.S. RG .21 running temps?? jeffrock Electric Off-Road 23 06-30-2003 10:23 AM
