Old 01-07-2004, 06:49 PM   #1
Pressure Line Length
For any type of nitro vehicle whats the advantage of running say 12" of tank pressure line vs 6" inches ?
Is there a minimum or maximum pressure line length rule that should be followed ?
Thanks....
SteveG is offline   Reply With Quote
Old 01-07-2004, 09:54 PM   #2
afm
afm's Avatar
Default Re: Pressure Line Length
Thanks....
Steve, This is what the late Ron Paris said about it......
"Did you know the longer the fuel line coming out from the tuned pipe the leaner you can make the midrange as the engine comes up to full power?
This is caused by the delay in time it takes the fuel tank and line to reach maximum pipe pressure.
Keep in mind that this tip should be used as a fine tuning adjustment on your motor at the track.
Experiment with different lenghts, between 10 to 17 inches is normal"
Hope this helps
AFM
afm is offline   Reply With Quote
Old 01-07-2004, 10:57 PM   #3
madweazl's Avatar
10 to 17 inches was recommended for a 1/10? I usually use a quite a bit of line from the tank to the quad in the event of a rollover but never heard of using more on the pressure side. Very interesting.
madweazl is offline   Reply With Quote
Old 01-08-2004, 06:46 PM   #4
Send a message via Yahoo to hicheef
Default hold on....
As it was explained to me........and I claim to be no expert but exhaust as it leaves the cylinder is pulsed. The longer line smooths out the pulses and feeds fuel to the carb more smoothly. Something like that. 8 to 11 is good
Kevin
hicheef is offline   Reply With Quote
Old 01-08-2004, 07:01 PM   #5
MugenMTX3Kid's Avatar
Send a message via AIM to MugenMTX3Kid
i run like a 4 inch line, is that bad?
MugenMTX3Kid is offline   Reply With Quote
Old 01-08-2004, 07:08 PM   #6
Default not at all
I mean you look in the manuals for most cars and the pics show about 3 to 4 inches. This is just stuff I've been told in the pits over the years. I read it in one of the mags as well
Kevin
Old 01-08-2004, 07:18 PM   #7
sup
sup's Avatar
to sum up everything, 10 inches up is good for the pressure line. how about the tube from the gas tank to the engine, will it still be the same as the pressure line?
sup is offline   Reply With Quote
Old 01-08-2004, 07:21 PM   #8
Default No!!!
In club races you'll see guys run a longer line for a bit more fuel volume or so the motor doesn't starve in the event of a roll-over but I wouldn't go much longer than say 5"
Kevin
Old 01-08-2004, 07:23 PM   #9
Manticore's Avatar
R/C Tech Charter Subscriber
i am no expert in pressure line as well but my experience is that you need a longer back pressure line for 21 class engine but I do use a much shorter line for 12 engine. about 6 to 8 inches.
Manticore is offline   Reply With Quote
Old 01-08-2004, 07:24 PM   #10
Manticore's Avatar
Default Re: No!!!
Originally posted by hicheef
In club races you'll see guys run a longer line for a bit more fuel volume or so the motor doesn't stave in the event of a roll-over but I wouldn't go much longer than say 5"
Kevin
right, some use an additional fuel filter in between the tank and carb to extend the idling time in case of flip.
Old 01-08-2004, 07:26 PM   #11
Default yup yup
forgot that, got a shiny Great Planes one for that job. Excellent point
Old 01-08-2004, 07:28 PM   #12
Manticore's Avatar
Default Re: yup yup
oh no, you dont even forget the "bling" factor for roll over. you are getting very detailed !
Old 01-08-2004, 07:29 PM   #13
Talking hehehe
Just trying to help..............it is gold though
Old 01-08-2004, 07:30 PM   #14
Manticore's Avatar
Default Re: hehehe
that is nice. any link for a picture of it?
Old 01-08-2004, 07:32 PM   #15
Default OK OK....
Now were stretchin it.
Return fuel tubing length - how to lower pressure in tank charlesd Onroad Nitro Engine Zone 3 06-13-2008 11:32 PM
pressure line karimbs Onroad Nitro Engine Zone 3 01-03-2007 02:24 AM
whats the recommended length for the pressure line ? mrgsr Nitro On-Road 1 05-09-2005 12:42 PM
where should the pressure line go? smidge Nitro On-Road 1 12-26-2004 08:30 AM
Pressure Line.... [HPI]RS4SS Nitro On-Road 23 12-30-2002 06:57 PM
