Old 06-27-2009, 09:17 PM   #1
nib
Default ofna dm1 1/7 scale help
i need help w/ susp setup on this car its total poo in the infield(low speed tight)sections of the track but does well in the high speed sweepers the laydown shock setup is kinda complex as is the droop/bump stop/swaybar setup.anything would help at this point.the surface is a med-low grip prepped race course and is realitvly tight/low speed(10 sec laps for the tq) not much 2nd gear use, lots of on/off throttle tires are rubber. have tried foam as well and they really sucked
nib is offline   Reply With Quote
Old 06-27-2009, 09:54 PM   #2
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Please refer to this threads for help :
http://www.rctech.net/forum/nitro-ro...ased-road.html
and
http://www.rctech.net/forum/nitro-ro...-thoughts.html
Anyway, i give you my current setup for my 1/7 Ofna DM One im racing on GT Class in my country :
Chassis : OFNA DM-ONE RTR
Engine : GO Engines 7 Port .21
Pipe : GO Engines EFRA 2072
Servos : Hitec 5998 on Steering and Hitec 985MG on gas/brake
Body : Mercedes
Tire : Alpha RC Rubber Tires on Alpha RC Wheels (will be available in USA soon)
Front Shocks : Red Spring, 2.000wt diff oil with shock support on front position (harder)
Rear Shocks : Red Spring, 80wt shock oil (ultimate racing) with shock support on rear position (softer)
Front Caster : All clips rear
Front Toe : 1 (out)
Rear Toe : 3 (in)
Ride Height : 5mm front, 8mm rear
Bars : Disconnected front and rear
Hopups used : Aluminum shock plate (front and rear)
Hope this help man,
cya !
Pat
Tabushi is offline   Reply With Quote
301 Raceway in Maryland Sandra Racing Forum 13734 04-13-2017 11:24 AM
Clockwork Racing Engines DM-1 Spec Picco 28 Maximo Nitro On-Road 13 05-13-2009 11:40 PM
