Old 06-23-2009, 04:43 AM   #1
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Default Tech for fuel tank size?
What is the method most track use to tech for fuel tank size.
The roar rule book gives a couple examples but seems time consuming.
Is their a fast, accurate and efficient way to do this at a large event?
Jamie
J.Gonzalez is offline   Reply With Quote
Old 06-23-2009, 04:53 AM   #2
Riketsu's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Riketsu
Jamie
I have seen it be done at a off-road event. They just basically take your car, disconnect the fuel line from the pipe and engine. Then they plug the pipe line to a small 12V pump, and the other end to a test tube.
Riketsu is offline   Reply With Quote
Old 06-23-2009, 05:17 AM   #3
Roelof's Avatar
Send a message via ICQ to Roelof
And the best way is to set the pump on the backpressure line and pump the tank full with air, in that way no fuel will be left inside the pump
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-23-2009, 05:56 AM   #4
J.Gonzalez's Avatar
Roelof do you have a picture of this setup anywhere?
Could you draw a simple diagram?
Jamie
Old 06-23-2009, 06:01 AM   #5
M7H
M7H's Avatar
Also that way you don't really need a pump, because you can also blow out all fuel if you really want to....
Serpent
M7H is offline   Reply With Quote
Old 06-23-2009, 06:45 AM   #6
Roelof's Avatar
Jamie
I have at home. As chairman of the Dutch 1/8 section I created a compleete manual how to use all the tools we have to check the cars.
Old 06-23-2009, 07:10 AM   #7
J.Gonzalez's Avatar
Great! Please check your pm Roelof.
Go-Tech Engines Thread MassiveMods Offroad Nitro Engine Forum 15109 10-10-2017 05:01 PM
Electric 1/8th Scale conversion kits. DJ1978 Electric Off-Road 19923 06-12-2017 06:16 AM
The Big Locked Thread donitaROSE Manila Racers 89718 03-26-2015 08:17 AM
Atria Car Park Speedway tIANcI Malaysian R/C Racers 26519 12-07-2013 07:04 PM
The reason for the lack of mod drivers... robk Electric On-Road 327 06-22-2009 05:23 PM
Fantom Engine Manual = ABC Engine Bible Horatio Monster Trucks 9 02-05-2007 08:35 AM
03 Western Canadian Off Road Championships 7.5man Canadian R/C Scene 922 09-14-2003 10:22 PM
