Old 06-20-2009, 09:36 PM   #1
FastPete's Avatar
Trader Rating: 44 (100%+)
Default Axial .28 spec bad runtime
Hi,I have one of these engines.Its great except for the runtime.Cant get more than 6:30 out of it.Cant go any leaner,its in a OFNA DM1 spec.Using a 086 pipe.Kinda tough in a 15 min main.
I know some guys with the 28RR same deal 5 min.Anything I can do outside of getting a different engine.
Thanks Pete
FastPete is offline   Reply With Quote
Old 06-20-2009, 09:42 PM   #2
_Hier_'s Avatar
Trader Rating: 19 (100%+)
what size tank are you running?
125cc or 150cc?
www.hobbyplexraceway.com
-www.windcrestwinery.com-
_Hier_ is offline   Reply With Quote
Old 06-20-2009, 09:48 PM   #3
FastPete's Avatar
125cc
Is there a bigger one? My rules say has to be OFNA hop up parts.
Old 06-21-2009, 12:12 AM   #4
Jspeed's Avatar
Kyosho IGT2 comes standard with 150cc tank, run time is not an issue here.
Jspeed is offline   Reply With Quote
Old 06-22-2009, 11:46 AM   #5
CurveTracer's Avatar
Pete,
You can change pinion or spur gears. The engine will be spinning a little slower, and you will be using more of the torque of the engine.
This approach would be cheaper than purchasing a different engine.
"Yellow Jacket" Mugen MTX-6, Picco Torque
TeamNITRO RC Club, Lynwood, Illinois
CurveTracer is offline   Reply With Quote
Old 06-22-2009, 12:28 PM   #6
regg151's Avatar
Send a message via ICQ to regg151 Send a message via AIM to regg151 Send a message via Yahoo to regg151
run two large fuel filters before the engine with the insides taken out that should get you an extra min or two.
or just run longer fuel lines.
_______________________________________________________________________
Inferno GT Hyper 21 8 Port Ipanema Tires
Spektrum DX3R
Team CFX Racing, RCNB Race Team, CFX Paintworks.com
regg151 is offline   Reply With Quote
Old 06-22-2009, 12:29 PM   #7
Thanks Pete
Dude....most people consider 5 minutes the sweet spot. If you're getting 6 minutes you're well ahead of the curve but if you still want more you can try one of these:
http://www.redrc.net/2009/06/craft-r...st-gas-cooler/
.....or like the real divers learn to conserver gas with your driving techniques
Kyo83 is offline   Reply With Quote
Old 06-22-2009, 12:54 PM   #8
Roelof's Avatar
Send a message via ICQ to Roelof
You can try a Sirio 2013 pipe. With 1/8 onroad I know it can give up to 30 sec more time.
The exhaust gas cooler does not gain any time, you can give it a try with the team Orion CPD.
I believe inserts in the carb is no option but if you can create something with a smaller hole (0.5 or 1m smaller) there is again some time to gain.
Last option is driving a fuel with less nitro content, that can give a lot.
The quality of an answer comes with the quality of the question.
Roelof is offline   Reply With Quote
Old 06-22-2009, 01:01 PM   #9
Jspeed's Avatar
The Axial engine comes with 2 size carb inserts.
Taller gearing than what you've got might help along with earlier clutch lock up; no need for those 1.1 springs, the engine has enough torque anyway.
Fuel filters, longer line or putting that car on a diet might help a lot too.
Hey...... why not just "lean that s&*t out", lol
Old 06-22-2009, 09:20 PM   #10
FastPete's Avatar
Thanks guys.I might mess with the gears soon.
I went and got a OFNA force today thats the engine that comes with the DM1
Guys getting 10 min out of it.Hard to tell but it dont seem much slower if at all.
Thanks Pete
Old 06-23-2009, 04:34 AM   #11
Send a message via Yahoo to phoenix357
That force 28 is a fast engine if you take out the sleave, get a dremel and a small grinding bit . Then look at the port fangs and just make them alittle deeper. I did 3 of them and people always say that motor is sick fast, and I beat the liven crap out of them gallon after gallon.
phoenix357 is offline   Reply With Quote
Old 06-23-2009, 10:01 AM   #12
Why not? its main purpose is to increase run time.
Old 06-23-2009, 11:23 AM   #13
Roelof's Avatar
Have you tryed it and compared it ?
I have made one but I can not tell a difference but I must say the engine seems to run more constantly.
Old 06-23-2009, 03:36 PM   #14
No I have not.
I'm just going by the article that was write about it and its originator, Novarossi. In the article it clearly states that the exhaust coolers help increase runtime
I asked about the CPD on another post, cause, I was considering trying the two together
