Old 12-17-2010, 02:32 PM   #1456
Chickentrader's Avatar
Originally Posted by blis View Post
Lars. the TM Clutch bells and spur sizes have a 4mm diameter split unlike a mugen that is a 5mm. I doubt you can mesh the TM clutch to other cars. Not sure about the RS09
Clutch bells and pinions are different, and there are many variations from manufacturer to manufacturer. You need to use TM clutch bells in TM cars. We have used TM, Kyosho and Mugen clutches in our RRR; with Kyosho clutch bells (3D and 2D), and we have used a Kyosho clutch in a TM G4RS (TM clutch bell).
Clutch bells work when the O.D. of the clutch bell is similar to the O.D. of the clutch shoe. The UFO clutch seems to work the way that the boy wants it to, and has been the favourite clutch in the RRR.
I doubt that we'll play around with different clutches again, we have a new Capricorn; and the Capricorn has the best clutch that we've ever experienced (or the way that the boy wants it), so we'll now stick to Capricorn clutches.
You may wonder why we use so many clutches; and the reason is that we have a few engines that we often change. We use an O.S 12TG in one class, and O.S. 12TZs on the tight track at at Wynnum, and have used Novas at Brendale. Often we use an old engine in pre-race practice, and then change to better one before race time.
It's the wrong forum I know, but it interesting to note that Mugen clutches are bullet proof in RRR's with the bigger inside bearing that Kyosho bells use.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 12-17-2010, 09:04 PM   #1457
blis's Avatar
Kindest regards,
Lars.
Lars, what is the diameter split of a Kyosho and Capricorn clutch bell?
ie the difference in diameter of the pinions?
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 12-17-2010, 11:28 PM   #1458
Kyosho 3D and Capricorn Lab C01 clutchbells both are 26 mm O.D., and I see no reason why you for example couldn't use a Capricorn clutch in a RRR with a Kyosho 3D clutchbell. Kyosho 2D and earlier model clutches have bigger bells however. The pinions of a Capricorn are 14,15T and 19,20T, and Kyosho use different gear ratios with 15,16,17T and 20,21,22,23T pinions that are also bigger in diameter, but are close to similar in width. Capricorn 1st gear pinions have 1mm smaller dia. and 2nd. 1.8 mm smaller dia.. I tried once to use a complete UFO clutch with TM bell in the RRR; but it didn't work for some reason that I cannot remember (maybe the pinions were different or the bell was longer), but like I said, it worked very well with a Kyosho clutch bell.
Kindest regards,
Lars.
Old 12-19-2010, 07:08 AM   #1459
Default setup sheet
Hiya..
Newbie to the car, hence went to TM site to look for other people setup sheets, only one i could found was the default setup. Maybe i am at the wrong site !! Please someone paste me the link.
xtreme888 is offline   Reply With Quote
Old 12-19-2010, 07:56 AM   #1460
blis's Avatar
Originally Posted by xtreme888 View Post
Hiya..
Look back a few pages, Impalabob has a lot of setups posted, likely to be better than those on TM site as well.
Enjoy.
Old 12-19-2010, 02:03 PM   #1461
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Setups
Thanks[/QUOTE]
What type of track do you run on maybe we can help you just lets us know thanks.
Bobby
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 12-19-2010, 04:25 PM   #1462
Here something on E-bay that may interest you Harry: http://cgi.ebay.com/Capricorn-1-10-G...6#ht_531wt_905
Kindest regards,
Lars.
Old 12-19-2010, 04:55 PM   #1463
What type of track do you run on maybe we can help you just lets know thanks.
Bobby[/QUOTE]
Hiya....
The track is techical but with a medium straight of about 4 secs
Going to try setup as in manual but with 1000 cst (45ish Wt) xceed shock oil in Kfactory shocks with white springs all round.
Normally run 1/8th onroad...hence wondering would the TM car be quicker with :
front one way and rear diff
solid front and rear diff
front one way and solid axle ?
.....not able to try car out as whole of uk is covered in white stuff...lol!!!
Old 12-19-2010, 06:41 PM   #1464
Default Setup
Bobby
Hiya....
.....not able to try car out as whole of uk is covered in white stuff...lol!!![/QUOTE]
I would try a solid axle setup for a tech track ,you would want to accel from corner to corner, i which i think the solid up front would help,try the Protoform P37 body .
RoninRc.com
Basher BT-4
Old 12-21-2010, 03:50 PM   #1465
blis's Avatar
Kindest regards,
Lars.
Only lately have I had problems with RED clutch shoes, nothing wrong with the UFO2's I use. And where would one get the pinions as the new bells use fixed 2nd gear
Old 12-21-2010, 05:06 PM   #1466
NitoriousRC's Avatar
Just thought id share some pictures of my new ride~
I wanted to use the team magic colours for the new rig, and this is what i came up with ...I was nearly going to paint a wizard on the roof, but maybe next time~
NitoriousRC is offline   Reply With Quote
Old 12-21-2010, 07:50 PM   #1467
abi
Default Spring rates.
Hi guys,
What spring rate did we work out the stock whites were? I,m thinking they are about 28 to 31LB/in. I did the test a year ago but I've forgotten the results!
What would be a good starting point for a bumpy track? 25LB?
Team Magic tragic. G4S RTR, G4S, G4S+Evo, 3 x RS09's.
OS Speed, Spektrum.
abi is offline   Reply With Quote
Old 12-22-2010, 05:27 AM   #1468
Originally Posted by R.Gilletti View Post
Dario has a contract with Team Magic for all 2011 season.
He will race for sure with TM in the next season.
Greetings from Italy!
Ciao
I think not
jelayne is offline   Reply With Quote
Old 12-22-2010, 02:59 PM   #1469
blis's Avatar
Default Only Jokin Luis!
Originally Posted by jelayne View Post
I think not
Nah, that's not Dario I think its SP Racer having lost a few kilos and had some eyebrow work...
Only jokin!
TM better hurry up with an LE release, everyone's jumping ship!
Old 12-22-2010, 06:10 PM   #1470
R.Gilletti's Avatar
Send a message via MSN to R.Gilletti Send a message via Skype™ to R.Gilletti
also the best "love story" sometimes ends...
like Valentino Rossi and Yamaha, like Michael Schumacher and Ferrari, also Dario and Team Magic...
Dario had a contract for 2011 with TM, but, was a common choice switch to KM for 2011/2012.
now I'm in Taiwan and I'm working with TM R&D Crew to design and test the new Team Magic's weapon for 2011 season....
we hope to show the proto car at the Nuremberg Toy fair!
Stay Tuned!
Raimondo Gilletti
Production Director @Matrix Racing Tires
R.Gilletti is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
