Old 11-18-2010, 10:00 PM   #1426
rocca30's Avatar
Originally Posted by impalabob64 View Post
Hey guys if you check out the Sedan im the only TM G4RS 09 out of 39 sedans wish me luck.
good luck bobby you had your dialed just put the hammer down.
RC AMERICA / / HUDY // SRC / / JC JEWELERS/ / GOT GOLD // MAXX POWER // EXTREME RACING FUEL //
rocca30 is offline   Reply With Quote
Old 11-20-2010, 05:50 AM   #1427
NitoriousRC's Avatar
Smash them Bob, well not lieterally but all the best man!
Having some setup isses withe the new car, trying to get the two speed to kick in.
Just looking at it hurts my head. What is the purpose of those lil round weights and the grub screws above them??
Any idea on a base setting for these and for the big hex bolts in it??
Also whilst skimming some pages i have read of an understeery problem that ine seems to have a bit of, just wondering how to settle that?
NitoriousRC is offline   Reply With Quote
Old 11-20-2010, 07:47 PM   #1428
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Thanks Man
Working on the car right now, getting ready for the Triple A mains Sunday.As far as 2spd did you build like it shows in the manuel .
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 11-21-2010, 05:52 AM   #1429
roach's Avatar
Send a message via Yahoo to roach
Thumbs up A main
Nice position!..bob GOOD LUCK TODAY!
Team Magic/ hy-brid composites/black project racing.
roach is offline   Reply With Quote
Old 11-21-2010, 03:02 PM   #1430
Took my car out for it's first race meet yesterday..
Started to get the two speed sorted after I had it kicking in way too early .... like straight away.
My run with it was cut short after the throttle servo died.
The Ninja motor in my Kyosho V1RR then died in the first main.
I then spent a frantic 20 minutes trying to put a new servo in the G4RS09 in ready for the last race.
I think i just missed out on getting it out there for the last lap!
Ended up having a few runs with it and then wound the 2 speed shoes in tighter until the thread was nearly flush with the end, and got it changing gears.
It has a Sririo 12 T3 Evo4 in it, and it was going really well, and was a pleasure to drive compared to the Kyosho.
The two speed shift seemed really smooth, im used to hearing a big change when it licks into second with the revs dropping and building again but this seemed to just go smoother .. hard to explain.
I think it has the standard gearing on it, and i am now wondering aboput changing it to suit the small track.
Our track only has a straight about 100ft long.
Old 11-21-2010, 03:37 PM   #1431
Default Small Track Gearing
16/64 22/58 this make the car super quick from corner to corner also depends on your motor.Try this as you starting point.
RoninRc.com
Basher BT-4
Old 11-21-2010, 04:23 PM   #1432
roach's Avatar
Thumbs up con-grats bob
first GREAT RACING bob...although you you missed the last main.. you did an awsome job racing some of the best racers around. im gonna guess your motor craped out on ya. but hey you have the winter nats to look forward to.
and nitroious my home track @ jackson is a smaller techincal track, and maybe the stright is 60ft i use 16/50 21/48 it shifts about 10-12 ft in to the stright and screams down the stright away...you might also try something like that...and have good breaks too!.
Old 11-22-2010, 02:10 AM   #1433
flynia's Avatar
I have this happen with mine... you don't really hear the drop when the gear change happens... but it does happen and it certainly gives that big kick of speed when it does happen.
I didn't get the chance to take mine out this past weekend as I spent most of the day with the wife... I will definately be rocking it on the 5th December when the final race meet for the year comes together.
I also have my final order of K Factory Parts set and now just have to put the order in for them. I don't know however if I could be bothered ordering the Metal Gears however as I think that the Plasticy ones tend to have a little more "Give" in them when it comes to rocks and crap getting lodged.
Congrats to all the racers that gave it a good go and won or ranked well over the weekend
Team Magic G4RS 2009 / K Factory K1007-3 Body Shell
RB T10-RC Engine and EFRA 2659 Pipe Set
Hitec Servos - HS-7775MG (Throttle) and HS-7965MG (Steering)
LRP LiPo RX PACK AAA HUMP 1700 RX 7.4v with MuchMore MRG-5A Regulator
KO PROPO EX-10 EURUS Transmitter with KR-407S Receiver
flynia is offline   Reply With Quote
Old 11-22-2010, 07:13 AM   #1434
Default Thanks
Motor was perfect battery failed in the warmup car destroyed,it took off on back straight full throttle. I will posted the solid axle setup i found to be on the money .
RoninRc.com
Basher BT-4
Old 11-22-2010, 07:58 AM   #1435
roach's Avatar
Default oh! no!
battery...oh man that sux.
Old 11-22-2010, 01:28 PM   #1436
td-civ's Avatar
Trader Rating: 18 (95%+)
o man that sucks that is the main thing why i run life pack no ubec and its a clean 6.6 volts and is very light
here is a link of my car with savox servo's on my life pack that is make
http://www.youtube.com/watch?v=iUFdS0A-_Lg
there 1600mah 6.6 volt pack
td-civ is offline   Reply With Quote
Old 11-22-2010, 06:30 PM   #1437
Default US Open setup
Front Susp
Track Width-200mm
Anti Rollbar: 0
Solid Axle
Toe: +1
Camber -2L&R
Rideheight-6mm
FrontDroop-1mm
Caster-3mm
Tires- 40s Contact Carbons
Dia-60mm L&R
Rollcenter-2mm shims
Shocks
Oils- 500wt Capricorn
Piston- 2hole 1.1mm
Springs- Kyosho Light Blues
Ackerman-B
Rear Sus
Track Width -200mm
Antiroll bar-Flat
Diff-80,000 Xray
Rear Toe: -3
Camber:-5L&R
Tire;40s Contact carbons
62mm
Rollcenter -0
Shocks
Oil-500wt Capricorn
Piston-2hole 1.1mm
Springs-Kyosho LightBlues
For my rear uprights i have them in the lower hole in,an the rear hub i have it shimmed at 4mm.
RoninRc.com
Basher BT-4
Old 11-25-2010, 02:23 PM   #1438
blis's Avatar
Impala.. could it be that you use a reverse throttle and didnt re-calibrate so that the fail safe attempted to brake and it was full throttle instead?
We had some fun on the weekend too..
http://www.youtube.com/user/therealblis?feature=mhum
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 11-25-2010, 09:16 PM   #1439
Trader Rating: 13 (93%+)
Brendale in reverse looks wicked
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 11-27-2010, 03:38 PM   #1440
Tabushi's Avatar
Send a message via AIM to Tabushi Send a message via Yahoo to Tabushi
Guys,
Any of you tested already GQ Tires on your G4RS09's ? ... im trying to look if normal tires will fit or do i have to buy 2mm offset ones,
thanks
Patricio "PATO" Concha
E-Mail : [email protected]
Facebook : http://www.facebook.com/patoconcha
Whatsapp : +56 9 66165085
Tabushi is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
