Old 09-11-2010, 02:33 AM   #1321
bobbyblaze's Avatar
Send a message via Yahoo to bobbyblaze
I'm looking to get this car and i notice the shocks not threaded is there an upgrage?
Arrma Nero 6s, Ofna DM-1 Pro
Traxxas Revo 3.3, Traxxas T-Maxx 3.3, Traxxas Jato 3.3
Traxxas Slash Platinum, Traxxas Slash 2WD
Bend The Rules--Rule The Bends
bobbyblaze is offline   Reply With Quote
Old 09-11-2010, 03:40 AM   #1322
Chickentrader's Avatar
All genuine G4RS Shockies have threaded ride height adjustments.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 09-11-2010, 07:29 AM   #1323
bobbyblaze's Avatar
Kindest regards,
Lars.
thanks for the info
Old 09-12-2010, 08:00 PM   #1324
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Great weekend
First staterace had a good weekend ,only problem battery dumped thats was the only issue, but overall the car was at its best this weekend at Homestead track in Miami will post setup later.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 09-13-2010, 03:02 AM   #1325
blis's Avatar
Impala, are you using the TM AAA packs or do u use an alternative?
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-13-2010, 11:53 AM   #1326
Default Battery
TM AAA i need to find an alternative though, im going to see if i can use the normal 5 cell pack but have to make it so it mounts under the gas tank an flat on the chassie will keep you posted.
RoninRc.com
Basher BT-4
Old 09-13-2010, 03:17 PM   #1327
blis's Avatar
When making up my own cells, I slip short lengths of heat shrink over each end of the batteries to prevent grounds touching each other. It spaces each cell apart slightly and is more durable than the harder shrink that TM uses.
Old 09-13-2010, 03:56 PM   #1328
Default Will do
Thank for that tip
RoninRc.com
Basher BT-4
Old 09-13-2010, 04:16 PM   #1329
GMartinez's Avatar
Trader Rating: 85 (100%+)
Bobby your car was on point & driving as well good luck at the next race
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Old 09-14-2010, 03:54 AM   #1330
Doug M's Avatar
Default Novarossi Challenge @ Homestead Super Raceway
Doug M is offline   Reply With Quote
Old 09-14-2010, 08:47 PM   #1331
Default Homestead Setup
Front Susp
Track Width-198mm
Anti-Roll Bar-0 (K14213)
Diff- 300,000 X-Ray
Front Toe - 1
Camber L2-R2
Front Ride Height-5mm
Front Droop- 1mm
Caster 3mm
Tire -ContactTires 37L-37R
Shocks Kyosho (1/8th short shock bodies)
Oil -600 wt kyosho
Piston -2hole 1.1mm
Spring -Serpent Red (old version)
Ackermann-B
Rear Susp
Track Width-199mm
Anti Rollbar-0(k14231)
Diff 80,000-X-Ray
toe 2.5mm
Camber 5.0L-4.5R
RideHeight-6mm
Droop 4mm
Tire-ContactTires-40L-40R
Shocks Kyosho (1/8th Long shock bodies)
Oil-600wt kyosho
Piston-2hole 1.1mm
Spring X-Ray DarkBlues
Optional parts i ran on the car.
Ceramic bearings
k14220
k14219
k14243
k14234
k14239
k14240
k14257
K14200
k14212
k14201
k14228
Titanium Hinge pins
Lightweight Middle Shaft
Lightweight Diff outdrives Front&Rear
Lightweight Bevel gear shafts for the diffs
Lightweight pulleys only used the 19t pulleys only.
RoninRc.com
Basher BT-4
Old 09-16-2010, 03:22 PM   #1332
Default Almost forgot
Front Susp
Track Width-198mm
Diff- 300,000 X-Ray
Front Toe - 1
Camber L2-R2
Front Droop- 1mm
Caster 3mm
Oil -600 wt kyosho
Piston -2hole 1.1mm
Ackermann-B
Rear Susp
Track Width-199mm
Diff 80,000-X-Ray
toe 2.5mm
Camber 5.0L-4.5R
RideHeight-6mm
Droop 4mm
Oil-600wt kyosho
Piston-2hole 1.1mm
Ceramic bearings
k14220
k14219
k14243
k14234
k14239
k14240
k14257
K14200
k14212
k14201
k14228
Titanium Hinge pins
Engine-MM RbM3/w INS box
Pipe-Nova 2530
Header-Nova short
Gearing-17/62 23/58
Fuel-J-Tech 16%
For qualifying i ran 32shore Contact tires front,an 37s on the rear
Body-Stratus 3.1
RoninRc.com
Basher BT-4
Old 09-17-2010, 08:01 AM   #1333
Suspended
rcpaintinpete's Avatar
Trader Rating: 16 (100%+)
Default bodie pic
Pipe-Nova 2530
Header-Nova short
Gearing-17/62 23/58
Fuel-J-Tech 16%
Body-Stratus 3.1
MR WATSON I NEED A PIC OF THE LAST BODIE ON THE CAR
TEAM ARC USA --- TEAM POWERS USA ---- TEAM VALKARIA RC ----
rcpaintinpete is offline   Reply With Quote
Old 09-18-2010, 03:32 AM   #1334
flynia's Avatar
With a lot of help from my mates at the LHS here in Canberra I have finally got around to getting the new Motor into my G4RS 09.
She is now good to go and "Run In" (Thanks Team at Stryke RC here in Canberra)
Hope you all like and enjoy and I'll keep you posted on how it goes!
Team Magic G4RS 2009 / K Factory K1007-3 Body Shell
RB T10-RC Engine and EFRA 2659 Pipe Set
Hitec Servos - HS-7775MG (Throttle) and HS-7965MG (Steering)
LRP LiPo RX PACK AAA HUMP 1700 RX 7.4v with MuchMore MRG-5A Regulator
KO PROPO EX-10 EURUS Transmitter with KR-407S Receiver
flynia is offline   Reply With Quote
Old 09-18-2010, 04:10 AM   #1335
u can do it... think about it...
premeet01245 is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
