Old 05-24-2010, 08:54 PM   #1231
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Region 4 setup
Front Sus
Track Width-198mm
Rollbar-flat
Diff-300,000-Xray
Toe-+1
Front Camber-2.0L-1.5R
RideH-4.5mm
Droop-2mm
Caster-3mm
Tire
40L&R(TwisterProLights Serpent style)
60.5mmL-60mmR
Shockoil 600wt kyosho
piston 2hole 1.1mm
spring-Serpent Blue(New Version)
Ackm-B
Rear Sus
Track Width-200mm
Anti-Rollbar-2.2
Diff-100,000
Toe-2.5 in
Camber 4L-3.5R
RideH-5mm
Droop 4mm
Tire
42L&R(TwisterProLights)
62.5mmL-62mmR
Shockoil 600wt Kyosho
piston-2hole -1.1mm
Spring-Serpent Red(New Version)
Wheelbase-258mm
Body-Chevy Kruzer
Note:Shocks layed all the way down F&R,
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 05-24-2010, 09:14 PM   #1232
Default Pics
Here are some pics
Team Magic G4RS 2009-dsc_0173.jpg   Team Magic G4RS 2009-dsc_0180.jpg   Team Magic G4RS 2009-dsc_0189.jpg
RoninRc.com
Basher BT-4
Old 06-02-2010, 03:24 PM   #1233
Default How is everyone
Havent heard any new tips or tricks in awhile ,our first Forgass race is in Sept so, i just taking alittle break myself.But for those who ask about the lightweight pulleys also i will be testing the front wire bar an some other kfactory goodies will keep you guys updated.
RoninRc.com
Basher BT-4
Old 06-04-2010, 07:34 AM   #1234
abi
Hi Bobby,
Did you happen to throw the pulleys on a scale? Wondering if they are heavier than the kit ones. looking at images of them they do look pretty heavy unless some whittling has been done to the back sides of them.
On a different topic, I see K Factory have 2 different front lower hinge pin mounts, one I recall is K14202 and the other is K14212. What exactly is the difference between these two mounts, looks to be the rear alloy mount?
Do you know anything about the TM lower front wishbone revision, P/N504134?
I got so many Q's re these cars and the recent option releases, will keep em comming if thats OK with you?
abi is offline   Reply With Quote
Old 06-04-2010, 03:40 PM   #1235
Default No problem anytime
Originally Posted by abi View Post
Hi Bobby,
Ok on p/n 14202-you can adjust your roll center by raising the bulkhead an adding shims,also the rear can be done the same way.I havent tested the rollcenter changes yet but, with all the new tracks popping up here in Florida i need to, tracks are getting super smooth, an crazy traction our last state race, i was running 55mm front 57mm rears really low tire wear.
For p/n k14212 this is an upgrade i recommend alot stronger than stock .
For the p/n 504134 i will have to get back with you on that.
RoninRc.com
Basher BT-4
Old 06-06-2010, 10:52 AM   #1236
MACHINARIA's Avatar
Stop spamming the threads
RC Fanatic
I need your help to build an On-Road Track in Virginia USA.
www.machinaria.com
MACHINARIA is offline   Reply With Quote
Old 06-11-2010, 05:22 PM   #1237
flynia's Avatar
Back on topic!
So far I have:
K5702H - K Factory G4RS 09 Alum. Heavy Duty Servo Arm (Hitech)
These had to be ordered due to me having purchased the Hitech 7965 Servos before the Kit arrived (yes I know... silly me... last time I do that). These are VERY NICE Servo Horns and if you dont have a pair to match your Servos i highly recommended them... K Factory do make ones for Futaba and KO as well.
As for upgrades for next fortnight I have decided to go with the following for starters at this point:
K14219 - K Factory G4RS 09 ST Steel Rear Universal Joint Set
K14220 - K Factory G4RS 09 ST Steel Front Universal Joint Set
K14201 - K Factory G4RS 09 Alum. 7075 Front Upper Hinge Pin Mount
K14241 - K Factory G4RS 09 Carbon Transponder Holder (L-Shape)
K14228 - K Factory G4RS 09 Lightweight Alum. Middle Belt Mount
K14210 - K Factory G4RS 09 Light Weight Alum Front Solid Axle Set
K14200 - K Factory G4RS 09 Alum. 7075 Rear Lower Hinge Pin Mount
Thats just for starters and will be ordered next week from rc-mushroom.com as they are fairly well priced and I have had lots of orders from them before without issue
Thanks for the suggestions all and appreciate the tips!
Team Magic G4RS 2009 / K Factory K1007-3 Body Shell
RB T10-RC Engine and EFRA 2659 Pipe Set
Hitec Servos - HS-7775MG (Throttle) and HS-7965MG (Steering)
LRP LiPo RX PACK AAA HUMP 1700 RX 7.4v with MuchMore MRG-5A Regulator
KO PROPO EX-10 EURUS Transmitter with KR-407S Receiver
flynia is offline   Reply With Quote
Old 06-13-2010, 08:42 AM   #1238
abi
Nice options flynia, did you happen to weigh the K14228?
What advantages are you seeing with K14219 and K14220?
I have most of the other options on your list and find them good.
Old 06-14-2010, 06:28 AM   #1239
Default Anna
You got email
RoninRc.com
Basher BT-4
Old 06-14-2010, 09:37 PM   #1240
PrimeAKF11's Avatar
Guys,
What kind of springs are you using on your G4RS 09? I race on a low to med grip asphalt track and I think the stock springs are just way too stiff.
I have my electric TC dialed for the track but not so much luck with my nitro. If anyone here races at a track with similar bite, I'd really appreciate it if you could post your settings.
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 06-15-2010, 05:55 AM   #1241
Default Springs
Originally Posted by PrimeAKF11 View Post
Guys,
You can use the Xray springs or Kyosho spring they work really well for low to med bite try Kyosho lightblues or X-rays Darkblues.
RoninRc.com
Basher BT-4
Old 06-27-2010, 05:28 PM   #1242
Default G4RS 09 takes TQ
Had a clubrace this weekend set new TQ 1 second over an X-Ray NT,it was the G4RS 09 an the Nt battling for the first 10min, i lead the race then my battery started dumping,but i put enough laps to secure a 3rd place podium.Will post setup later.
RoninRc.com
Basher BT-4
Old 06-28-2010, 01:47 AM   #1243
blis's Avatar
Default TQ... Nice.:)
Well done for TQ, but what do you mean a new one? fastest lap too?
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 06-30-2010, 12:23 PM   #1244
revo7617's Avatar
Hi guys, Im distributing Team Magic in Mexico, basically Offroad, but we are trying to carry Onroad too..
Does anyone can tell me what parts break the most or need constant replacement? so I may order those for stock?
Thanks.
Juan Gonzalez.
Chihuahuarc.com
Mugen MBX6 / Werks B5 / Futaba
Mugen MBX6T / Werks B5 / Futaba
revo7617 is offline   Reply With Quote
Old 06-30-2010, 01:33 PM   #1245
Chickentrader's Avatar
Thanks.
What comes to mind of what you need to carry is: spurs, pinions, belts, one way hubs, pulley sets, clutch shoes & weights, clutch bearings and 2 speed clutches & housings for drive trains. For the body you would need front & rear arms, front & rear uprights, shock towers, turnbuckles (steering & rear) bulkheads, battery packs and radio plate support brackets. Things like bearing kits, chassis plates. pins for the arms, plastic parts etc. will also be needed eventually.
Peter Lee at http://www.rcmanufactory.com/prod.php?cat=Team%20Magic is very reliable.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
