Old 04-18-2010, 10:12 PM   #1201
Trader Rating: 24 (100%+)
get some k factory upgrades
you can get them at www.machinaria.com
RANDY SMOOTH is offline   Reply With Quote
Old 04-19-2010, 05:38 AM   #1202
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Kfactory Goodies
Originally Posted by flynia View Post
Good News,
Managed to get my G4RS 09 around 70% or so complete... Have the Front and Rear on the Car itself and set... at this point I am up to around Step 15 or so and just need the Servos and the like to get this up and running properly.
Will be taking it up to the Local Hobby Store on Thurs/Friday just to ensure that the build is nice and perfect as this is the first kit i have built. At this point it has been a lot of fun and cant wait to see what it will be like when its done.
I will be running the following gear:
RB Concept R3 V12
K Factory 6001 Missile Pipe
6v-1100mah Ni-MH Lightweight Rectangle Receiver Pack
Hitec HS-7965MG Servos
KO Propo KR-407S Receiver
KO Propo EX5-UR Transmitter
Any thoughts or options I should invest in folks?
Here is what i have on my car.
K14243
k14201
k14200-you need this part
k14212
k14257
k14206
k14228
k14227
k14224
k14223
k14239
k14240
k14234
k14219
i also ran the lightweight spur gears, i would also give them a try.I also found a lipo the fits perfect an cost my $25.00, 800 mah i also installed a regulater.Later i will getting the lightweight pullies my goal is to make the drivetrain as light as possible.Give Anna a call at Machinaria she give all the help you need.
Best Rgards
Bobby Watson
Here is my car in action i passed that car coming down a 300ft straightaway.The body is RN5 from Protoform.My engine MurnanModified RB M3 major Hp motor.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 04-19-2010, 09:18 AM   #1203
aizenbelle's Avatar
k14200 it's a must
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 04-20-2010, 10:31 PM   #1204
abi
Default RS09 K Factory Lola conversion.
This upgrade looks impressive for outlaw classes, anyone use it?
Seems to have a locked rear diff as well as body downforce applied to the hubs direct as per 1/8 scale.
What would be a good high downforce body to take advantage of this feature?
Edit - Took another look at the web page, P/N K14310.
Definitely a spool rear diff complete with diff gear, upper arm pivot assy's, bulkheads etc. Front and rear wheels wider and looks to suit a 235mm body.
abi is offline   Reply With Quote
Old 04-20-2010, 10:33 PM   #1205
abi
Default K Factory hard anodised pulleys.
Has anyone weighed these and compared to the stock plastic, heavier, lighter?
Old 04-20-2010, 10:38 PM   #1206
abi
Default RS09 arm revision and now K Factory versions too.
I noticed on the TM site a revised part number for some of the arms, also noticed on the K Factory site P/N;s for arms.
So what do we know about these parts? Different material or different mouldings? Any testing been done and what are the advantages?
Any feedback welcome, seems the TM product releases are made with very little fanfare sometimes
Edit - TM front lower arm P/N revised from 504082 to 504134.
K Factory front lower arm P/N K14262
K Factory front upper arm P/N K14261
K Factory rear lower arm P/N K14263
Old 04-21-2010, 01:43 PM   #1207
Default Homestead Miami Track setup
Surface-Smooth/ Bumpy
Size-Open
Traction-Med
Front Susp
Track Width-199mm
Anti-Rollbar-0
Diff-300,000(X-ray)
Toe-1+
Camber-2.0L/1.5R
RideHeight -5.5mm
Droop-2.5mm
Caster-3mm
Tires
Manu-Matrix
Shore 37L-37R
Dia-59mm L/R
Shocks
Oil -600wt Kyosho
Piston-2hole 1.1mm
Spring-Serpent Blue (new version)
Ackerman-A(B is also a good option didnt get a chance to try though)
Rear Susp
Track Width-200mm
Anti-Roll Bar-stock
Diff-80,000-(x-ray)
Toe-2.5mm
Camber-3.5L/3.0R
Droop-4mm
Tires
Manu-Matrix
Shore-40L/40R
Dia-61.5L/61.R
Shocks
Oil-600Kyosho
Piston-2hole 1.1mm
Spring-Serpent Red(new version)
Gearing
17/23
62/57
Engine
MM RB M3
Fuel 16% Byrons
Body-Rn5(ProtoForm)
Note(for the front roller center i added the 2mm shim,the rear i left stock ,i also dropped the rear uprights to the lowest hole on the inside.Laid shocks all the way down.
RoninRc.com
Basher BT-4
Old 04-29-2010, 01:33 PM   #1208
Originally Posted by sammies View Post
Thanks Bundy and Lars for the replies... will replace them with longer screws to see how it goes.
Another question... anyone has the problem of the rear tyres wearing out at a higher rate than the front ones?
Ive noticed that too... So Im using harder tyres in the rear. 37/40 or 37/42 in some tracks.
[]s
R.Takeda
takeda is offline   Reply With Quote
Old 04-29-2010, 03:18 PM   #1209
Default ?
[]s
R.Takeda
Are you running the 2mm split,also are you using the diff up front,or the solid. If you have to run 37/42, sounds like your car maybe having a pushing problem or the track has really high tire wear.Also droop settings maybe alittle off.I run 35/37,37/40,40/42 an if traction really low maybe 32/35 an thats a big maybe on the 32/35.Can you post your setup maybe i can help.
RoninRc.com
Basher BT-4
Old 05-02-2010, 02:18 AM   #1210
abi
Hi,
What typically would you run as a set-up when traction is real low using the 32/35?
Old 05-02-2010, 07:00 PM   #1211
Default Low traction
Originally Posted by abi View Post
Hi,
I would start with the out the box setup first, then make small changes one thing at time,until you get the car to where you like it.Try diff springs & shock oils first..
RoninRc.com
Basher BT-4
Old 05-07-2010, 09:44 AM   #1212
abi
Thanks Bobby, I tried the 'out of the box' set-up at the begining of our most recent champoinship round and found it very good but too stiff in the springs and shock oils. Its now been 13 rounds and 26 races in total and I have changed and tweaked a lot of the car over that time and finally came up with the overall championship win, my best result in this class.
Have you recieved the hard anodised pulleys yet, what do you think of them?
How is the weight compared to the nylon ones?
Old 05-07-2010, 09:52 AM   #1213
abi
Default Just wondering if anyone has tested any of the new parts released recently?
Has anyone got hold of any of the new suspension arms, pulleys, 2 speed clutches etc?
TM have a revised front lower arm and k Factory have full set of front upper, lower and rear lower.
Also available is a TM front swaybar in 1.0mm (Kit style not the K Factory type)
TM have what looks like a kit type nylon pulley set with zero overdrive compared to the kit 4.xx% overdrive.
As mentioned a TM revised 2 speed clutch shoe set
Any test data or personal thoughts appreciated.
Old 05-07-2010, 11:32 AM   #1214
Im running 1mm split... Cause with 2mm split my car understeer a lot!!!.
My setup is:
Surface-Smooth
Size-Open
Traction-High
Front Susp
Track Width-199mm
Anti-Rollbar-0
Diff-200.000 (Xceed)
Toe-1+
Camber-1.5L/1.0R
RideHeight -5.5mm
Droop-2.0mm
Caster-3mm
Tires
Manu-Matrix
Shore 37L-37R
Dia-60mm L/R
Shocks (Mugen)
Oil -450
Piston-(standart)
Spring-1.6 TM
Ackerman-D (but the car overteer in the middle of turn - off power)
I didnt have time to test another position...
Rear Susp
Track Width-200mm
Anti-Roll Bar-stock
Diff-50,000 TM
Toe-3.0mm
Camber-3.5L/4.0R
Droop-4mm
Tires
Manu-Matrix
Shore-40L/40R
Dia-61.0L/61.0R
Shocks (Mugen)
Oil-450
Piston-(std)
Spring-1.7mm TM
Gearing
16/22
62/56
Engine
Nova 353 Flaxh
Fuel 20% Byrons
Body-A5 (Xceed)
Old 05-07-2010, 11:41 AM   #1215
Another problem that I have in the last national round was the clutch bell touching the 2nd speed housing...
This has happened to you?
[]s
R.Takeda
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
FWR Racing Season FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
