Team Magic G4RS 2009
#1156
Front Downstops
Hi
I have been doing a little more work on my G4RS 09 tonight and still can not for the life of me work out how the front downstops work on the car.
The instruction manual shows a grub screw in the lower arm, but it does not touch the chassis like it does on the rear off the car. The old G4RS had it in the front bulkheads resting against the swaybar mounts... Maybe i have missed something!
Thanks in advance...
Andrew
Andrew
#1157
Hi
Andrew
Andrew
#1158
Hi
Andrew
Andrew
They sit against a small tab that protrudes from the suspension arm a little.
I found the supplied screws to be a little short and replaced them with 8mm ones.
Have another look.
#1159
Playing at bayside this weekend?
Hi
Andrew
Andrew
Bundy, Lars mentioned that the droop grub screws were a little short... Down stops from pics seem to be from underneath stopping against sway bars?
If you are running at Bayside this weekend, then downstops might be a good idea. From experience the downstops grubs need a lot of loctite or better still replace them with a long round head screw and use Shims to set them.
Bayside is extremely rippled and sway bars tend to disrupt the cornering, many stand up their shocks, remove sways and run really soft. To get an idea of how soft, I helped out Ray Griffiths from Sunny Coast (his down stops had screwed themselves in too far and locked the suspension) and he was running pink fronts and lime rears. These soft srpings would require downstops unless you want to run considerably higher ride height 8-10mm otherwise in a longer race you'll find yourself bottoming out.
Also used 1.5mm drilled out pistons in my shocks to get improve shock absorption.
#1160
Attachment 572249
Attachment 572249
Sorry for the late reply i am away from home at the moment, appreciate the assistence...
I got it sorted, they are indeed on the bulkheads and you can get to them from the top, but Lars is correct and the screws are too short to touch anything.
The manual for the car is so shit... it doesn't explain anything like with previous Team Magic cars i have!
#1161
Steering linkage!
WTF Team Magic!
Why does the manual not tell you how long to make the tie rod for the steering linkages.
Does anyone have any suggestions? At the moment it is pushing the rack up and the top deck is sitting high as a result.
Hoped to get it finished this weekend!
Thanks again
Andrew
Thanks again
Andrew
#1162
Hey
WTF Team Magic!
Thanks again
Andrew
Thanks again
Andrew
Bobby Watson
#1163
WTF Team Magic!
Thanks again
Andrew
Thanks again
Andrew
#1164
Just out of curiousity I downloaded the manual for the G4rs from Team magic. In the middle of the book, right when it tells you to open bag 15 there is a shot of the front turnbuckles. Says that it between the ball ends there should be 33.5mm of room. Try that out and see if its right. I dont have the car but hope that gets you close.
#1166
#1167
Purchased mine on Monday night from Wolf Hobbies.
Can't wait for it to get here as I am looking forward to building!
So far I have the following for it:
RB Concept R3 V12
KO Propo KR-407S Mini Sized Reciever
K Factory K6001 Missile Pipe (Thanks Lars from Chickentrading)
RB Concept R3 V12
