Old 02-28-2010, 05:56 PM   #1126
ALG
Default Team Magic PERU
Hi TM Family,
We had an invitational race here on Peru, with people from Argentina (RINALLDI), Ecuador(CUCALON) and USA (Morganti)
TM had a great race making 2,3,4 on the Amain, yes Paolo won with the Serpente IoI but TM RS09 made a great race putting ALL 4 cars on the A MAIN.
My car was on rails all the week, I just can say that TM has a very good car!
hope to make this race bigger a see more people here to have a great time and eat the best food!!!
Have fun
Andy Ledgard
ALG is offline   Reply With Quote
Old 02-28-2010, 06:05 PM   #1127
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Great News
Originally Posted by ALG View Post
Hi TM Family,
Have fun
Andy Ledgard
Hey good showing for the TM G4RS09 2,3,4 good to hear. I would like to make it out to your next big race keep me posted.
Best Regards
Bobby Watson.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 02-28-2010, 06:07 PM   #1128
Trader Rating: 24 (100%+)
Cool
good job guys
RANDY SMOOTH is offline   Reply With Quote
Old 02-28-2010, 06:27 PM   #1129
Hi TM Family,
Have fun
Andy Ledgard
Good job guys,what was you'll set up?
grouchy is offline   Reply With Quote
Old 03-02-2010, 07:28 AM   #1130
ALG
He re is my Set up;
FRONT
Track: 198mm
Roll bar: Flat
Diff with 500K
Toe 1º open
CAmber L 2º R 2.5
Droop 2mm (static)
Caster 3mm
offset 0
oil shock 400
piston stock
Spring Kyosho blue
Akerman c
REAR
Track 200mm
Roll bar: 2.2 (wire flush with collar)
Toe: 3.5mm
Camber L 4, R 4.5
Droop: 4mm
Offfset 0
Oil 400
piston stock
Spring Serpent Yellow
Ride height with 56mm wheels Front 5 rear 5.5mm (to much bumps and change in elevations)
Engine
RB T9 RC with NR 2562 Pipe
Body ALTIS 2.3, (first time with that body, is GREAT!!!!!!!)
Have fun and if you have any question we are here to help.
Andy Ledgard
Team Magic Peru
Old 03-02-2010, 09:30 AM   #1131
HTN
I own one of these cars and it looks really good, but I haven't tested it yet because of the bad weather
When I ordered spares for this season it came to my mind that I couldn't find the O-rings, which seals the differentials, anywhere
I just wondered where you guys get the O-rings from, or if you use something else to seal the differentials.
All answers are appreciated
HTN is offline   Reply With Quote
Old 03-03-2010, 07:49 AM   #1132
aizenbelle's Avatar
that is a good question? does anyone know
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 03-03-2010, 07:59 PM   #1133
Post
i lost a o-ring on a diff and i used some red hight temp silicone but make sure you clean the diff case real good so you can get a good seal works great
Old 03-04-2010, 07:53 AM   #1134
HTN
Thanks for the answer
I'll try sealing them with silicone when the O-rings need to be replaced
Old 03-07-2010, 02:55 PM   #1135
Hello everyone.
That lipo battery used in this car?
I have one but only 900 mha.
There is some lipo battery of more than 1300 to enter into this car?
Thank you very much.
Greetings
arielnieto is offline   Reply With Quote
Old 03-07-2010, 04:50 PM   #1136
Default LIPO 7,4 VOLT. FOR RECEIVER
Hi there,
I used the INTEGY 7,4v LIPO rx baterry...
The receiver is a SPEKTRUM SR3100 and my servos a SANWA ERG RZ...
My questoin is:
I need to use a regualator ? To put the receiver working on 6 volts? or there is no problem with the receiver but with the servos that work on 6 volts?
thanks... please help me..
T.Senna is offline   Reply With Quote
Old 03-07-2010, 05:24 PM   #1137
blis's Avatar
Default LiPo
Originally Posted by T.Senna View Post
Hi there,
My questoin is:
Yep it's for the servos. Best put the LiPo on a multimeter and check the real voltage too.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 03-07-2010, 06:38 PM   #1138
Chickentrader's Avatar
Hi there,
My questoin is:
You are meant to, but there are some that run lipos without voltage regulators. The rated voltage is less than 3% different to NIMH, but the initial output may be higher. One guy in our South East Queensland racing community is actually testing it, by not using a voltage regulator. There has not been a problem with this yet as far as I know. You would think that there should be a fair bit of tolerance with this in servos, receivers and transponders; but who am I to know.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 03-07-2010, 11:21 PM   #1139
In my circuit, virtually 100% of pilots use the lipo battery without voltage regulator.
T. Senna, you could put a picture and the size of your battery?
Thank you.
Old 03-09-2010, 02:00 AM   #1140
Help to solve a problem - leak of oil from the shock-absorber (from 152007)!
crius is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
