Old 01-25-2010, 03:49 PM   #1051
impalabob64's Avatar
Send a message via AIM to impalabob64
Default +1
Originally Posted by aizenbelle View Post
good stuff!! If I was you I would get the Kfactory rear aluminium support that is the only part I had trouble with
I second that, i have some Kfactory stuff coming in (got the tip on what kfactory parts to add to make the car perfect) i will let you when the testing is done.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 01-25-2010, 06:16 PM   #1052
MACHINARIA's Avatar
Default Your imput needed
Hello guys, please let me know what you think.
Best regards
Anna
RC Fanatic
I need your help to build an On-Road Track in Virginia USA.
www.machinaria.com
MACHINARIA is offline   Reply With Quote
Old 01-25-2010, 06:40 PM   #1053
Thumbs up I will take 3
Best regards
Anna
3x is my size ,very nice work ,maybe some hats later.
RoninRc.com
Basher BT-4
Old 01-26-2010, 03:17 AM   #1054
R.Gilletti's Avatar
Send a message via MSN to R.Gilletti Send a message via Skype™ to R.Gilletti
Best regards
Anna
Really nice Anna!
Nice to see apparel for TM Drivers!
How I can to have one of this T-Shirt??
Best Regards
Raimondo Gilletti
Raimondo Gilletti
Production Director @Matrix Racing Tires
R.Gilletti is offline   Reply With Quote
Old 01-26-2010, 05:12 AM   #1055
MACHINARIA's Avatar
Originally Posted by R.Gilletti View Post
Really nice Anna!
Best Regards
Raimondo Gilletti
Thank you very much. you can send us your address and we will send you one as soon as we receive them.
Best regards
Anna
www.machinaria.com
RC Fanatic
www.machinaria.com
Old 01-26-2010, 05:13 AM   #1056
MACHINARIA's Avatar
Glad you guys like the shirts. We will ship them out as soon as they arrive.
Best regards
Anna
RC Fanatic
www.machinaria.com
Old 01-26-2010, 06:27 AM   #1057
Trader Rating: 24 (100%+)
Cool
Best regards
Anna
nice XL for me
RANDY SMOOTH is offline   Reply With Quote
Old 01-26-2010, 10:12 AM   #1058
roach's Avatar
Send a message via Yahoo to roach
Thumbs up RSII shirts
hi Anna i could use two xl please! i'll be placing an order for more up grades next week also...whats up with the VA track Anna?
thank you!..
roach is offline   Reply With Quote
Old 01-26-2010, 12:07 PM   #1059
ALG
Originally Posted by roach View Post
lets us know how the car is working for you...
OK, my reporte of the car. First of all I had some "problems" with the clutch, but made it work after some mix and match from my previous G4, but there is something that dosent sound ok... I just got my teflon counter weight and my yellow clutch shoe. hope to get the thing working
I just drove the car for 2 tanks because I got some problems with the middle shaft, but my impression were the following.
Over steer entering the corner and under steer coming out of the turns. the car felt very twitchy or nervous
overall the car felt good and with potencial, I will work on my clucht and try the front diff.
the body I was using was the KFACTORY
My set up is the following
front,
199m
Roll bar flat (stock)
spool
toe out -1
Camber 2.5º
droop 1
Caster 4
0ffset 0
shocks 450 oil piston std spring white Stock
Mounting shocks upper inner lower outer
ackerman C
RAER
200mm
Roll bar 2.2mm
50,000 diff fluid
Toe 3º
camber 4º
droop 3
offset 0
camber link shim 0mm, lower inner
roll center 0
shock 450, std piston, 1.6mm spring TM
shock mounting lower inner upper inner
257mm wheel base
40 shore all the way
Regards and waiting for your comments
ALG is offline   Reply With Quote
Old 01-26-2010, 06:30 PM   #1060
Default Lets see
front,
199m
spool
toe out -1
Camber 2.5º
droop 1
Caster 4
0ffset 0
ackerman C
RAER
200mm
Roll bar 2.2mm
50,000 diff fluid
Toe 3º
camber 4º
droop 3
offset 0
roll center 0
257mm wheel base
The first thing i see is your front droop.1 i think is transfering alot of weight to the rear which would give you a push while on power.I would go to 3 or 4 first before you change anything else.For me i like to start off with the cars stock setup then work from there.So try the droop first ,then let us know if you still have the same problem.P.S Stratus 3.1 make it you friend LOL
RoninRc.com
Basher BT-4
Old 01-27-2010, 02:31 AM   #1061
Chickentrader's Avatar
Default Selling my G4RS09 with parts on E-Bay
Hi all,
I'm selling my G4RS09 on E-Bay at http://cgi.ebay.com.au/ws/eBayISAPI....#ht_500wt_1182.
Rolling chassis; complete with manual – never raced; only used for about one hour in practice. Has front diff and 1900 Mha lipo battery installed. Comes in original box with the following new spare parts: 2 x side belts, 2 x front belts, rear belt, front & rear arms, 4 x 1st gear spurs, 2 x 2nd gear spurs, steering blocks (front uprights), front spool, front and rear hinge pin blocks, complete 2nd speed clutch set, and roll centre – caster clips - adjustment washer set.
Pictures on Photobucket at http://s498.photobucket.com/albums/r...r/G4RSII%2009/.
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 01-27-2010, 03:53 AM   #1062
getpip's Avatar
It depends on how he is measuring droop Bob.
If he is measuring actual droop ie. how far the chassis lifts before the wheels leave the ground ...I reckon 1mm is about right.
If he is measuring static droop ie. downstops on blocks then I agree with you.
What other shells have you tried Bob and what how do they compare.. I have been running mostly Blitz 2.3 which I like.
Regards
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 01-27-2010, 03:56 AM   #1063
getpip's Avatar
Originally Posted by Chickentrader View Post
Hi all,
Kindest regards,
Lars.
Why you selling up Lars?
What have you bought?
Old 01-27-2010, 05:27 AM   #1064
blis's Avatar
Default Old magic revived.
Guess who bought all his G4/07 gear.. not to mention.. 80% fully restoring my first TM G4 lemans back to original (with some hop up) glory. Will make a nice addition .. now to build a shelf!
Lars, you've lost the love....
PS: Lars, heading down to Sydney for a memorial meeting, back Tuesday.
PPS: Dont mind the tyres guys.. was just checking the roll.. something is sticky on the front end.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-27-2010, 05:33 AM   #1065
Default Bodies
Regards
Stratus 3.1,Civic,i want to try the Blitz maybe i can pick 1 up an give it a try.Lars why you selling man everything ok.
RoninRc.com
Basher BT-4
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
