Old 01-07-2010, 07:46 PM   #1021
fatboy's Avatar
Send a message via MSN to fatboy
Originally Posted by R.Gilletti View Post
Hi Anna!
Thanks for the welcome!
thank you for the support to TM Customers!
I really like the TM family in this forum!
Ciao Ciao!
JUST COOL MAN.....
Serpent 100, Serpent 120, Serpent 240 , Serpent 966, Serpent 733, Serpent 811, KM HK-1
fatboy is offline   Reply With Quote
Old 01-08-2010, 06:09 AM   #1022
roach's Avatar
Send a message via Yahoo to roach
Default RSII
no body has any tips on maintance, set ups on the 2speed? im just trying to learn everything i can about them. i think its one of the most important factors in getting the most performance out of your cars. i havent had any issues, however i did notice it gets pretty hot , is any one use grease or oil in the bearings?
I'd be greatful on some feed back on this subject!...thanks.
roach is offline   Reply With Quote
Old 01-08-2010, 07:31 AM   #1023
aizenbelle's Avatar
personally I use oneway bearing lube and seal it with a small piece of tape that dispose of at the end of the day when cleaning my car. As far as setting it up I go according to the manual but you can set it up depending on how early you want the 2 speed to engage, remember that you also have to setup your clutch , good luck and if you want more details on setting up your car you should PM some of the guys that race pro like raimondo , Impalabob and many of the other fellas on this forum
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 01-08-2010, 08:35 AM   #1024
roach's Avatar
Default 2 speed
thanks aizenbelle!...every bit helps
Old 01-08-2010, 03:29 PM   #1025
blis's Avatar
Default Cleaning and gap.
I've found that cleaning the 2 speed drum of dust and residue with cleaning gum gives my cars a much smoother change, theory is that clutch dust adds a bite to the change (risking spur strip), otherwise, as mentioned, keep one way clean, use old one drop of one way lube and ensure bearings are in good working order.
I haven't yet explored the gap... after all it is a clutch, maybe others have tweaked them in this area.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 01-08-2010, 04:11 PM   #1026
Trader Rating: 13 (93%+)
Hi Roach build it as per manual but just loosen the 2 larger screws half a turn more for earlier engagement, this will help you get the engine tuned right first as this is a must for 2 speed engagement.
Don't use grease on the bearings, just a drop of light bearing oil and then wipe of the excess. Keep the gap between the shoe assembly and 2 speed housing to a minimum without drag using the small set screws.
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 01-08-2010, 04:37 PM   #1027
roach's Avatar
Thumbs up thanks guys
thanks every one...thats just what i was looking for...i knew there wasnt much to it. i just wanted to keep it performing at its best.
Old 01-10-2010, 04:20 PM   #1028
roach's Avatar
Default RSII CLUTCH SPRING
is every one using the 1.8 black spring???
Old 01-10-2010, 06:10 PM   #1029
impalabob64's Avatar
Send a message via AIM to impalabob64
Default clutch spring
Try the Orion spring
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 01-10-2010, 06:47 PM   #1030
roach's Avatar
where can i find that bob? and why that spring?. did know they made clutch springs.
Old 01-11-2010, 09:36 AM   #1031
Default Orion spring
Hey roach here is the part #ORI88671 www.teamorion.com also i will be running the G4RS 09 for this year,s Winternats.
RoninRc.com
Basher BT-4
Old 01-11-2010, 10:31 AM   #1032
roach's Avatar
Default hey bob
thanks for the info...i put in my favorites going to check it out after i write this. i was watching the forgas race yesterday, untill i lost the conection...ugh! i'll be watching the nats to. hope you do well there.
im making plans for 011. lets see how this sommer goes here for me.
thanks again bob.
Old 01-13-2010, 05:18 AM   #1033
MACHINARIA's Avatar
Bobby you got PM.
Anna
www.machinaria.com
RC Fanatic
I need your help to build an On-Road Track in Virginia USA.
www.machinaria.com
MACHINARIA is offline   Reply With Quote
Old 01-15-2010, 02:24 PM   #1034
Default Building G4 RS 09
Hi everybody,
For two years I ran with the MTX4-r.
For this season I decided to run with the G4RS 09.
I liked to Know from Raimondo Gillette, and all the pilots of the forum what can I expect from this car?
It's fast from box ? Easy to drive? There are plenty of direction?
It has more grip from behind or ahead?
I know this depends on the set-up that we run ... but what are the main features this car?
It is very different from the G4 RS 08?
Can be competitive equal with nt1, 733, velox v10, vone ...
I hope that TM could win the world´s Championship in Texas this year or the European Championship in Sweden.
Balestri deserved to have won in 2009 in Gubbio - Italy
This car needs a few extra kfactory? What you advises ?
Finally I wish all the TM riders a good seasson with a lot of victories...
T.Senna is offline   Reply With Quote
Old 01-15-2010, 03:18 PM   #1035
Default Welcome
Originally Posted by T.Senna View Post
Hi everybody,
Out of the box the car is a dream to drive,i would get the yellow clutch shoe ,an maybe the orion clutch spring.Setups Dario,an R.Gill have setups as do many others on this thread.Build it, drive it ,learn it,you will always get help from this thread, so dont be afraid to ask for help.P.S go lipo.
Best Regards
Bobby.
RoninRc.com
Basher BT-4
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
