Old 10-08-2009, 05:45 PM   #841
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Wire Sway Bar
Originally Posted by mrgsr View Post
Our local hobby store www.nbhc.com.au has the front wire swaybar. Looks pretty good but i havent used it yet. looks more suitable for lower traction tracks but also looks much easier to adjust tweak
Do you have the part number of the wire bar.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 10-08-2009, 06:05 PM   #842
Trader Rating: 13 (93%+)
no sorry but send a pm to old 69
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-08-2009, 06:51 PM   #843
Trader Rating: 24 (100%+)
Hi guys we should have some new parts available soon for the G4 RS 09:
- new bigger fuel tank
- some new carbon fibre bits
- front lower adjustable arms
Sounds good
RANDY SMOOTH is offline   Reply With Quote
Old 10-08-2009, 11:57 PM   #844
Company Representative
OLD 69's Avatar
Trader Rating: 44 (100%+)
K14213 i have 2pcs left. We (www.nbhc.com.au) are from Australia but have no issues supplying overseas.
They look and feel awesome on the car. Full stiff on this bar is 3/4 on the blade style, so if you run full stiff this is not the bar for you.
Regards
Ari
NBHC
www.hobbyexpress.com.au
www.nbhc.com.au
OLD 69 is offline   Reply With Quote
Old 10-09-2009, 10:41 AM   #845
blis's Avatar
Default Old 69's magic on track
Latter part of video from stand.
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 10-13-2009, 09:25 AM   #846
Default G4 RS 2009 - Ackerman
Can Anyone explain to me how the ackerman positions (A to D) work in the RS?
[]΄s
R.Takeda
takeda is offline   Reply With Quote
Old 10-13-2009, 09:40 AM   #847
aizenbelle's Avatar
I'm thinking about getting the light weight clutch bell, is there an advantage to this part? or should the light weight 2 speed housing will do
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 10-13-2009, 10:12 AM   #848
AC.
- new bigger fuel tank ==> more than 75cc??
AC. is offline   Reply With Quote
Old 10-13-2009, 10:47 AM   #849
PrimeAKF11's Avatar
guys,
can someone help me out by posting a setup that has a lot of steering on a mid bite track? I still don't have the understeering problem under control .
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 10-13-2009, 11:44 AM   #850
afm
afm's Avatar
[]΄s
R.Takeda
The size and geometry of the servo saver forces the inside wheel to increase its turning angle at a greater rate than the outside wheel, as the servo turns either way from center.
The rate of the increase, called Ackerman effect, can be changed by the angle of the steering rods connecting the servo saver to the steering blocks. The straighter the rods are in relation to each other, the more Ackerman effect will be applied to the inside wheel.
The goal in tuning ackerman is to get the car to keep a consistent steering arc after going from off-power to on-power, while not allowing the front inside wheel to be turned too much and drag through the corners instead of rolling through them.
If the car steers well off-power but pushes on-power, then use more Ackermann effect and decrease your transmitter EPA/dual rate.
If the car steers well on-power and pushes off-power, then use less Ackermann effect and increase your transmitter EPA/dual rate.
The angle of the steering rods can be changed by moving the steering rods inner mount position on the servo saver, or outer mount position on the steering blocks.
1. Inner Ackermann Position (servo saver) – Changing the forward/rearward position of the servo saver has the greatest Ackermann effect
Position more forward – less Ackermann effect (steering rods more angled)
Position more rearward – the greatest Ackermann effect (steering rods straighter)
2. Outer Ackermann Position (steering blocks) – Changing positions on the steering blocks is used to fine tune the Ackermann effect
Position more forward – more Ackermann effect (steering rods straighter)
Position more rearward – less Ackermann effect (steering rods more angled)
NOTE: It is recommended to use more Ackermann effect in low-to-medium grip conditions and less Ackermann effect in medium-to-high grip conditions.
Hope this helps
AFM
afm is offline   Reply With Quote
Old 10-13-2009, 02:58 PM   #851
Chickentrader's Avatar
Hope this helps
AFM
Would you mind if I use this information in the "How to Guide" in our club (SCRCCC) newsletter?
Kindest regards,
Lars.
Support your local RC stores - they support our sport!
Social media – The empowerment of the small individual to enforce democratic process at the expense of dishonesty.
Chickentrader is offline   Reply With Quote
Old 10-13-2009, 03:34 PM   #852
afm
afm's Avatar
Kindest regards,
Lars.
Sure, no problem
AFM
Old 10-14-2009, 05:20 AM   #853
has anyone played around with the diff heights yet?
you have the difs in 2 positions, high or low. tthis can be changed by rotating the orange eccentrics areound.
Old 10-14-2009, 05:44 AM   #854
Default A B C D
[QUOTE=afm;6468070]The size and geometry of the servo saver forces the inside wheel to increase its turning angle at a greater rate than the outside wheel, as the servo turns either way from center.
Hope this helps
AFM[/QUOTE
So in otherwords
A-less
B-mid
c-mid
d-more (is this correct in a sense)
RoninRc.com
Basher BT-4
Old 10-14-2009, 07:24 AM   #855
blis's Avatar
Default A + B + C + D == Awesome work guys:)
None of it matters if there's not enough front droop to keep the tyre down... But rather than disrepect a great post... I should make the remark...
HOW GOOD IS THIS THREAD!!!
Thanks guys, awesome info
A few more ideas to throw around:
1) We ran in the wet... yes I mean rain.. on foams.. one big drift race... should I have cut the rear belt?
2) Also am very much relating tyre shore and suspension, stiff suspension, hard shore, softer suspension, softer shore.
Ive been practicing the theory that shore == tyre pressure and with reasonable tyre diameters, 59/61 etc (not low trued <57mm) . The car has more roll with softer suspension, this in turn will run on the edges with hard shore tyres and likely to chunk. With softer shore, the tyre is more maleable and manages the roll of the car onto the softer tyres.
Ideally a fast car is stiff and low, though this isnt always possible, but on a high grip smooth track I was running orange and blues (rear) on 42 shore at 62/60mm.. (Quite large hey!) The car handled really well (better than ever) and Ill be experimenting some more on this principle ..
If the track grip comes up I will be tempted to use the GREY/ORANGE TM on 42's just to find out, so Im going to do it when grip comes up at our local just to find out. (Will just need to avoid the aging bumps)
Ideas? Opinions? am I wrong? are there other factors at play?
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
