Old 10-05-2009, 12:18 PM   #826
getpip's Avatar
Originally Posted by Muley View Post
Hi All,
Just wondering if some one could help and let me know if they are having trouble with the shockies leaking and how to get the oil level right. If i get full travel they will not rebound all the way - if i get rebound i do not get full travel - i am using the standard shock bladder.
Thanks Mike
I use the xray Orings .... good n chubby!
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 10-05-2009, 12:26 PM   #827
PrimeAKF11's Avatar
I used the o-rings I had for my G4RS 08. They work perfectly.
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 10-05-2009, 08:31 PM   #828
Trader Rating: 13 (93%+)
Default 2009 Australian Nationals update!
hey guys im back from a hectic 2009 australian nationals and once again rain killed the event.
We had to cancel the 6th qualifier as rain disturbed the last few heats in round 5 so i ended up qualifying 22 out of 80+ drivers. My car was superquick in my last qualifier (laptimes in the high 17 seconds) TQ's lap times were 17.4-17.5 so i was very happy with the car.
I started first on the grid in the 1/4s but due to a rapid weather change the engine was so rich on the first lap that i had to come in the pitlane to lean it so i dropped to last but ended up second at the end of the race on the same lap as first out of 9 drivers.
i then started 9th in the semi and got up to 3rd on the opening lap but then my engine (353 09 tuned) was changing tune with the weather. after a crazy semi i finished 5th not enough to progess to the main final.
Not that it mattered as thunderstorms came through we had to cancel the event and results were called on qualifying.
Ill post my setups as soon as i can.
John Germanos
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 10-05-2009, 10:36 PM   #829
fatboy's Avatar
Send a message via MSN to fatboy
great race.....
fatboy is offline   Reply With Quote
Old 10-06-2009, 05:23 AM   #830
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Great News
Thats good to hear that the car is doing really good,cant wait to see you setup.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 10-06-2009, 05:37 AM   #831
Default Setup sheet
Guys this setup was used in qualifying and finals
i started with 37f 40r tires then when the grip came up i changed to 40f 42r
File Type: pdf 2009_Australian_Nationals_John_Germanos.pdf (148.2 KB, 149 views)
Old 10-06-2009, 08:22 AM   #832
blis's Avatar
Default AU nats 2009
To Impala and our international friends..
I tried so hard to get the feeds working early so you could get some insight into the event but after spending my own $$ on a wireless extension cable for the antenna and bridge coax cable, the antenna extension connectors didnt fit and race control and was marred with poor bandwidth and video coverage. I did my best
Im uploading a video to http://www.vimeo.com/blis/videos atm and it should be ready in a couple of hours.. if not 6 hours (wake up time)
Guy drove very well, posting times a little over one second off the top runners and in one practice heat drove a .28 deviation and was competing in his heat with the likes of Patto who is the West Australian Champion.
The G4+ was wonderful on the smooth track with 42 shore Matrix tyres, ORange and Blue springs with 650 oil and low ride heights. It was a learning experience none the less, trying to preserve the race engine marred many heats and in the final qualifier with our GRP Guy learnt about patience as he was on a 31 lap schedule and fast through the sweep and met a slower car a little too early and ended his quals 4 feet off the ground and broken rear arm.
We learnt a lot about our team, rules, engine tuning and strategies and in our 1/16th final were set onto a "wet" track with foams and drifted slowly around off racing line while the others took on rubbers and left us struggling... it was all over.
After the wet 1/16th final I pondered over whether I should have cut the rear belt and let Guy drive front wheels only... still wondering... I cared not to use rubber as it seemed an unfair advantage, it's not how we are supposed to race in AU.
Special thanks to Patto for his understanding and support as he was in our heat and we got in his way in qual 1, one can only wonder why he was... anyway... we made sure he got clean quals after that.
Cheers to all that supported us, we'll definitely take this experience as a learning one and move on to more successfull events in the future.
more media posting soon.. need Zzz's
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 10-06-2009, 03:41 PM   #833
Default Florida
Be nice if you guys can come my way for the Winternationals,be nice meet all you guys.
RoninRc.com
Basher BT-4
Old 10-06-2009, 04:34 PM   #834
Pattojnr's Avatar
Trader Rating: 19 (100%+)
h
as i said on the day Blis, there is no point mouthing off at a kid who enjoys his racing, as it can affect his future. it is not your fault nor mine that i was put in that heat. i thank you for taking the time to come talk to me about it, and im happy that MOST people realised i was the quicker car out there. i had patience to not push or barg my way past, but still some just dont get they are racing the clock in qualifying. no harm done, and i wish you all the best for the rest of the season.
Serpent - Walter RC
Serpent E Power ..... Serpent 747 Reds M3T
Serpent 966-TE Reds M7T .... S411ERYX Speedpassion 3.5T, T-Shox
Serpent 811-TE REDs R5T
Pattojnr is offline   Reply With Quote
Old 10-06-2009, 05:30 PM   #835
roach's Avatar
Send a message via Yahoo to roach
Default G4RS clutch
hope im in the right thred for this. in short im new to touring cars, been racing dirt& ashphalt oval, for 15+ years...anyway i have a ufo clutch. cars runs great handels great. but i don't know how to set the clutch..its not shifting. its not sliping or screeming. the track i was testing it on was small
maybe a 30' stright. but i need to know how to set the shift points...
thanks; roach
roach is offline   Reply With Quote
Old 10-07-2009, 02:31 AM   #836
blis's Avatar
Default Is it on a G4?
thanks; roach
Roach, I trust you are using this clutch and bell on a G4.. if not you better be sure you are meshing to the two speed as a G4 has a 4mm split between gears unlike many other 2speed systems like mugen at 5mm.
Secondly, if you are referring to 2nd speed shifting, that's inside the 2 speed system not the clutch.
If you are referring to the two speed flyout clutch, Ive got quite strong hands and I can just manage to open them 1mm when I pull on them. Be sure you're not too loose as you may be stuck in second gear. It's a matter of tightening the 2speed clutch in, ensuring you are in firsat gear, then equally unwinding the shoe tensioning screws 1/4 turn at a time until you get second gear.
For the UFO engine clutch, I tighten the clutch nut down until I cant turn it easily with my fingers, if the wheels turn when you fire it up, one of two things are happening:
1) Not enough GAP between Clutch shoe and clutch bell
2) Or too loose on the clutch nut.
If it doesnt engage at all..
1) Too tight on the clutch nut
2) Or your clutch shoe is worn out.
I use a thrust bearing washer + shims beneath to create the gap between the clutch bell and clutch shoe, then pack the rest of the spacing with shims after the thrust bearing.
good luck.
h
Old 10-07-2009, 07:52 AM   #837
roach's Avatar
Default G4JS
thanks bliss yes it a G4JS...all seems fine with it, it just wasnt shifting.
I think it might be locked down. i'll check it out and get back. just new to touring cars, but im hooked now!!!!
thanks again!
Old 10-08-2009, 05:50 AM   #838
Hi guys we should have some new parts available soon for the G4 RS 09:
- new bigger fuel tank
- some new carbon fibre bits
- front lower adjustable arms
Old 10-08-2009, 07:31 AM   #839
Default Front wire Bar
Any news on the front wire bar .
RoninRc.com
Basher BT-4
Old 10-08-2009, 04:17 PM   #840
Our local hobby store www.nbhc.com.au has the front wire swaybar. Looks pretty good but i havent used it yet. looks more suitable for lower traction tracks but also looks much easier to adjust tweak
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
