Old 09-24-2009, 09:44 PM   #811
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Best of luck
Originally Posted by mrgsr View Post
The drivers using the G4 09 at the nats are:
Brendan Sola
Ari Bakla
John Germanos <- Myself
Not sure of any others - Blis do you know?
Wish you guys the best ,keep us posted, again i know i will be watching.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 09-25-2009, 03:12 AM   #812
blis's Avatar
Default U got it right...
We're still running the G4+ not sure, just three.. but HEY what a good set of THREE.... Go get em MrGSR..
http://76.164.192.66/slyfoxrmt/livet...ivetiming.aspx
Keep your eye on slyfox next week
Live timing/video hopefully.
Cheers.. excitement is growing here!
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 09-25-2009, 04:04 AM   #813
blis's Avatar
Default Meet the aussie TM drivers
#1 Pit dad.. Me..!!
http://www.beachmumsracing.org.au/wp...%20(Large).JPG
Guy my driver (eldest son)
Luke my younger.. E4 electric racing the top runners and learning excellent driving ettiquette )
SP.. The godfather of TM in Aus.
http://www.beachmumsracing.org.au/wp...s/dscf9850.jpg
Brendan Sola.. ( He needs a good run.. lots of bad luck at recent title meets and he's fast!! IT'S TIME LUIS!!)
John Germanos (Left)
Beachmums car for 2009 Nats.
http://www.beachmumsracing.org.au/me...chmums-racing/
Old 09-29-2009, 06:25 AM   #814
Muley's Avatar
Default Shock Setup
Hi All,
Just wondering if some one could help and let me know if they are having trouble with the shockies leaking and how to get the oil level right. If i get full travel they will not rebound all the way - if i get rebound i do not get full travel - i am using the standard shock bladder.
Thanks Mike
The Only Toy to Have
Team Magic G4RS - 09
Nova Rossi 3SCT Plus
Helios Spektrum
Ko Propo Servos
Muley is offline   Reply With Quote
Old 09-29-2009, 07:09 AM   #815
Default Leaking
Are they leaking from the bottom,also are getting the air out .If the shock is leaking from the bottom try bigger o -rings.I had the same problem, i think a few others did too.As far as rebound i fill the shock then i make sure i get the air bubbles out before i put the cap on the shock.Hope this helps .
RoninRc.com
Basher BT-4
Old 09-29-2009, 08:25 AM   #816
Default Imfo
Any imfo on the Aussie Nats want to check on my TM friends.
RoninRc.com
Basher BT-4
Old 09-29-2009, 08:36 AM   #817
Renault_Tech's Avatar
Im on my way to Sydney 2moro to help Luis and Brendan out. Big Lue must be having fun working on the Evolva and G4RS while Brendan sits there and watched TV. I will try to keep you guys updated whilst up there.
[KYOSHO] [NOVAROSSI] [TEAM MAGIC G4RS] [O.S SPEED T.Z SPEC II] [SPEKTRUM DX3R]
Renault_Tech is offline   Reply With Quote
Old 09-29-2009, 01:37 PM   #818
Default Clutch spring
Well, I´ve finished the assembly of my 09. But I have some doubts...
1) Are you using the green clutch spring? Cause it doesn´t work fine with my 353. It was very slippery... I´ll gonna test the black one.
2) The rear body mount was very high for my body (Stratus 3.1). I had to remove de body mount and install just a rubber ring... Is that happen with you too?
3) My Novarossi header is very close to the side belt. I had to remove some material from it and the belt still "touches" the header. What do you do in that case...?
[]´s
R.Takeda
ps.: Sorry for my bad English...
takeda is offline   Reply With Quote
Old 09-29-2009, 02:57 PM   #819
Default Hope this helps
1)For your clutch,i recommend the TeamOrion spring,or you can use 1/8 clutch spring also.Kyosho,Serpent,Mugen will work fine.I think the is green i way to stiff.
2)For your body i think alot guys are doing the same with the O-rings.
3)For you header i would shave alittle more off,adjust the side belt tensioner alittle more that should help with the clearence.If we can help you with anymore ?s. Feel free we are all here to help.Best of luck with your new ride.My name is Bobby Watson
RoninRc.com
Basher BT-4
Old 09-30-2009, 02:46 AM   #820
Bundy_Bear's Avatar
Originally Posted by blis View Post
#1 Pit dad.. Me..!!
Hey hey... I didn't get a mention! I have taken the liberty to add a photo of myself as Blis has forgotten
See you at a track near me... Don't forget the Bundy Red to keep you running!
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 09-30-2009, 02:54 AM   #821
Muley's Avatar
Hi Bob,
Yeah they do leak from the bottom, i use a vacumn pump to remove the air.
Do you worry about obtaining full travel or rebound. I normaly fill fill so the oil come to the outside of the shock body, then scre the cap on and if i let oil out to get full travel they do not rebound all the way out.
I am using the green clutch spring and Teflon K14208 and K14207 High grip shoe - i have installed 2 x 3mm set screws in each teflon shoe and works really well.
Thanks Bob
Helios Spektrum
Ko Propo Servos
Old 09-30-2009, 06:46 AM   #822
Default Hey
Originally Posted by Muley View Post
Hi Bob,
Thanks Bob
No problem,i think you are over filling you shock bodies ,fill them i until get about 1/3 away from the top.Then before you put the cap on push the shaft up an then pull it back down until you get rid of all the air bubbles, then put the cap on.Then when you push the shaft in it should rebound.Heres a tip if you get a bid at a race ,im using the Evolva shocks with TM shockends with kit springs they work perfect, just tip if you get in a bid.
RoninRc.com
Basher BT-4
Old 09-30-2009, 07:11 AM   #823
Default Hey BB
Trying to get on the slyfox livescoring can you help thanks .Bobby
RoninRc.com
Basher BT-4
Old 09-30-2009, 03:49 PM   #824
Bundy_Bear's Avatar
Hi
Not working for me either, you can see the results though when clicking on results files. Maybe no live coverage yet until qualifying starts!
MissMooRC Racing
Old 10-05-2009, 06:15 AM   #825
aizenbelle's Avatar
Default Kfactory
just got my kfactory rear hinge pin mount
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
