Old 08-25-2009, 10:48 AM   #676
aizenbelle's Avatar
Originally Posted by PrimeAKF11 View Post
Guys,
What kind shims am I supposed to use for altering roll center? Is there a special kind that goes below the upper arm mounts (front) or the lower arm mounts (rear) ?
your kit should have come with the required shims they are made of plastic
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 08-25-2009, 11:02 AM   #677
getpip's Avatar
Are these not for the rear only though?
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 08-25-2009, 11:11 AM   #678
PrimeAKF11's Avatar
Ok, I think I found the shims for the rear but I'm still lost on what to use for the fronts.
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 08-25-2009, 03:14 PM   #679
Sp Racer's Avatar
Originally Posted by getpip View Post
This is an interesting observation.
I am usually a front diff driver (mtx4) but I ran my RS09 for the first time on Sunday.
I was amazed at how predictable the tranistions were with the solid .. much better than I had expected. Although I was overshooting my off power apexs a little at first there was still more off power steering than I expected.
I have the front diff on order but am wondering now if it will be an improvement.
I have to say though ... what is that clutch all about!? I ended up ditching those pivoting shoes in favour of free floaters and the difference is night and day.
I am really looking forward to having a play around over the coming weeks.
Re. clutch shoes - did exactly the same here, heaps better
Sp Racer is offline   Reply With Quote
Old 08-25-2009, 03:23 PM   #680
blis's Avatar
Smile Clutches.
I expected as much from those pivotting throwouts. Doesnt make sense to act against the radial force and pivot. I still think they need a good running in to loosen up the pivot hole a little.
Tell me guys, is the pinion offset on clutch bell still same (approx 4mm) and can we share clutch bells?
Back to using a UFO2 now SP?
SP, at some time your knowledge on clutches would be a good read matey.. Apart from droop blocks Im also thinking over heavy throwouts, heavy spring, hard clutch shoes and soft clutch shoes and how they behave and react.
h
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 08-25-2009, 03:26 PM   #681
Sp Racer's Avatar
h
will post something tonight 4 you Harry
Old 08-25-2009, 04:41 PM   #682
Trader Rating: 24 (100%+)
Thumbs up
can we see some pics of the free floaters
RANDY SMOOTH is offline   Reply With Quote
Old 08-25-2009, 05:37 PM   #683
Team Magic G4RS 2009-im006016.jpgBobby Watson takes 3rd Place at Allstar Race,Tampa,Fl SS Raceway
Old 08-25-2009, 08:03 PM   #684
MACHINARIA's Avatar
Originally Posted by RANDY SMOOTH View Post
Attachment 492447Bobby Watson takes 3rd Place at Allstar Race,Tampa,Fl SS Raceway
Excellent Job guys!!!
Best regards
www.machinaria.com
RC Fanatic
I need your help to build an On-Road Track in Virginia USA.
www.machinaria.com
MACHINARIA is offline   Reply With Quote
Old 08-26-2009, 03:36 AM   #685
Bundy_Bear's Avatar
Originally Posted by impalabob64 View Post
We add a money race over the weekend,car was really good ran a front diff, although i felt i would be faster with a lock,just want to get use to running a diff.I ran a Picco Evo3 engine very fast motor insane bottom end power was able to run with Max,Sirio,Rbs without a lack in speed.Also tried out 1/8 evolva shocks.They have the short shock bodies for the front an long bodies for the rear. The car worked perfect you can use the kit springs from the G4RS or you can use springs from the RRR Evo or EVo2 not the Evolva they are to stiff.Will post setup soon.
Why did you choose to use the Evolva shocks over the RRR Evo? And are you then running the Team Magic springs and ball ends?
I ran the Kyosho Evo WCE shock shafts and pistons on my G4+ Evo as recommended by Luis.
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 08-26-2009, 05:08 AM   #686
fatboy's Avatar
Send a message via MSN to fatboy
u mean we could use kyosho shocks and springs ????
fatboy is offline   Reply With Quote
Old 08-26-2009, 05:11 AM   #687
Bundy_Bear's Avatar
Can't comment on 09 RS as i don't have one... From memory i am sure i have seen photos of Dario's 09 with Kyosho shocks and springs, i could be wrong though
BB
MissMooRC Racing
Old 08-26-2009, 06:19 AM   #688
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Hey BB
BB
I had a brand new set of Evolva shocks,also yes i used the ballends & springs,the Evo & Evo2 are using the Evolva front shocks all around.When i ran for Serpent thats the concept the Team was running on the 720.It work so i figured i would give it a try an was very impressed with the handling.Also you are able to run different springs( short front,long rear).Also as i always post this is(A Drivers Prefence) just testing to set the car to my driving style .Oh agian if your the only G4RS 09 at a big race this will help you when your in a jam, if blow or break a shock you know what works.Hope this helps you guys.I see some people trying to raise rollcenters leave car box setup.(Tires ,Shock &Shock oils,Springs,Droop,& Body) thats what i focus on the most.Learn the car before you do any major changes to the car, trust me im still learning the car too.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 08-26-2009, 10:10 AM   #689
PrimeAKF11's Avatar
Guys,
Can someone help me out with my question? What kind of shims do I need to use under the front upper arm mounts to alter roll center? Also, although I think I have the shims for the rear lower arm mounts I just can't see how they're supposed to go on .
Old 08-26-2009, 04:09 PM   #690
MACHINARIA's Avatar
Guys,
Here is an image that may help you. you must remove the screws in order to install the washers.
Best regards
www.machinaria.com
RC Fanatic
www.machinaria.com
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
