Old 08-22-2009, 05:57 AM   #661
MACHINARIA's Avatar
Originally Posted by mettuchi View Post
received the upgrades from k factory, looking good
We are glad that you like them. We have just sent you a PM let us know what you think
Best regards
www.machinaria.com
RC Fanatic
I need your help to build an On-Road Track in Virginia USA.
www.machinaria.com
MACHINARIA is offline   Reply With Quote
Old 08-23-2009, 09:25 PM   #662
What would be the better motor for this car.
I'm looking at getting my G4RS mid next month, the guys at Team Magic advised me that I should go for the "Novarossi 353 Race .12 On Road Race Engine (2009 TUNED Version)" engine.
Is there anyone else using this motor?
What is the performance like and what other motors should I consider.
I fly planes and helis, getting out that hobby and getting into cars and monster trucks with my 8 yr old son.
smo0
Smo0 is offline   Reply With Quote
Old 08-23-2009, 09:37 PM   #663
Trader Rating: 24 (100%+)
smo0
The 353 or the Maxpower will make it fly, they are very fast engine and if it's your frist time running onroad it maybe to much for you to handle i would love to have one in my car
RANDY SMOOTH is offline   Reply With Quote
Old 08-23-2009, 09:46 PM   #664
Trader Rating: 13 (93%+)
I have ran both the 353 09 and the JP Eagle 12 TL-3t and both engines are super fast.
The Jp works great with the G4 due to its shorter gear ratio as the exhaust port on the JP is a lot bigger for HUGE top end.
I have a JP eagle and a pipe set for sale if you like pm me..
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 08-23-2009, 10:25 PM   #665
Thanks mrgsr
I have always had my heart and budget set on the Novarossi 353 motor but thanks for the offer.
Where abouts do you race?
Old 08-23-2009, 10:31 PM   #666
Sydney Australia
Old 08-23-2009, 10:39 PM   #667
Do you race at Whalan Reserve or Penrith on a Tuesday night.
I'm at Blacktown.
thanks again for the offer.
Old 08-25-2009, 05:11 AM   #668
impalabob64's Avatar
Send a message via AIM to impalabob64
Default 3rd Place A-main
We add a money race over the weekend,car was really good ran a front diff, although i felt i would be faster with a lock,just want to get use to running a diff.I ran a Picco Evo3 engine very fast motor insane bottom end power was able to run with Max,Sirio,Rbs without a lack in speed.Also tried out 1/8 evolva shocks.They have the short shock bodies for the front an long bodies for the rear. The car worked perfect you can use the kit springs from the G4RS or you can use springs from the RRR Evo or EVo2 not the Evolva they are to stiff.Will post setup soon.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 08-25-2009, 06:17 AM   #669
aussies1129's Avatar
Trader Rating: 74 (100%+)
Thanks mrgsr
the build quality of the nova engines are first class and the 353 09 has lots of power just be sure to match it to the right pipe for your track and be sure to run in your nova engine correctly.
cheers
Proudly supported by......
Premier Model Supplies Pty Ltd
H.E.I AUSTRALIA
XRAY*****PRO-LINE*****HUDY*****
-----FUTABA-----NOVAROSSI-----
aussies1129 is offline   Reply With Quote
Old 08-25-2009, 06:25 AM   #670
Originally Posted by impalabob64 View Post
....car was really good ran a front diff, although i felt i would be faster with a lock,just want to get use to running a diff.......
my g4rs always seems to run better with the solid than the diff.... no matter the track or setup....
katze is offline   Reply With Quote
Old 08-25-2009, 06:54 AM   #671
gtrmx's Avatar
What silicon grease thickness are you using in the front diff?
Even 100,000 is too soft for this car sometimes... just makes me wonder.
I love the car with a diff and would hardly change it for a spool. Side to side transitions are sooo smooth with the right silicon and that helps me keep car in check. I am sure track conditions and plain preference sure make a difference and I am always open to suggestions and to learn.
Any particular reason for your preference? Keeping the car from tail-whipping on corner exit, for instance? How do you recover off-power steering? Thinner front shock oil than rear? I see it gives me a slight push off-power into long open curves, compared to my RRR. I do not see any problem in hairpins, but I am thinking it is because the car does not roll as much in the open turns as it does going into the u-turns. I've spaced up my front upper hinge pin mounts and feel no difference. Have not tried the thinner oil or softer springs. I only wanted to feel how the spool drives in direct comparison to the diff but had no time to make more changes last time at the track.
Thanks!
gtrmx is offline   Reply With Quote
Old 08-25-2009, 07:25 AM   #672
Thanks!
i tried 150k, 300k and 500k... but the transition into and out fo the corner just feels nicer to me with the solid.... i found it weird as i am normally a diff driver but the solid is just nicer on the g4rs...
Old 08-25-2009, 08:10 AM   #673
PrimeAKF11's Avatar
Guys,
What kind shims am I supposed to use for altering roll center? Is there a special kind that goes below the upper arm mounts (front) or the lower arm mounts (rear) ?
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 08-25-2009, 10:16 AM   #674
getpip's Avatar
This is an interesting observation.
I am usually a front diff driver (mtx4) but I ran my RS09 for the first time on Sunday.
I was amazed at how predictable the tranistions were with the solid .. much better than I had expected. Although I was overshooting my off power apexs a little at first there was still more off power steering than I expected.
I have the front diff on order but am wondering now if it will be an improvement.
I have to say though ... what is that clutch all about!? I ended up ditching those pivoting shoes in favour of free floaters and the difference is night and day.
I am really looking forward to having a play around over the coming weeks.
Check out my blog: www.pipskiracing.blogspot.com
getpip is offline   Reply With Quote
Old 08-25-2009, 10:18 AM   #675
getpip's Avatar
Originally Posted by PrimeAKF11 View Post
Guys,
I was wondering the same... I think one has to shell out for KFactory upgrades!
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
