Old 08-14-2009, 03:18 PM   #646
Originally Posted by getpip View Post
getpip, you disagree with that solution? I've seen people running these red dots in g4's before. What collets are everyone using?
gladcow is offline   Reply With Quote
Old 08-14-2009, 03:44 PM   #647
charlesd's Avatar
Hi,
I was using the stock one. If you use another collet you will have to grind it down a few millimeters. This is the only way you will be able to install the clutch system properly. I guess what is happening now is that when you tighten the end screw, the clutch binds and there is no freeplay at all. (that is what happened on mine before i realized i had the wrong collet on). I guess there is almost a 2 mm difference on both collets i have.
charlesd is offline   Reply With Quote
Old 08-16-2009, 07:49 AM   #648
+1 grind it down, that was the only way I could get the the clutch nut to lock. Only took me a few days to figure out the solution after trying a couple diff collets. G4/RS pro street.
OutlawIGT2 is offline   Reply With Quote
Old 08-16-2009, 10:19 AM   #649
PrimeAKF11's Avatar
Gaah, after a day of racing at Xray challenge at a nearby track yesterday, my G4RS is in need of a major overhaul. There was a removable barrier sticking out just a little at the back straight, which I didn't really notice, and proceeded to hit at full throttle .
I need to do a complete teardown but it looks like the chassis is bent slightly and the carbon upper deck is cracked as well . That alone is almost $100 in parts!!!!
Does anyone know a method of checking for chassis trueness?
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Old 08-16-2009, 02:48 PM   #650
freestyles's Avatar
Trader Rating: 14 (100%+)
There are a few ways you can check for this. 1.You can get a metal ruler or a nice straight edge and place it on the bottom of your chassis eg: front left corner to rear right corner and visa versa. If it's tweaked you will see daylight through the gap on the chassis where it is. 2.You can take your chassis off and place it on a flat surface and if it's tweaked it will rock and not stay flat 3. Or you can dish out the $$$$ for a tweak station. I personally use method one and two cause i can't afford a tweak station
PS: Sorry to hear about your missfortunes
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 08-16-2009, 04:58 PM   #651
blis's Avatar
Default As per John Hamon - TraclksideRC
My original aluminium chassis plate on lemans was bent. Spoke to John Hamon about it and in his exp, only way is to put on a heavy anvil and thwap it straight. I also sandwiched the plate under my loaded trailer for a few weeks. no change. So likely to get a new plate on order or get lucky with a big hammer.
PS: That's T6 aluminium... it's going to be very hard
RC Cars: E4/G4/TCX/LAB-C02/T4'15/MM Engines
WEB: Beachmums Racing - MYRCM Race Registration
Media: Amain - RCRacingTV - RedRC - LiveRC - blisx264
blis is offline   Reply With Quote
Old 08-16-2009, 08:59 PM   #652
Renault_Tech's Avatar
I like to untweak my chassis in a 20 ton hydraulic press. does wonders!
Renault_Tech is offline   Reply With Quote
Old 08-17-2009, 02:01 AM   #653
Sp Racer's Avatar
Yep -if it is a G4RS '08, it will always be bent, don't stress about it too much.
Try to get it as straight as you can, we would always back off the rear radio plate screws after every run and re-tweak it.
Always wanted to try the JR / JS chassis - bit stiffer which would be good....
Sp Racer is offline   Reply With Quote
Old 08-17-2009, 03:15 AM   #654
keavze's Avatar
it'll still run great even with a slightly bent chassis, no worries.
the JR/JS chassis is not as narrow and a couple of the mounting holes are different if i did remember correctly.
>>> the "SNAKE" doesn't bite; it STINGS! <<<
keavze is offline   Reply With Quote
Old 08-17-2009, 07:07 AM   #655
PrimeAKF11's Avatar
I'm talking about my 2009.
Well I don't think there's a question that the chassis is bent now. I took the car apart yesterday and it was visible to the naked eye that it was concaved .
I just hope I can get replacement parts before the ROAR regionals this Saturday. If not I can just use my 08 but I much prefer 09 over it.
Old 08-17-2009, 09:28 AM   #656
aizenbelle's Avatar
that sucks!! is there no way you can have it fixed?
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 08-17-2009, 07:10 PM   #657
Ladder Killer's Avatar
MACHINARIA, you have a PM
( I know where you stood last weekend) http://www.MobileRCRacing.com
DiscountRCRacing - http://myworld.ebay.com/discountrcracing
Team Magic Parts, Kits and More www.machinaria.com
RC Apparel - http://www.bluegrooveapparel.com Globalhobby.com - XtM Racing Teamxtm.com
Ladder Killer is offline   Reply With Quote
Old 08-18-2009, 04:04 PM   #658
MACHINARIA's Avatar
Replied
www.machinaria.com
RC Fanatic
I need your help to build an On-Road Track in Virginia USA.
www.machinaria.com
MACHINARIA is offline   Reply With Quote
Old 08-19-2009, 10:29 AM   #659
We can proudly announce that we are as CometRC.com the distributors of TEAM MAGIC, K FACTORY and HARD products within the UK.
www dot cometrc dot com
Regards
Team Comet
cometrc is offline   Reply With Quote
Old 08-21-2009, 02:17 PM   #660
received the upgrades from k factory, looking good
mettuchi is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
