Old 08-06-2009, 01:36 PM   #586
gtrmx,
Ive noticed that youre using "blue shocks".... Are they from your RRR?
[]s
R.Takeda
takeda is offline   Reply With Quote
Old 08-06-2009, 01:42 PM   #587
gtrmx's Avatar
Originally Posted by aizenbelle View Post
good stuff keep it coming, I don't know if you tried this yet but you should install ceramic bearing kit and 1mm offset hexes, my jaw dropped to the floor when I was not able to stop
if you could post you setup sheet would be nice
My setup...
gtrmx is offline   Reply With Quote
Old 08-06-2009, 01:56 PM   #588
gtrmx's Avatar
Originally Posted by takeda View Post
gtrmx,
[]s
R.Takeda
Yeah, those are Kyosho shocks from my RRR.
I noticed that in the effort of making the shock shafts travel as free as possible, TM machined the G4RS 09 body shocks in a way that they apply as little pressure as possible on the O-rings. That in turn allows some air into the shocks, specially when using lighter oils.
However, I have found some o-rings that are just a little thicker than the stock units and they may cure my problem.
I like the TM shocks, but I am not using them for the moment for that particular reason. If I find out that the new o-rings fix my problem then I will let you know.
http://www3.towerhobbies.com/cgi-bin...?&I=LXHCD1&P=7
Notice the internal diameter and outside diameter measurements...
I had been using those blue collar shocks you see in the pictures, but I drilled the bleeding hole to allow extra oil to escape and prevent over-packing...
Old 08-06-2009, 01:58 PM   #589
gtrmx's Avatar
Originally Posted by RC MARKET View Post
Mini-Z front spring ?
yup!
Old 08-06-2009, 02:00 PM   #590
gtrmx's Avatar
Originally Posted by PrimeAKF11 View Post
I did the same thing, but used a spring from a bad ballpoint pen instead . Just cut it to appropriate length and bingo!
That should do it, too, but I thought it would take some time to flatten the ends of the springs to keep the calipers spaced out evenly. Besides, I already had those in my pit box...
Old 08-06-2009, 05:54 PM   #591
Trader Rating: 24 (100%+)
Originally Posted by gtrmx View Post
These are front suspension springs for mini-z.
From the many different types available, you must use those with fewer coils, so they can compress enough to allow good disc grip.
Let me see if I can find you a part number...
yo gtrmx, in your pic it looks like the 2 speed houseing was rubbing the clutch bell how did you stop it. my clutch bell is still rubbing the 2 speed houseing i need a fix
RANDY SMOOTH is offline   Reply With Quote
Old 08-06-2009, 08:18 PM   #592
gtrmx's Avatar
Originally Posted by sebtarta View Post
GTRMX, do you have a picture of your track?
vamos guey!
I will try and get better, but this is a satellite picture from Google Earth...
And this is the layout we used for our last nats in town...
Old 08-06-2009, 08:23 PM   #593
gtrmx's Avatar
I am using whatever spacer I had in hand, but I intend to use these spacers between 2nd speed and the main shaft bearing...
http://www3.towerhobbies.com/cgi-bin...?&I=LXGPC9&P=7
I think 2 or three of these should get the job done...
Are you using any shims between the outside engine bearing and the flywheel? If you are, remove them and put a bunch of shims on the outside of the thrust bearing collet. Or use a shorter collet that does not need so many shims.
Any of the above work for you?
Old 08-06-2009, 08:27 PM   #594
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Wow
That is a motor track ,i will running this weekend to get car ready for the National.I will running Picco motors for the Nationals.Again that looks like you need motor out there.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 08-06-2009, 08:28 PM   #595
thanks, i'll try that this weekend
Old 08-06-2009, 08:29 PM   #596
Default call me
Im up with the wife .
RoninRc.com
Basher BT-4
Old 08-06-2009, 09:00 PM   #597
gtrmx's Avatar
vamos guey!
Old 08-06-2009, 09:02 PM   #598
Cool
NICE TRACK
Old 08-06-2009, 09:06 PM   #599
That is a nice track,id like to take a trip to that track really nice.
RoninRc.com
Basher BT-4
Old 08-07-2009, 05:00 AM   #600
GTRMX, that looks pretty nice. The track layout is good too, and the fact that you can do many different layouts is even better.
Thanks for the pics, at least it gives us a sense of your track and your setup used.
That orange "bocho" in the back looks in good shape...
sebtarta is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
FWR Racing Season FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
