Old 08-05-2009, 03:02 PM   #571
MHarrison's Avatar
Originally Posted by RANDY SMOOTH View Post
It's a nice car Mark
must be....but.. you upset your " little buddy " by switching.. j/k
Maybe I can make it down to the fort this weekend. Get my hands on one and see what'sup.
MHarrison is offline   Reply With Quote
Old 08-05-2009, 03:08 PM   #572
Trader Rating: 24 (100%+)
that's funny . i'll try to make the fort so you can get your hands on the wheel
RANDY SMOOTH is offline   Reply With Quote
Old 08-05-2009, 10:20 PM   #573
gtrmx's Avatar
I managed to find some time this afternoon and found way to the track.
It was a very pleasing day today, as I continue to break-in an engine and tried a few things in my car.
It was actually the first time I drive the G4RS at my home track. I cannot remember now how many hours I had to work on my setup for my old RRR to turn fast repeatable laps.
The contrast was immediate!! The G4 was planted and it felt awesome to drive, right away!! There are two sweepers that have a huge impact in lap times and the car felt superb at both!! I had been using a front diff in my RRR to be able to turn those sweepers nice and round. Since I do not have any diff fluids beyond 100k for the moment, I had to fit in the front spool. I felt that 100k front diff is too soft for our track in a G4RS09, but is just fine for a Kyosho. I was afraid the G4 would feel a little "square" with a spool and would not flow in the sweepers, but to my surprise, turn-in was still great and the car flows nicely!! I did not feel much understeer at the two hairpin turns of the track, either!! I still do not believe how balanced the car feels even with a spool! I have said many times how impressed I am with the car, but my time today with the car managed to put another smile on my face!!
Wow, there is no going back to ol'kyosho for me!! I was kind of holding back on putting my two Kyoshos and tons of spare parts for sell, but there are no second thoughts any more... RRR's for sell!!!
I do not remember when it was the last time it felt so rewarding to drive an RC!!
Last night I was making the few changes I meant to test today.
I removed the tall ball ends on the rear uprights and threw in shorter ones from Mugen, but same diameter. I intended to gain more rear traction by lowering the roll center and that is exactly what the car did!!
Some time ago I had tried this in my RRR but the result was not as evident. I do not know how far I could go on lowering that rear roll center, even by grinding off some material on the top to lower that ball end position, but in the RRR it got to a point that it did not make any difference. Our tracks are usually dusty and any additional traction is always welcome and I like trying things that are not in a manual.
On my first try here with the G4RS, the result was just what I expected!! I had to dial in some more steering afterwards, but that can only mean I can turn closer corners and keep the momentum to get out of the turn fast, too!
I'll be posting some pictures soon...
gtrmx is offline   Reply With Quote
Old 08-05-2009, 11:01 PM   #574
gtrmx's Avatar
Check the longer ball end (stock part) on the tyre...
The Mugen ball end on the rear upright lowers the roll center because it is much shorter than the stock part...
Next step will be to start grinding off just a bit of plastic from the top of the rear upright to see how far that takes me without upsetting the car. The idea is to place that camber link as parallel to the A-arm as roll center dinamics will allow.
The other thing I will have to try is making that camber link shorter. I am not sure what impact that will have in my track, but the shorter link would allow more camber change as the suspension compresses. That in turn will require less static camber. Right now the car will work with 3° to 4°, which looks a bit high. I will relate my findings...
Old 08-05-2009, 11:14 PM   #575
Hi, anyone race team magic in socal?!
LAM3SAUCE is offline   Reply With Quote
Old 08-06-2009, 04:49 AM   #576
GTRMX, do you have a picture of your track?
vamos guey!
sebtarta is offline   Reply With Quote
Old 08-06-2009, 07:31 AM   #577
aizenbelle's Avatar
good stuff keep it coming, I don't know if you tried this yet but you should install ceramic bearing kit and 1mm offset hexes, my jaw dropped to the floor when I was not able to stop
if you could post you setup sheet would be nice
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 08-06-2009, 09:33 AM   #578
gtrmx's Avatar
vamos guey!
hahahaha!!! I do not, but let me find some for you...
Old 08-06-2009, 09:41 AM   #579
gtrmx's Avatar
I already have ceramics in the car and aluminum hexes!! Coming up is a Ti screw kit, turnbuckles, hinge pins, KFactory hinge pin blocks and high grip clutch shoe... weight is not restricted for us... If the mounting blocks make no significant difference in terms of roll center adjustment, then I am putting plastics back on, but let's see...
Let me put together a setup sheet for you...
Have you put spacer springs between the brake calipers??
Old 08-06-2009, 12:24 PM   #580
aizenbelle's Avatar
I have not, what type of springs are you using, would you mind uploading a picture? Thanx in advance
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
Old 08-06-2009, 12:36 PM   #581
gtrmx's Avatar
These are front suspension springs for mini-z.
From the many different types available, you must use those with fewer coils, so they can compress enough to allow good disc grip.
Let me see if I can find you a part number...
Old 08-06-2009, 12:39 PM   #582
gtrmx's Avatar
http://www.rckenon.com/public_html/s...roducts_id=397
These are disk damper springs, but their diameters are similiar and they have less coils... even better!!
http://www.rckenon.com/public_html/s...roducts_id=780
Old 08-06-2009, 12:51 PM   #583
gtrmx's Avatar
I found these in Tower Hobbies...
I want to fit some of these right between the second speed gear and the bearing to reduce a little bit of excessive play...
http://www3.towerhobbies.com/cgi-bin...?&I=LXGPC9&P=7
And these are for the middle pulley shaft...
http://www3.towerhobbies.com/cgi-bin...?&I=LXPD13&P=7
Old 08-06-2009, 01:15 PM   #584
RC MARKET's Avatar
Mini-Z front spring ?
RC MARKET is offline   Reply With Quote
Old 08-06-2009, 01:21 PM   #585
PrimeAKF11's Avatar
I did the same thing, but used a spring from a bad ballpoint pen instead . Just cut it to appropriate length and bingo!
Best rubber tires>> www.SweepRacingUSA.com
For your Team Magic G4 parts needs>> www.bluesunhobbies.com
HD Videos of Blue Diamond Onroad Raceway!!! 200ft+ straight of fury!! >> http://www.rctech.net/forum/racing-forum/406318-2nd-annual-pete-johnson-have-nice-day-memorial-race-5.html
PrimeAKF11 is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
