Old 07-21-2009, 07:35 PM   #376
impalabob64's Avatar
Send a message via AIM to impalabob64
Default Hex
Originally Posted by mrgsr View Post
Does anyone know if the xray wheel hexes fit ?
The older Kyosho V1R hexes fit perfect ,you have to get the pins also.I hve them on my car.Direct fit no mod need.
RoninRc.com
MurnanModifiedMotors
Basher BT-4
impalabob64 is offline   Reply With Quote
Old 07-21-2009, 07:37 PM   #377
Trader Rating: 13 (93%+)
Impala how does your car go for weight?
Serpent 748 TQ | GIMAR Engines
Walter RC HObby | www.walterrchobby.com.au
BlueRC | www.bluerc.net
mrgsr is offline   Reply With Quote
Old 07-21-2009, 07:40 PM   #378
Default Weight
I havent had a chance to weigh it yet,anyone out there weigh the car yet let us know.
RoninRc.com
Basher BT-4
Old 07-21-2009, 11:53 PM   #379
abi
Default just got me an 09!, initial thoughts and Q's
Hi all,
Have an 09 in my hot little hands (thanks bundy!)
Initial thoughts -
Well made plastics, no bling, all business!
Things I like -
Compared to my other two cars (both G4S), i like the strength of the power transmitting components, the larger diameter motor clutch, larger dia 2 speed clutch shoes, the larger dia spurs, all should mean less wear and tear with the higher HP motors.
Weight savings -
Like the narrow chassis, smaller side and top bulkheads, smaller narrower diffs etc.
Lots of roll centre adjustment!
Not so keen on -
Injection molded hexes, I clocked mine over in the stubs by hand inside the hubs and sure enough i can visibly see the runout, I dont care so much about the material of construction but hexes should be machined end of story. 0.1mm runout at the hex will be like 1.0mm runout at the tread face!
Bearings, these look to be metal shielded but mine have more resistance to rolling than I'd like (packing grease?), should I wash out in solvent and reoil with low viscosity oil?
Other than that any assembly tips? I oiled my 2 speed oneway (was bone dry) and set the shift point higher so the 1.5mm dimension is now approx 0.5mm, anything else i should do?
Cheers and sorry for all the Q'S.
abi is offline   Reply With Quote
Old 07-22-2009, 12:07 AM   #380
barg's Avatar
Send a message via Yahoo to barg
What you doing in here Johnny??????
XRAY NT1-2015 Spec | Max Power Engines | KO KIY EX10 | Protoform | Matrix Tires | XRAY X12-16
HEI International | www.hobbyexpress.com.au
www.nswrcrcc.com
barg is offline   Reply With Quote
Old 07-22-2009, 12:11 AM   #381
Im just looking around asking questions
Old 07-22-2009, 01:34 AM   #382
I weigh my car, and it is 1704 grams including everything ( tyres, bodyshell ...)
mettuchi is offline   Reply With Quote
Old 07-22-2009, 03:22 AM   #383
Bundy_Bear's Avatar
Originally Posted by abi View Post
Hi all,
Initial thoughts -
Things I like -
Weight savings -
Not so keen on -
No worries dude!
Enjoy it... One question though, did you finish building it already???
BB
MissMooRC Racing
Find us on Facebook https://www.facebook.com/missmoorc
Bundy_Bear is offline   Reply With Quote
Old 07-22-2009, 05:35 AM   #384
Default weight
Are you serious 1704 grams no lipo for me ,for sedan 1725 grams is the weight required for Roar.Is this 1704 with full size tires, are using 1/8 body clips.Man is was planning on getting the Twister prolights with these it would shave 20grams off the car making the car weigh 1684 grams.This will make really fast being so light.Imagen adding a lipo to the car with Twister prolights.
RoninRc.com
Basher BT-4
Old 07-22-2009, 08:10 AM   #385
abi
Originally Posted by Bundy_Bear View Post
No worries dude!
BB
Ha.. not yet, working on it though!
Did the engine and clutch tonight, then started on the chassis, step 8 is next
Thanks again for everything.
Old 07-22-2009, 02:57 PM   #386
aizenbelle's Avatar
My car is 1741 with my regular setup which includes 2 1015 acer metal servos full tank, full size wheels and heavy body shell. I can easily bring it down below 1700g specially because the body that I weighted has over 4OZ of paint
Don't Blame it on the car when you know you cant drive
X_ray Nt_1 08
RRR WC (For sale!!)
G4+EVO
G4RS 09' (IT'S FINALLY HERE!!!!!) Serpent 733 put on hold!!
aizenbelle is offline   Reply With Quote
Old 07-22-2009, 03:08 PM   #387
freestyles's Avatar
Trader Rating: 14 (100%+)
Originally Posted by OLD 69 View Post
Ran the G4RS on the weekend. Positive thoughts straigh up. Looking to impove setup and my driving...
Car held out great all day 3 5min quals and a 20 Main no issues. Oiled my 2 speed oneway with some light bearing oil and had zero issues, didnt even need to re oil it.
Setup as follows:
Front
track width- 198mm
solid axle
toe -1
camber L&R -2
ride height -5mm
droop- 3.5 mm
caster - All the way back
offset-+0.0
Tire 40 jaco
Dia- 59mm
Shock oil - 500 Mugen
piston- 2hole
spring- kit
Shocks layed over all the way
Roll bar 45Deg
ackermann-D
Rear
Trackwidth-200mm
Anti-roll bar 2.2
Diff 50,000
toe 3.0
camber L&R -3.5
ride height- 5.5
droop-3mm
offset-+0.0
tire 40 jaco
shock oil kit-600 Mugen
piston -2hole
spring-kit
gearing 17/62-23/57
clutch spring- Kyosho
clutch shoe - Kit
I feel the car is a little under dampened out of the kit. Cant wait to try a diff in the front too.
...Ari
Hi Ari, good to hear you had a good day with your car for the first time out. I've got a quick question though. Do you normally use a thinner oil in the front? Or was that just for moorebank?
This public service announcement was brought to you by the letter "B" and the number "9". Thanks for watching.
freestyles is offline   Reply With Quote
Old 07-22-2009, 03:28 PM   #388
Here is the weight of my car with pictures. i am using full size sanwa servos, OS engine, Vantage pipe, stratus body. And it weighs at 1692 grams.
Old 07-22-2009, 04:16 PM   #389
Nitro-Racer*'s Avatar
and the tires are new and you have the gas cooler on!!!!
Xray Nt1-Novarossi 3sct-KoPropo-GRP-Altis 2.3-RB Fuels
Xray 808 09-RB Killer 9-Hitec-KoPropo-RB Fuels
Nitro-Racer* is offline   Reply With Quote
Old 07-23-2009, 02:43 AM   #390
gtrmx's Avatar
Hi guys,
I am looking for a piece of advise here...
Please take a look at the vertical lines on the diff cover...
http://img33.imageshack.us/img33/2204/hpim0641h.jpg
Those are cracks that have not torn apart yet, but I am afraid they can.
Back when I used my RRR I had to tighten up my diffs at a point that is very close to what you see in the picture, warpage of the cover included. It was the only way to stop leaking diff silicon.
But with the G4RS 09, that seemed to be too much. Now I do not know how to stop my leak problem, and I need to use new parts if it ends up being I do not have to tighten up so far.
Please tell me how you have used yours, as I have not seen one negative comment or bad experience with your diffs...
gtrmx is offline   Reply With Quote
Team Magic G4 Motorman Nitro On-Road 11759 12-09-2016 06:09 AM
‘FWR Racing Season’ FWR Northwest Racers 11302 08-23-2015 07:38 PM
Team Magic G4 + EVO afm Nitro On-Road 421 08-05-2011 01:31 PM
RC equipments for Sale ijnek Malaysian R/C Racers 22836 09-09-2009 02:50 PM
Just Hobby 1/10 Onroad GP Sedan Challenge Race 2( 08 March 2009 ) justhobby Singapore R/C Racers 28 04-08-2009 10:59 AM
